#2367 | |
Drives: Late 2014 Subaru BRZ
Give us a follow up |
#2368 |
NASA SpecE30 Racer
First thing I always tell people to check is whether or not the Tial Q BOV is opening up at idle or in high vacuum situations. If it is opening, that is most likely your issue as it causes turbulence in the air flow across the MAF sensor which causes large swings in fuel.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
| The Following User Says Thank You to King Tut For This Useful Post: | #maverick# (07-13-2015) |
#2369 | |
Turbo E85
Drives: 13 wrb brz
just picked mine up from FRSPORT. going to be installing tomorrow wish me luck.
Flex Fuel Turbo BRZ
#2370 | |
Turbo E85
Drives: 13 wrb brz
![]() just added my quick tap to the elbow bend for the compressor housing.
Flex Fuel Turbo BRZ
| The Following User Says Thank You to BRZtoni For This Useful Post: | Cessblood (07-14-2015) |
#2371 | ||
| The Following 2 Users Say Thank You to willharp360 For This Useful Post: | #maverick# (07-13-2015), BRZtoni (07-14-2015) |
#2372 |
NASA SpecE30 Racer
Remember it is just a basemap. You need to get it properly tuned.
- King Tut
#2373 |
#2374 |
Drives: Scion FRS
| The Following User Says Thank You to FullBlown For This Useful Post: | willharp360 (07-14-2015) |
#2375 |
NASA SpecE30 Racer
LJ being conservative, never. When you gonna take down that new horsepower record that seems to need so many threads?
- King Tut
#2376 |
Turbo E85
Drives: 13 wrb brz
Uploaded my flash and go tune by delicioustuning and my car stalls at idle or feels like going to stall
4 bar fbm map sensor 550cc injector 91 pump gas What u guys think?
Flex Fuel Turbo BRZ
#2377 |
Drives: RX-7 / BRZ
The best was you I could describe MAF turbulance on a FBM turbo car is that it would feel like someone was *lightly* tapping on and off the brakes repeatedly.
If you think it may be turbulance and not a fuelling issue the quick look places are the long silicone pipin behind the pass headlamp (is it pinched) On the BRZ they reccomend you unplug the clips that hold the wiring but in the end it still ends up with a slight kink. The second place to check is a the MAF sensor. Unplug and clean it. It is very easy to get a bit of oil/blow by from a fresh install on it (since it is on the underside of the charge piping.) Also tripple check the O-ring around the MAF sensor. You may want to use a bit of RTV to ensure it is 100% sealed around it.
//2018 Crystal White Pearl BRZ Ts 2.2l Harrop Supercharged |
#2378 | |
Drives: RX-7 / BRZ
Make sure you have all the vaccuum lines correctly installed. IMO it was easier to run all the lines without the EBCS to make sure the car was running well. Then add the EBCS and tune for it. Start simple and then add to her.
#2379 | |
Turbo E85
Drives: 13 wrb brz
i removed my EBCS and only have the WG/BOV connected to vacuum and still idles rough as if its misfiring. i contacted delicious and they told me to check the direct injector black metal covers to make sure its making ground and i removed and check them both and it still does it. anyone got any idea of what it is? heres a log of my rough idle and i stalled right at the end.. http://datazap.me/u/brztoni/log-1436...-9-12-13-14-28
Flex Fuel Turbo BRZ
#2380 |
Drives: Scion FRS Firestorm
Hey guys. Here are the pics you guys wanted to see.
Sorry it took so long. I took them but tapatalk had issues with my image resolution so I had to do it on a computer. @mashal @King Tut Catch can with filter to vent to atmosphere. ![]() Weather stripping to make the seal work better ![]() It's hard to see, but just past the latch and under the metal bracket, you can see a layer there. It's some sort of weather proof material my dad had in his garage. It worked perfect. I'll try to find exactly what it was I used. But it is essentially another layer that makes a seal to stop water from going past the holes underneath the metal bracket. ![]() Rust forming around mounting holes. This car has never seen salt from the winter. ![]() More rust
| The Following User Says Thank You to blackfireball5 For This Useful Post: | mashal (07-21-2015) |
| Tags |
| best company ever, big fuck off turbo, blown, bow chicka wow wow, fbm, full, owners, powaaaaaa!, thread, will work for turbo |
| AVO Turbo Kit Owners Topic | Sportsguy83 | Forced Induction | 1935 | 02-20-2023 10:46 AM |
| Full Blown FRS/BRZ Stage 1 Turbo Kit | FullBlown | Forced Induction | 456 | 09-27-2021 03:10 AM |
| FA20Club Turbo Kit Owners Topic | pixel67 | Forced Induction | 1531 | 09-09-2014 12:36 PM |
| Full Blown Turbo Kit! | Unleashed | Engine, Exhaust, Bolt-Ons | 70 | 10-09-2013 09:46 AM |
| WTB: Full Blown turbo kit (used) | whitefrs | Engine, Exhaust, Bolt-Ons | 12 | 03-29-2013 09:15 PM |
