Old 07-21-2015, 08:11 PM   #2381
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Interesting.
blackfireball5 (07-21-2015)
Old 07-21-2015, 08:50 PM   #2382
mashal
DADA
mashal's Avatar
Drives: 2013
@blackfireball5 I have rust in that same spot, will do this mod. Thanks!
mashal is offline   Reply With Quote
The Following User Says Thank You to mashal For This Useful Post:
Old 07-22-2015, 10:46 AM   #2383
P86RAVES
Drives: 08 WRB WRX STi / NA Miata
Shouldn't that rust be covered under warranty?
It's based on a RWD Corolla, what do you expect?
P86RAVES is offline   Reply With Quote
Old 07-22-2015, 10:51 AM   #2384
blackfireball5
blackfireball5's Avatar
Drives: Scion FRS Firestorm
It wouldn't hurt to ask I guess.
But honestly I just got this thing set so that it isn't leaking at that seal anymore. I'd rather have minor rust there than have to deal with all the nonsense over again. lol.
blackfireball5 is offline   Reply With Quote
The Following User Says Thank You to blackfireball5 For This Useful Post:
P86RAVES (07-24-2015)
Old 07-23-2015, 11:48 AM   #2385
grant
Drives: too many to list
Originally Posted by BRZtoni View Post
Uploaded my flash and go tune by delicioustuning and my car stalls at idle or feels like going to stall
4 bar fbm map sensor
550cc injector
91 pump gas
What u guys think?
was this short lived? I had the same issue with my wife's but after a few start/stops it was better. A few of the Subaru's do this after resetting the ecu/flash for the first bit, I'm only guessing its a ecu learning kinda thing
grant is offline   Reply With Quote
Old 07-23-2015, 12:41 PM   #2386
BRZtoni
Turbo E85
BRZtoni's Avatar
Drives: 13 wrb brz
delcious sent me a map sensor and my car now runs properly with the flash and go kit. it did not work properly using the map sensor that fullblown provided me. but the tune fullblown provided me with there map sensor worked fine.
Flex Fuel Turbo BRZ
BRZtoni is offline   Reply With Quote
Old 08-06-2015, 11:15 AM   #2387
Howardwei
AC in texas
Does anyone have problem with AC blowing hot air in Texas after idling for while or stop and go traffic for too long?
I have the FBM radiator fan + shroud. The ambient temp was ususally about 97F+; however, same temp in a garage does not see problem like this. Is this something a tune can fix?
Howardwei is offline   Reply With Quote
Old 08-06-2015, 01:27 PM   #2388
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Nope. The only way to fix it would probably be to add a pusher fan to the A/C condenser. I had the same issue. I just accepted it.
Old 08-06-2015, 09:52 PM   #2389
mashal
DADA
mashal's Avatar
Drives: 2013
I have the same issue, I thought my ac had dried out.. Ran a test and all, everything was good.. Like King I just learned to accept it
Old 08-06-2015, 10:02 PM   #2390
Infamous Performance
Infamous Performance's Avatar
Drives: 02 WRX, 05 LGT, 08 LGT, 08 SpecB
You are asking more of the system than it is designed for. Anything over 95deg F ambient air temp is outside the range of efficiency.
Infamous Performance is offline   Reply With Quote
Old 08-08-2015, 07:03 PM   #2391
Jhood
Jhood's Avatar
Drives: 2014 BRZ Limited [6MT/SWP]
Did some re-running of vacuum lines and hoses last night, as well as installed a vacuum distribution block, an ATP Turbo-Tap, and ran the top vent of my AOS to another silicone coupling. Anyone have any negative feedback on any of these? Not sure how well the Turbo-Tap will hold up (for now it works great), or if venting my AOS into the air intake will draw up oil into the turbo.
|FBM Stage 1 Build|GTX2867R|
|Moto-East Flex Fuel & Dyno Tune|
|360whp / 265tq (E81 @ 12psi)|
Jhood is offline   Reply With Quote
The Following User Says Thank You to Jhood For This Useful Post:
BRZtoni (08-12-2015)
Old 08-12-2015, 03:52 AM   #2392
monkie
monkie's Avatar
Drives: 86 GTS
Originally Posted by Kiske View Post
If you give it gas and hold the revs at 1500 or 2k is it pretty smooth? Vac leak?
Make sure you have all the vaccuum lines correctly installed. IMO it was easier to run all the lines without the EBCS to make sure the car was running well. Then add the EBCS and tune for it. Start simple and then add to her.
This was just happening to my FBM set up and after speaking to my tuner he though I had a vacuum leak as well.
Drove the car up there and used his vacuum tester found out that it was the FBM intake pipe was leaking like a bitch where the MAF sensor mounts.
Issues
1. the tapped holes to mount the MAF sensor are drilled straight into the intake pipe with leaks through both screw threads.
2. The MAF plate is far from level causing leaks past the O ring
I thinking of just throwing the intake pipe away or at least cutting it up and mounting a decent MAF sensor mounting plate that isn't uneven and drilled through
monkie is offline   Reply With Quote
Old 08-12-2015, 11:46 AM   #2393
BRZtoni
Turbo E85
BRZtoni's Avatar
Drives: 13 wrb brz
@Jhood im using a turbo tap as well boosted 9PSI. so far so good
Flex Fuel Turbo BRZ
The Following User Says Thank You to BRZtoni For This Useful Post:
Jhood (08-13-2015)
Old 08-13-2015, 10:08 PM   #2394
blindfold
Drives: brz
a minor question, how do you guys deal with the overwhelming EWG noise on the daily basis? Would re-routing the wastegate dump tube back into downpipe decrease the noise significantly?
blindfold is offline   Reply With Quote
best company ever, big fuck off turbo, blown, bow chicka wow wow, fbm, full, owners, powaaaaaa!, thread, will work for turbo
AVO Turbo Kit Owners Topic Sportsguy83 Forced Induction 1935 02-20-2023 10:46 AM
Full Blown FRS/BRZ Stage 1 Turbo Kit FullBlown Forced Induction 456 09-27-2021 03:10 AM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 12:36 PM
Full Blown Turbo Kit! Unleashed Engine, Exhaust, Bolt-Ons 70 10-09-2013 09:46 AM
WTB: Full Blown turbo kit (used) whitefrs Engine, Exhaust, Bolt-Ons 12 03-29-2013 09:15 PM
