Old 08-06-2015, 01:56 PM   #295
CxG
Drives: Pearl White '13 ZN6
Originally Posted by tahdizzle View Post
@CxG
I'm not sure why you would want to. As far as CARB goes. You need that intake, because the system is CARB exempt. Any modification to it will fail visual.
It also flows better.
The only reason I can think of to delete that would be cosmetics.
I'm in NY so I just need to pass OBD II if I'm not mistaken.
Compared to the stock intake yes less airflow but I need to kill that torque dip so was planning on running the grimmspeed intake and some no cat uel headers until early summer next year (plan on getting suspension, brakes, clutch, transmission, and audio work done before going forced induction).
I was (and still am) strongly considering the turbo route for low end torque. The thing is if this kit will allow me to make that power down low (unlike the HKS and vortex) while giving me the option to keep both the intake and header of my choice (unlike the AVO and ptuning) then this kit will probably win out.
I'm only aiming for 230 wheel torque so it's not like I need the overhead the turbo kits provide and yes trying to keep a certain aesthetic appeance if I can. Who says you can't have functional form?
Sent from my D5803 using Tapatalk
CxG is offline   Reply With Quote
Old 08-06-2015, 01:58 PM   #296
tahdizzle
So elite I'm 1338
Drives: WRB Subaru BRZ
@CxG
If you are seriuosly thinking about getting the kit. Skip the intake and tune. Go ahead and buy headers, but You'll be paying 2x for the tune if you go your route, and an intake won't net you any real gains anyway, bro.
-Jack Burton
The Following User Says Thank You to tahdizzle For This Useful Post:
CxG (08-06-2015)
Old 08-06-2015, 02:12 PM   #297
brady86
Drives: 2013 firestorm fr-s
This is the exact same supercharger they use in the lotus evora s correct? that cars 0-60 is in the low 4s i think and it weighs 3166lbs granted it has a 3.5 for engine size so that should add a lot more power. i wonder if its the same pulley size on that car as this kit. maybe we could see mid to high 5s 0-60 with this kit and decent wheels then we can compete with 350z!
brady86 is offline   Reply With Quote
The Following User Says Thank You to brady86 For This Useful Post:
Kamakanani0 (08-06-2015)
Old 08-06-2015, 02:16 PM   #298
This kit has taken the edge off my Cosworth desires...want I do, Cash I do not....
The Following 6 Users Say Thank You to Dadhawk For This Useful Post:
civicdrivr (08-06-2015), DAEMANO (08-08-2015), itsibarra (08-06-2015), Kamakanani0 (08-06-2015), Phantobe (08-06-2015), tahdizzle (08-06-2015)
Old 08-06-2015, 02:20 PM   #299
Yoda
Drives: Crystal Black BRZ(Sophia)
Start saving. If you want it bad enough you will start bring lunch to work like me
Yoda is offline   Reply With Quote
The Following 6 Users Say Thank You to Yoda For This Useful Post:
CxG (08-06-2015), Dadhawk (08-06-2015), funwheeldrive (08-07-2015), itsibarra (08-06-2015), Kamakanani0 (08-06-2015), Phantobe (08-06-2015)
Old 08-06-2015, 02:26 PM   #300
Sadly, cash flowing three kids through college with no debt means I haven't eaten lunch out in 8 years, but I hear ya!
funwheeldrive (08-07-2015), Kamakanani0 (08-06-2015), ultra (08-22-2015)
Old 08-06-2015, 02:28 PM   #301
tahdizzle
So elite I'm 1338
You and ghandi musta been college roommates.
-Jack Burton
The Following 2 Users Say Thank You to tahdizzle For This Useful Post:
azian_advanced (08-23-2015), Dadhawk (08-06-2015)
Old 08-06-2015, 02:31 PM   #302
The Racers Line
The Racers Line's Avatar
Drives: FRS, Supra, Colorado D, GLC63
Now, if only we could get a good look at the W2A radiator mounting, so I could be assured that my oil cooler would work.
I'd love to see as well, because it looks to be larger than the stock radiator
The Racers Line is offline   Reply With Quote
Old 08-06-2015, 02:45 PM   #303
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
You should sign up to be an official installer, we only have one in South SF
Old 08-06-2015, 03:14 PM   #304
wootwoot
Drives: FRS
Yes!
Old 08-06-2015, 03:37 PM   #305
The Racers Line
I've got an email into them. Waiting to here back!
Old 08-06-2015, 07:01 PM   #306
Nevermore
Wayward Member
Nevermore's Avatar
Drives: Hot Lava 86
I always figured I'd stay N/A but if I went forced induction it would be supercharged. For some reason, this makes me want it more than other kits...
Nevermore is offline   Reply With Quote
Old 08-06-2015, 07:04 PM   #307
xwd
Originally Posted by Budo View Post
Gentlemen,
It appears that the 1320 is similar enough to the 335 giving up just a bit, say, .2 liters or so per revolution and yet it seems the maximum rpm is 18000 versus 15000. Dare I say it and chastise me if I am wrong, but I think this Edelbrock blower is a stunner. Fine for a stock engine on the carb tune and yet enough potential flow for something I think to be, quite serious for a 2800 pound car.
Cheers,
Budo
I've posted this a few times before, but this is the dyno from the TRD S/C using the TVS1320 on Stout Racing's FR-S from a couple years back. This is on a 10.5:1 CR engine running 98 octane fuel, 12psi iirc. Definitely a smaller pulley than what Edelbrock is using. This is WHP and a stock car was never dyno'd on this dyno, so it's hard to do a comparison. They later made 347WHP with different tuning. I don't think making 300WHP will be all that difficult with either this kit or the Harrop one, which uses the same 1320.
The Following 2 Users Say Thank You to xwd For This Useful Post:
civicdrivr (08-06-2015), DAEMANO (08-06-2015)
Old 08-06-2015, 08:32 PM   #308
sato
sato's Avatar
Drives: Dodge Patitas
I guess I probably know the answer to my question, but if I decided to add a header (or exhaust), it's best to re-tune. However, since this is a locked carb tune, does this mean I'd have to buy another ecutek license and spend $$$ on tuning?
Tempting, isn't it?
sato is offline   Reply With Quote
boost, byebye jackson racing, e-force, edelbrock, forced induction, supercharger
Trunk needs a bit of force to close..... Hachiroku14 Issues | Warranty | Recalls / TSB 30 06-19-2018 06:09 PM
X-Force 3" Exhaust mwjcyber Engine, Exhaust, Transmission 19 03-13-2017 02:55 PM
The force is strong with this one (2015 STi) blackhawkdown FR-S / BRZ vs.... 39 08-01-2014 01:26 AM
X force or Invidia N1 JakeG AUSTRALIA 8 01-18-2014 05:16 AM
G-force meter mikepaul21 Cosmetic Modification (Interior/Exterior/Lighting) 2 03-17-2013 02:24 PM
