Old 08-12-2015, 03:35 PM   #365
350matt
Drives: toyota mr2/ Toyota GT86
crank pulley on this motor is about 138mm diameter I think
so 7500rpm crank with 80mm pulley = 13157 rpm
also thanks for the boost data earlier
regarding the 80F uplift on charger exit temp what IAT is it post intercooler as thats the figure of interest
and how long can it hold onto this delta T before temps run away?
the reason I ask is that there's a lot of history with the 210 setup of IAT's that climb and climb on track use or after a couple of dyno pulls
i get that spinning a bigger blower slower will result in colder air but we're still tlaking about a fair level of boost here
350matt is offline
The Following User Says Thank You to 350matt For This Useful Post:
WHITE (08-12-2015)
Old 08-12-2015, 04:01 PM   #366
WHITE
Thats pretty neat
WHITE's Avatar
Drives: LOADING......
Well thats possibly my problem, I was assuming the crank was closer to 149mm.
Can anyone confirm the crank pulley is 138mm?
Edit:
Just did my math with your numbers and I got a different rpm then you did for the blower. Here's what I'm doing.
Crank rpm * crank diameter(inches) / blower pulley diameter(inches)= blower rpm.
So, 7500 x 5.43(138mm) / 3.15(80mm) = 12,928.57 rpm
What am I doing wrong?
WHITE is offline
Old 08-13-2015, 02:07 AM   #367
350matt
you just need the ratio from the 2 pulley sizes then multiply that by the crank speed
so 80mm / 138mm = 0.579
7500 / 0.579 = 12953
so obviously my sums were a bit out the 1st time, whata can I say it was late, I'd had a snifter and just rattled it off
350matt is offline
WHITE (08-13-2015)
Old 08-13-2015, 07:38 AM   #368
smudge
Drives: Supercharged GT86
So a 70mm would be 14,792 @ 7500rpm?
smudge is offline
Old 08-13-2015, 08:14 AM   #369
WHITE
Thats pretty neat
WHITE's Avatar
That number makes me happier. my way and your way both work out the same, our slight difference in number now is because your using mm while I'm a grumpy American who wont give up inches haha.
WHITE is offline
Old 08-13-2015, 04:43 PM   #370
350matt
correct
and max speed on this charger is 15,000rpm...... so 7600 engine speed
350matt is offline
Old 08-14-2015, 05:25 AM   #371
smudge
correct
Good stuff, might just confirm that with Sprintex and Moto-East before I go sticking the 70mm on though
Cheers guys
smudge is offline
Old 08-14-2015, 09:18 AM   #372
Kodename47
Kodename47's Avatar
Drives: UK GT86
Cheers guys
Have you checked the calculator that @SprintexUSA posted earlier? 15,000 is max RPM, but 13,500 is the continuous max (and stated Max RPM). You might as well cap the RPM as you'll already be running good power, rather than risk a pricey rebuild on the compressor You can have per ger limits you know, I allow mine to spin up in 1st and 2nd but start reducing it so you won't risk it in the longer gears.
.: Stealth 86 :.
Kodename 47 DJ:
Kodename47 is offline
SprintexUSA (08-14-2015)
Old 08-14-2015, 11:43 AM   #373
SprintexUSA
SprintexUSA's Avatar
Drives: 2014 FT86
Heat after the intercooler is supposed to be within 5-10 degrees above ambient. Please also note that burping air out of the intercooler is very important. You might need to burp it a few times before it is happy. When all of the air is out of the system, then post-intercooler air temperatures should stay consistent for a lot longer.
You will always make more heat the longer you are running the vehicle hard. That is just a fact of life.
Heat is a real bugger to deal with in the first place. Temps always climb on the dyno and track, run after run, compressor or not. E85 runs too cool in some instances and has to be beat on to get UP to a good temperature. You're always fighting either too much or too little heat with performance applications.
We tend to leave you up to your own means when it comes to doing your builds. We put a lot of time and effort into developing the happiest medium between power and longevity. The happier product lives longer. If you had the fastest breakneck thing out of the box that broke every other part in your driveline, we think you'd hate us. That's why the big unit was labelled "for racing only" and the smaller unit for street use. You're either racing a street system (210) or trying to drive a race system on the street (335). The 210 is better at autocross than 20 minute lap sessions. The 335 can take the beating of track sessions, but is overpowering for autocross and street use.
SprintexUSA is offline
Old 08-26-2015, 02:27 PM   #374
Dream20b
Y u do dis?
Does anyone have a parts list of what comes with the 335 UPGRADE Kit?
Dat Hot Lava Doe
Clearly you have no clue what you are talking about. Everything you said was completely and utterly the ramblings of a babbling idiot regurgitating garbage from his mouth. Everyone here is now dumber from reading your post. Please die now.
Dream20b is offline
Old 08-26-2015, 02:44 PM   #375
SprintexUSA
Drives: 2014 FT86
In short:
335 blower with nosedrive, 80mm pulley, and inlet casting
hardware + o-rings
The Following User Says Thank You to SprintexUSA For This Useful Post:
Dream20b (08-26-2015)
Old 08-26-2015, 06:54 PM   #376
stockysnail
Just the tip
stockysnail's Avatar
Originally Posted by SprintexUSA View Post
In short:
hardware + o-rings
If I do upgrade but want to sell my 210, what parts do I need to make the 210 into a complete kit again and how much would it cost? I'm considering upgrading early next year after tax returns come in.
stockysnail is offline
Old 08-26-2015, 09:07 PM   #377
SprintexUSA
Drives: 2014 FT86
You would need far more in parts to make a complete kit than would be worth it. Figure $2k+ in parts pretty easily. Like I mentioned, there are enough DIYers on RS25 that someone would buy it.
stockysnail (08-27-2015)
Old 09-01-2015, 02:47 AM   #378
sam69
Drives: GT 86
Any one else got their 335 up and running ??
Been very quite on this thread for a while
sam69 is offline
500whp or bust, sprintex, sprintex 335
The new sprintex 335 supercharger jet86 Forced Induction 39 11-01-2014 11:27 AM
Innovate/sprintex SC rudysaliby Scion FR-S / Toyota 86 GT86 General Forum 3 10-28-2014 03:14 PM
Innovate/ Sprintex vs vortech GeeTee86 AFRICA 24 04-04-2014 02:38 PM
Innovate/ Sprintex vs vortech GeeTee86 AFRICA 5 03-05-2014 07:26 AM
TyperRspec789's Full Blown Stage 1 Base Turbo & e85 Progress and Testing TyperRspec789 Forced Induction 63 12-31-2013 07:39 PM
