Old 08-07-2015, 08:57 PM   #29
funwheeldrive
Originally Posted by Phaedrus29 View Post
Just notice this today...frown:
Anyone sorted out how to take care of this? Is this a bulb I can just replace myself?
Originally Posted by stockysnail View Post
Add me to the list now as well. Passenger brake in top corner. Also another guy in my area had a few LEDs go out. I bought them used so I may be screwed.
Originally Posted by anthonybrz View Post
I just found out some of the LEDs went out in my TOM's yesterday. I contacted the seller and they said the warranty doesn't cover the LEDs, only the housing on the TOM's. Now I'm like
Do you guys have the clear or red TOMs?
Old 08-07-2015, 11:55 PM   #30
ZOMBRZ
Drives: 2014 CBS BRZ Limited
I have the same problem on my clear toms on the top left corner of my left light.... I've just tried to cope with it. It's hard though.
ZOMBRZ is offline   Reply With Quote
Old 08-08-2015, 01:07 AM   #31
funwheeldrive
Are your clears starting to melt too?
Old 08-08-2015, 02:26 PM   #32
ZOMBRZ
Yea on both sides right at the top in the middle. The melting stopped though. Is this only with the clear ones?
Old 08-10-2015, 12:35 PM   #33
funwheeldrive
The melting only happens with the clear Toms from what I've read.
It would be interesting is the LEDs going out is a result of melting tails. This seems like a growing problem though.
Old 08-10-2015, 01:08 PM   #34
Phaedrus29
Phaedrus29's Avatar
Drives: 2013 Subaru BRZ
My LED went out on one of my red Toms, not the clear. I believe if you aren't under warranty then Toms USA will still offer you a replacement tail light at a discounted rate. The individual bulbs themselves are not replaceable.
Phaedrus29 is offline   Reply With Quote
Old 09-09-2015, 05:57 PM   #35
XanRules
A Very Powerful Wizard
XanRules's Avatar
Drives: 2014 BRZ LTD WRB (RIP), 2017 FiST
do you have contact info for Tom's USA? All I can find is contact info on their japanese site for their JDM dealers.
XanRules is offline   Reply With Quote
Old 10-03-2015, 06:13 PM   #36
XanRules
XanRules's Avatar
Just wanted to say that according to BuddyClub/TOMS USA, individual bits ARE replaceable but you've gotta crack open the taillight and solder in new relays.
Sent from my A0001 using Tapatalk
Old 12-16-2015, 10:05 PM   #37
rileymcmuffins
Drives: 14 FR-S
Any updates on these? I'm at the point now where I have no left side brake light and have a dead one on the right. I bought used and would like to repair vs buy
rileymcmuffins is offline   Reply With Quote
Old 12-20-2015, 02:03 PM   #38
akiranakayama
Drives: 2013 Subaru BRZ Limited (CBS)
It's a shame people are having problems with these tail lights. Tom's are some of the coolest units for the 86 platform.
Lotus Elise / Exige owners have had to deal with a very similar issue with the LED taillights of 2006 and later cars. I've had mine burn out as well. The issue with the OEM units is the resistors for the diodes are too weak, causing the LEDs to be overdriven and that shortens their service life. At least, that's what the forum consensus seems to be. Owners have cracked open the housings and desoldered the resistors and put in higher rated resistors and the problem hasn't come back since. The diodes are not as bright, but only just. Probably wouldn't even notice unless someone pointed it out.
Maybe that's the same thing going on here? :shrug:
2016 Scion FR-S
1991 Acura NSX
2012 Mazda Miata (Track)
2019 Triumph Bonneville Bobber
2007 Suzuki SV650 (Track)
akiranakayama is offline   Reply With Quote
The Following User Says Thank You to akiranakayama For This Useful Post:
funwheeldrive (12-21-2016)
Old 12-18-2016, 11:37 PM   #39
LANI86
Drives: 2015 Scion FR-S
Has anyone purchased the Red (DOT approved) TOMS lately and experienced any issues? I've gone through 2 OEM's due to condensation and thinking of putting TOMS on this time. I've been very hesitant reading through this topic as there is no true answer as to why the LED(s) is failing. I'm going to be patching up the gap between the metal and tail light with something more resistant and stronger this time, and I don't want the lighting to become another issue as the condensation is already a pain in the a**. Anyone with the Red TOMS longer than 3 years without any problem??
LANI86 is offline   Reply With Quote
Old 12-21-2016, 11:50 AM   #40
funwheeldrive
I have owned my red TOMs for almost 2 years now. So far so good. The car is garaged in Northern California though, so it doesn't have to deal with the elements constantly. I try to regularly check them out to make sure nothing is burned out.
Old 12-21-2016, 01:11 PM   #41
FX86
out of curiosity..let's say one of the smd's is burned out..what do you do then? do they have a long warranty on those or are you out of luck then?
i guess the same questions can be applied to the stock lights if one of the leds die and your warranty on the car is expired....end up buying new or used ones that fully work?
i always thought about getting the aftermarket tail lights but all those tiny leds everywhere make me worry if they go bad then the whole look is off
Old 12-21-2016, 01:30 PM   #42
funwheeldrive
I worried about my Tom's failing before I pulled the trigger on them, but I also can't stand the OEM tails on a red 86.
If mine ever burn out I will probably just buy a set of used Kouki taillights. Hopefully they get pretty cheap over time.
Valenti / Lexon / Tom Tail lights, Winjet Headlights, Front Bumper lights and Mirrors Speed Element Exterior Parts - Lighting 224 12-06-2016 02:07 PM
TOM'S Racing JDM LED Tail Lights , Spyder LED Tail Lights, and JDM Side Markers!! Evasive Motorsports Exterior Parts - Lighting 94 12-18-2015 01:19 PM
FS/FT RED TOM'S LED USDM DOT Tail Lights FOR CLEAR TOM's LED Tail Lights giants130 Exterior Parts (Aero, Lighting, Etc.) 4 04-28-2014 06:41 AM
WTT - My Vertex tail lights for Crystal eye tail lights drftxx Exterior Parts (Aero, Lighting, Etc.) 0 02-19-2014 10:34 PM
AT - Failed to downshift in manual mode abutterman Issues | Warranty | Recalls / TSB 26 03-14-2013 09:11 AM
