Old 08-06-2015, 10:05 AM   #43
klearfade
klearfade's Avatar
Drives: Scion FRS
Now removing the top hat from the oem strut is what I am concerned about?
Any tips
Just here to learn.......and laugh
klearfade is offline   Reply With Quote
Old 08-06-2015, 11:07 AM   #44
Cockatoo
TALLY FT86
Cockatoo's Avatar
Drives: 2014 FR-S Monogram -- SBD Turbo --
Any tips
Dont do it if you dont have to....
But if you do, you MUST use a spring compressor.
Cockatoo is offline   Reply With Quote
Old 08-06-2015, 11:13 AM   #45
klearfade
klearfade's Avatar
Drives: Scion FRS
I actually just saw a great write up that shows how to remove the top hate with a hollow ratchet and a hex key....yayyyy
Sent from my LGLS996 using Tapatalk
Old 08-06-2015, 11:27 AM   #46
klearfade
klearfade's Avatar
Drives: Scion FRS
Super late
Originally Posted by hahaman86 View Post
Sorry to hear that happen I'm trying to get around to installing my kw's as well. I just absolutely clueless as to how to get the top hat off the stock strut. I borrowed a spring compressor from auto zone but have no idea how to use it. Any chance I could get some help? I've looked and haven't been really able to get a clear guide how to remove them.
lol little late but this helped as well
http://www.ft86club.com/forums/showthread.php?t=32414
Old 08-06-2015, 11:31 AM   #47
klearfade
klearfade's Avatar
Drives: Scion FRS
This helped for the top hat
Old 08-06-2015, 01:17 PM   #48
Cockatoo
TALLY FT86
Cockatoo's Avatar
I saw that before and totally forgot, that does look much easier
Old 12-07-2015, 03:13 PM   #49
Seth Hawkins
Seth Hawkins's Avatar
Drives: 2015 BRZ Limited
Rear Suspension Diagram with Torque Values
Do you know where I can find one of these diagrams for the rear suspension? I'm changing out the LCAs along with coilovers. I might change a few of the other components back there as well in the future. Having a diagram of the rear with the torque values would be really helpful. The 'Service Manual' that someone uploaded doesn't cover these parts. And I have yet to find a Chilton's or Hayne's for these cars.
Seth Hawkins is offline   Reply With Quote
Old 04-01-2016, 10:56 PM   #50
BigRips
Originally Posted by Buuurz View Post
Did my coils today. The back were a breeze, 45 minutes tops for both sides. The fronts...those damned endlinks...how does a one year old car have such seized up bolts? It took another 2 hours each side just for those bolts. They're now destroyed and need to be replaced. Blow torch and vice grips should be added to the list of tools needed. Great help though! Thanks guys
PB Blaster penetrating lubricant is what I used to break endlink nuts loose. Just spray wait 30 seconds and remove nut like normal.
BigRips is offline   Reply With Quote
Old 04-01-2016, 11:28 PM   #51
mpross
mpross's Avatar
Drives: 2015 Scion FRS
What is the definitive answer for front end links? You do need the adjustable? Or no?
Sent from my SAMSUNG-SM-G928A using Tapatalk
mpross is offline   Reply With Quote
Old 04-02-2016, 01:05 PM   #52
stockysnail
Just the tip
stockysnail's Avatar
If you are lowered over 1" or so vs stock then I think the adjustable front end links are recommended.
Old 04-05-2016, 09:00 PM   #53
Buuurz
Buuurz's Avatar
Drives: 2013 SWP Rocketbunny V2 BRZ
I'd recommend them. My car has been thrown out of alignment multiple times in just a few months.
Buuurz is offline   Reply With Quote
Old 06-12-2016, 03:43 PM   #54
WolF_RS
WolF_RS's Avatar
Drives: 2015 Ultramarine Scion FR-S (MT)
Installed Tein Street Flex, did anyone cut their rear carpeting to let the top dampers for the rear coils sit properly without pushing the carpeting out?
WolF_RS is offline   Reply With Quote
Old 10-03-2016, 07:57 PM   #55
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
I am probably gonna install Ten Flex Z very soon.
red mark line is where ride height adjustment i can make?
checked manual front B is 28mm and Rear B is 35mm
so i need to make 28mm and 35mm between collar for default setting?
I am trying to lower 1.2
thanks
Old 10-04-2016, 05:06 PM   #56
zc06_kisstherain
Drives: SWP BRZ
i am quite mechanic savy and did most work done on many cars and trying to install coilover today and these damm endlinks' hex was rust like shiiit and it got round off and cannot hex anymore. i used pb blaster torched and did not work before it got rounded.
i managed to remove driver side's endlink from sway bar not on strut!! lol
I am gonna buy adjustable endlinks but i am stuck on passenger side' endlink.
any idea to remove damm rusted endlink?
DG-5 Coilover harajukukei Suspension | Chassis | Brakes -- Sponsored by 949 Racing 17 06-27-2014 03:42 PM
NW Coilover Shootout DarrenDriven Northwest 14 07-24-2012 02:12 AM
Suspension Installation Warning!!!! Don@Accelerated Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 07-20-2012 06:44 PM
TRD parts installation manual Nardi330 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 05-21-2012 03:19 AM
