Old 08-13-2015, 02:31 PM   #15
WolfpackS2k
WolfpackS2k's Avatar
Drives: '12 C63 P31, '23 GRC
Originally Posted by humdizzle View Post
completely different car. An M2 would do everything better than a twin aside from gas mileage. Even though its only 10" longer its about 700 pounds more than a twin and i guarantee you would feel that in an autocross.
For the price of an M2 you could get a mint E92 M3 and change in ur pocket.
Good point. I'd take that high revving V8 over a turbo 6 every time.
Old 08-17-2015, 08:18 PM   #16
SUB-FT86
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
I would rather buy a kit from DBW in Atlanta that cost less than 5k with install/tune/and dyno than get a 3500 lb M2. And for some reason the only BMW I like the looks of is the overweight Z4 and 4 series.
SUB-FT86 is offline   Reply With Quote
Old 10-13-2015, 08:58 PM   #17
damnitBobby
damnitBobby's Avatar
Drives: 2016 frs 6mt
I like it.
damnitBobby is offline   Reply With Quote
The Following 3 Users Say Thank You to damnitBobby For This Useful Post:
86kahl (03-22-2016), NLS8520 (04-26-2017), ort895 (02-25-2016)
Old 10-13-2015, 10:42 PM   #18
synchromesh
synchromesh's Avatar
Drives: Ultramarine Blue
It isn't a bad comparison per say. When the FR-S first came out a Rocket Bunny kit wasn't cheap. I'd say 7-8000 maybe $10,000 with a nice 2nd set of wheels with tires. Forced induction with an appropriate suspension and brakes, your looking at another 10g's at least.
Someone on the 2addicts forum claims, from a rep, the M2 will start at $51,000.
If this is true, that's thousands less than what I first thought. With this information combined with a decent residual lease, the thought of throwing money away on a supercharged daily driving FR-S has lingered.
synchromesh is offline   Reply With Quote
Old 10-14-2015, 01:40 AM   #19
xuimod
Drives: 2007 MX-5 Miata, 2015 VW Golf GTI
You could buy 2 good used FR-S's and turbo charge both of them for the price of 1 M2. And the M2 has an 'active differential' which uses sensors and an electric motor.... to many parts that could break and malfunction. I think a LSD would have been a better route (more proven solution).
xuimod is offline   Reply With Quote
Old 10-14-2015, 01:57 AM   #20
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
People on this forum will compare the FRS/BRZ to pretty much everything and still ultimately decide that the FRS/BRZ is the better car.
How can any realistic comparison even be made to the M2? This shit isn't even out yet.
The Following 9 Users Say Thank You to TylerLieberman For This Useful Post:
86kahl (03-22-2016), Basket Case (10-14-2015), Dpk3 (02-26-2016), drewbot (10-14-2015), evomike (10-14-2015), GotBRZ1691 (10-15-2015), jdmblood (10-15-2015), shu5892001 (10-15-2015), Tcoat (10-14-2015)
Old 10-14-2015, 09:15 AM   #21
The Following 7 Users Say Thank You to Tcoat For This Useful Post:
86kahl (03-22-2016), Dpk3 (02-26-2016), fatalelement (10-15-2015), GotBRZ1691 (10-15-2015), gt8613 (12-18-2015), jdmblood (10-15-2015), MTpockets (10-16-2015)
Old 10-14-2015, 09:58 AM   #22
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
Sorry but anything up around the $50k range, I'm looking at the Shelby 350. The m2 is nice and all but it doesn't ooze specialness like a 5.2 liter v8 at 8200rpm. Not even close.
industrial is offline   Reply With Quote
The Following 4 Users Say Thank You to industrial For This Useful Post:
bfrank1972 (10-14-2015), GotBRZ1691 (10-15-2015), pinski (10-15-2015), WolfpackS2k (10-15-2015)
Old 10-14-2015, 10:36 AM   #23
DarkSunrise
DarkSunrise's Avatar
Originally Posted by tahdizzle View Post
Last good M cars (in my opinion) was the M coupe and the 1M.
I came across a 1M at my last track day at VIR. Very impressive car. Pulled over 5 bus lengths on me on the front straight (about 80-120 mph in the FR-S). Even my friend's supercharged E46M didn't pull nearly that hard. Factory turbo'd cars make power so easily with mods. It was also nearly as fast as my car through corners.
If it's anything like the old one, the new 2M should be pretty spectacular.
Good handling chassis + turbo I6 =
2022 BRZ Build
2013 FR-S Build
The Following 2 Users Say Thank You to DarkSunrise For This Useful Post:
NLS8520 (04-26-2017), strat61caster (10-14-2015)
Old 10-14-2015, 10:48 AM   #24
Trettiosjuan
Drives: GT86
The M2 will be fairly similar to the 1M I recon, which was a good car. But not comparable to the twins.
Originally Posted by 8R6 View Post
long live the E30M
If anything, the twins are a modern day equivalent of the E30 icon. Similar concept, weight and power. Both drivers cars, both did well with some further fine tuning, and both have been subjected to ludicrous turbo builds and engine swaps.
Some things don't change.
Trettiosjuan is offline   Reply With Quote
Old 10-14-2015, 11:39 AM   #25
jvincent
jvincent's Avatar
Let's bench race the new M2 against the FRS.
- M2 is about 22% heavier.
- M2 will have about 82% more horsepower.
M2 FTW Brah!
In all seriousness, the M2 looks like it will be a nice ride.
The Following User Says Thank You to jvincent For This Useful Post:
CSG Mike (10-14-2015)
Old 10-14-2015, 01:02 PM   #26
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
http://www.automobilemag.com/feature...-a-drift-mode/
Old 10-15-2015, 04:22 AM   #27
JW89225
Drives: E92
Both true and not true, modern cars are surprisingly well at "coping" with weight. I've driven cars that feel similar in weight but different in reality. Lightness is always but it isn't the end all be all. While no light weight, but surprisingly the F80 M3 I tossed around felt as nimble and flat as my FR-S. My E92 M3 on the other hand doesn't mask the weight as well.
Cast in point is from behind the drivers seat on the street doing sporty driving, the F80 is almost every bit as nimble and lightweight on the feet as the FR-S despite being hundred pounds more. With that said, tires and brakes and other wear components will wear much faster on the M cars. I think the new M rolls less than the FRS stock for stock.
I'm sure the M2 will be another great driver's car per say.
2013 Scion FR-S 6AT
JW89225 is offline   Reply With Quote
Old 10-15-2015, 12:32 PM   #28
EAGLE5
Dismember
EAGLE5's Avatar
With wide, sticky tires, computer-controlled differentials, active roll bars, and computer-controlled struts, even a pig can dance. That doesn't mean a heavy car is the same experience as a lighter one.
The Following 3 Users Say Thank You to EAGLE5 For This Useful Post:
GotBRZ1691 (10-15-2015), WolfpackS2k (10-15-2015), xuimod (10-15-2015)
Twins vs. a used C6? Shadowsong6 FR-S / BRZ vs.... 64 05-29-2015 12:23 PM
Other twins gravitylover Other Vehicles & General Automotive Discussions 53 03-02-2015 12:38 PM
Twins vs GT 350 ScottDRFT FR-S / BRZ vs.... 53 01-22-2015 10:39 AM
Is it just me or Twins are everywhere now? DrawingWaves Scion FR-S / Toyota 86 GT86 General Forum 93 03-20-2014 10:31 PM
The twins pnig BRZ Photos, Videos, Wallpapers, Gallery Forum 2 02-06-2014 07:52 PM
