#15 |
Drives: 2005 STi, 2015 FR-S
Nicely done!! If you don't mind me asking, what plastic are you printing with? I have access to a Dimensions FDM printer but limited to ABS and I'm weary of it supporting the weight of a 6.5" especially over bumps with aftermarket suspension. How are yours holding up?
#16 |
Drives: Whiteout FR-S
If you can let me know the depth and how much clearance up front also that would be great. I could mount an mdf ring on top of the adapter for more depth if needed if there is enough clearance up front. Mine wouldn't have a tweeter on it either and would need something to support 5-6 pounds.
#17 |
Apostle
Drives: JesusMobile
This is freakin cool, open source speaker mount upgrade! Thanks for sharing!
#18 |
Drives: 2013 BRZ Limited
The panels have not been modified in any way. The new speakers sit in precisely the same locations as the factory ones in terms of distance from the panel.
The BlueBaru Turbo Rebuild: http://www.ft86club.com/forums/showthread.php?t=90382
I Rebuild BRZ's for Breakfast. ![]() |
| The Following User Says Thank You to TurboBRZ For This Useful Post: | tato.valverde (08-05-2015) |
#19 | |
#20 |
The speakers sound awesome. I am printing off some mounting plates for my new front speakers so I can complete the system. Full sound as the coaxes are a woofer and tweet I believe.
#21 | |
I Rebuild BRZ's for Breakfast. ![]() Last edited by TurboBRZ; 08-03-2015 at 09:52 PM. |
#22 |
Drives: 2014 FRS Monogram Edition
So you have a 6.5" speaker covered by a panel and firing out through a 3.5" speaker grill? How does it sound?
#23 |
It sounds great. The position of the speaker allows the tweeter to be right near the center of the grill, which puts the woofer right behind it. So I still get full sound out of those grills and it's so much nicer with incredible clarity compared to the stock speakers they replaced.
| The Following 3 Users Say Thank You to TurboBRZ For This Useful Post: |
#24 |
Here is the front speaker adapter I made (another member on the forum gave me the inspiration) so I can replace the factory 6.5" with some Focal 6.5". It takes 20 hours to print a single side in 2 pieces!
| The Following User Says Thank You to TurboBRZ For This Useful Post: | DAEMANO (08-08-2015) |
#25 |
#26 |
Drives: Toyobaruion
I'd buy a pair of 5 1/4" rear adapters if you want to make and cut some. I haven't put in my rear speakers yet because of the lack of adapter lol
#27 |
Drives: Subaru BRZ
#28 |
I can make them, but I would need to know the diamater of the basket on the back of your speaker (the innermost measurement of the ring) - this way I can ensure they fit properly when you get them.
| 3D Printed Double Din Adapters | cmspooner | Electronics | Audio | NAV | Infotainment | 22 | 09-11-2019 10:22 AM |
| 3D Printed Speaker Adapters | Shankenstein | Electronics | Audio | NAV | Infotainment | 57 | 09-21-2017 07:55 PM |
| 6.5in Speaker Adapters for Door - Really Necessary? | geruta | Electronics | Audio | NAV | Infotainment | 2 | 04-26-2015 05:13 PM |
| Subaru Audio door speaker adapters | JoeBoxer | Audio/Visual, Electronics, Infotainment, NAV | 0 | 12-16-2012 11:13 PM |
| FS: 3/4" PVC Speaker Spacers/Adapters for the BRZ/FR-S | phenryiv1 | Audio/Visual, Electronics, Infotainment, NAV | 1 | 08-22-2012 05:03 PM |
