Old 08-08-2015, 11:30 AM   #85
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
Here’s a plot showing three fast laps from the last month.
Blue- Yesterday’s second morning session. 1:27.2
Orange- July 30th morning session. 1:26.4. RE71Rs & Tarmac 2s
Green- July 18th morning session. 1:28.1. RE71Rs & stock suspension
Smooth lines are speed, and the noisy lines are lateral acceleration. Track surface temps from yesterday were within a few degrees of the other runs, and actually cooler than the session on the 30th. So it shouldn’t be an issue with the tires being on a hotter track.
We were developing higher lateral loads through the longer corners on the “orange” lap. The second smaller plot at the bottom of the graph shows time differential from the fastest lap, and you can see we’ve got the highest increases in time through those same corners where “orange” was developing more grip.
I think this pretty clearly shows the tires are slowing down, and are negating any benefits we might see from the Tarmac 2s and swaybars. Fresh tires are on the way!
GSpeed is offline   Reply With Quote
The Following 3 Users Say Thank You to GSpeed For This Useful Post:
DarkSunrise (08-08-2015), Jonsey (08-08-2015), Valentino (08-09-2015)
Old 08-08-2015, 12:54 PM   #86
Bramick
Bramick's Avatar
Drives: 2013 BRZ Limited M/T
Thoughts about environmental factors, like increased summer heat?
2013 BRZ Limited | 1965 Mustang GT Fastback
Bramick is offline   Reply With Quote
Old 08-08-2015, 12:55 PM   #87
Bramick
Bramick's Avatar
^^^ ignore. I clearly can't read
Old 08-08-2015, 01:06 PM   #88
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
No worries, it was a legitimate question. Here's the average temps per session, as measured by the IR sensor looking at the track:
July 18th- 94.2°
July 30th- 108.5°
Aug 7th- 108.5°
So yeah. They were the exact same average temperature, down to the third decimal place. Some sections of the track were cooler on the Aug 7th session than they were on the July 30th session, and vise versa. Not enough deviation to explain any of those thermal variations in the tires, though.
Old 08-08-2015, 06:28 PM   #89
IPGJames
Drives: ...Cars...
Interesting stuff ... I will be following along
IPGJames is offline   Reply With Quote
Old 08-11-2015, 05:03 AM   #90
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Finally got through it, I'm getting some insight into that tire thread, awesome deal with all the data collecting and a huge thumbs up for publishing anything at all.
Personal thought: the camber plates will be the most effective upgrade you've done since the tires. Will you be testing them on your old or new tires? Would be interesting to see (and would keep the data within family to your most recent test with the swaybars and coilover)
Seriously though, camber. I've read some guys are running over -3 and I can personally vouch that it transformed my car from an understeering pig to the balanced machine all the magazines claimed it was.
Best of luck, look forward to the results!
ineedyourdiddly
The Following 2 Users Say Thank You to strat61caster For This Useful Post:
GSpeed (08-13-2015), Pat (08-11-2015)
Old 08-13-2015, 11:20 AM   #91
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
Finally installed a Perrin oil cooler, so our 280° oil temps will be a thing of the past! (At least for now...)
In our spare time, we've been working on a gas pedal relocation mount. The stock pedal position leaves a little to be desired, so we've moved it a little closer to the driver, and a tad closer to the brakes. By bringing the pedal closer to the driver, you're able to get a more confident toe position for heel-toe work by keeping your foot more "on top" of the pedal, with less risk of falling off the side.
Here's a picture of the proof of concept we machined in house on a manual mill. The production ones will be CNC machined and pocketed, and a good deal lighter.
Be watching for a group buy for the first run of these guys. Thanks to @ichitaka05 for the idea.
Here's a teaser shot of the camber plates we'll be running. They appear to be very well made. We can't say whose they are yet, but they're designed to be very affordable.
The Following 13 Users Say Thank You to GSpeed For This Useful Post:
BatStig (08-13-2015), Bramick (08-13-2015), civicdrivr (08-13-2015), DAEMANO (08-15-2015), e1_griego (08-13-2015), ichitaka05 (08-13-2015), Jonsey (08-13-2015), kch (08-13-2015), NLSP (08-14-2015), philooo (08-14-2015), Tristor (08-30-2018), Valentino (08-15-2015), VerusEric (08-13-2015)
Old 08-13-2015, 11:51 AM   #92
Jonsey
Jonsey's Avatar
So I will bite. What do you guys like about these camber plates that others don't offer?
Put me on the list for the pedal kit.
"It is better to keep your mouth closed and let people think you are a fool than to open it and remove all doubt." Mark Twain
Jonsey is offline   Reply With Quote
Old 08-13-2015, 11:56 AM   #93
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
Honestly? They were free. This company has a history of well-designed and engineered parts, and they asked us to test them out on track. They seem to be a great bang-for-your-buck part to add an effective amount of camber.
That being said, they know we won't pull any punches with what we learn. If we don't like something about them, we'll be frank. They're putting themselves out there by giving us these and having us review them, so we've got to respect that.
We have a policy of not putting parts on our car that we wouldn't feel comfortable putting on a customer's car, regardless of price or incentives. These pass that test.
The Following 2 Users Say Thank You to GSpeed For This Useful Post:
calmtigers (10-05-2015), VerusEric (08-13-2015)
Old 08-13-2015, 12:17 PM   #94
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Glad to see you're working on pedal relocation mount. I'll be interested to see how much difference it makes.
Edit: Also I want add few other things after reading all the posts here. It's very good info is written here and I hope all other members read this thread.
Just my 2 things:
1. 225 vs 245 is up to which track. I've heard both great on track putting down better time than other one. You might need to test 225 to see if it gets better time. My local 86/BRZ track geeks are getting better time w 225 instead of 245.
2. From few other engineers (Cusco, AVO & so on) have been testing out different sway bar stiffness/size. For several reasons, but majorly this car great a lot of common track answers. Bigger isn't always better. Stiffer isn't always better. There have been a lot of test have been going on and more to come.
Please keep up the awesome work
The Following 3 Users Say Thank You to ichitaka05 For This Useful Post:
DAEMANO (08-15-2015), Jonsey (08-14-2015), nikitopo (10-24-2015)
Old 08-13-2015, 01:20 PM   #95
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Definitely interested in that pedal relocation bracket.
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 08-14-2015, 11:53 AM   #96
Jonsey
Jonsey's Avatar
The track they are testing on is very technical with short straights and favors grip over power, so in this instance I don't think the 225s are the better choice. The top speed for me on this track is 103-105. Part of why I love it, the vettes and porsches don't have such an advantage.
Just my 2 things:
The Following 3 Users Say Thank You to Jonsey For This Useful Post:
DAEMANO (08-15-2015), GSpeed (08-14-2015), ichitaka05 (08-14-2015)
Old 08-14-2015, 06:00 PM   #97
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Doesnt look like there is any caster built in these. Might want to do that if these guys are still pre-production. That would be one major consideration besides the price and quality for myself.
Intent > Content
Old 08-15-2015, 12:56 AM   #98
DaiTT500
DaiTT500's Avatar
Drives:
I don't know if I missed it but instead of the pedal relocation, why not use the cusco pedal extension? Is there a disadvantage of that?
DaiTT500 is offline   Reply With Quote
North East Track/AX - what did you sign up for? dp1 NY / NJ / CT / PA 42 10-17-2016 11:51 PM
Ohio Track Day - Nelson's Ledges 2015 mcquarrieg Great Lakes 24 08-04-2015 03:43 PM
Bar & Track - 2015 Subaru WRX Review FT-86 SpeedFactory FR-S / BRZ vs.... 71 05-26-2014 12:08 AM
