#113 |
Drives: FR-S Whiteout
What's your build date? MY2014, I presume? This was after Fuji Heavy upgraded the subframe bolts I'm guessing.
Intent > Content
cowardice is the mother of cruelty. |
#114 |
Drives: 2016 FR-S
Yes, MY2014. Bought it last Feb.
| The Following User Says Thank You to Sleepless For This Useful Post: | solidONE (08-14-2015) |
#116 |
Dismember
Drives: 2013 Red Scion FR-S
Theys works fors the spoons bottoms lines.
#118 |
Drives: 2013 Scion FR-S Raven
Yes Sent from my iPad using Tapatalk
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
#119 |
Drives: GT86
I have some concerns. Also I have almost all bushings from Whiteline and some more stuff to sharpen my handling and I have doubts I will see a change after collars installed. Any of you guys who has collars and HEAVY changes in other suspension parts see this mod worth the money?
#120 |
Yes, my signature lists upgrades
#121 | |
Drives: GT86
How would you describe difference after installing them? |
#123 | |
Rigid collars changed the jounce Current Suspension components Whiteline KCA434 & 435 KDT922 & 926 Koni 8641 1559 Front Inserts 8041 1416 Rear Spring Dampners HVT Front Camber Plates 810TM-FT86 Swift Springs 4F912 GT Spec LCA 1473 SPC Adjustable Toe Arms
#124 | |
Drives: '14 GT86 project, '13 GT86 DD
Uneven mating faces?? The body is a pressed steel welded construction that is built on a jig. Every assembly in the world requires tolerance, hence the clearance on the holes. The bolts on the rear subframe pull up through machined steel tubes mounted in rubber bushes. Any angular misalignment of the mating faces is taken up by this rubber. Even if you fit uprated bushes, the bolts will still pull the bush square with the body, and the rigid collar will squash evenly, giving the same result. As for the front subframe.. how on earth can a solidly bolted component, being removed and bolted solidly back into place with what is no more than an aluminium washer improve ride or jounce??? in fact, I would say that shock loads through the stock assembly are less likely to move anything if they don't have an aluminium washer in place??
#125 | |
I'm trying to find some for my other Toyota cars No one is forcing anyone to buy these rigid collars
| The Following 2 Users Say Thank You to tonystewart For This Useful Post: | juliog (08-14-2015), mokinbird87 (11-02-2015) |
#126 |
Dismember
Not exactly a double-blind test. This screams snake oil. And KoolBRZ likes it.
| The Following 2 Users Say Thank You to EAGLE5 For This Useful Post: | tonystewart (08-14-2015), Travisty75 (08-17-2015) |
| Spoon GT86? | c147258 | Scion FR-S / Toyota 86 GT86 General Forum | 67 | 04-27-2016 12:31 AM |
| No Spoon parts for the 86... | twincamRob | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 81 | 06-02-2015 10:37 AM |
| Fs: brand new pbm subframe collars | Guildjs | Brakes, Suspension, Chassis | 3 | 10-16-2014 08:54 AM |
| T1R Differential Collars | Mikepage | Engine, Exhaust, Transmission | 0 | 05-01-2014 09:18 PM |
