Old 06-12-2013, 03:50 AM   #15
swtfrs
swtfrs's Avatar
Drives: 2013 lava orange scion frs
I like the silencers in better.Ran for a few weeks without and you loose torque off idle.I installed the UEL and downpipe and tried both ways and I think it runs much stronger with silencers in and sounds real rumbly at start up and any time you hit the gas.It was a bit obnoxious with them out,but cool too!
Borla UEL,Borla downpipe cat delete,G-Reddy Evo3,Eibach sportline,AEM intake
swtfrs is offline   Reply With Quote
Old 06-19-2013, 01:18 AM   #16
IllusiveFRS
IllusiveFRS's Avatar
Drives: 13 Scion FRS, Asphalt
I highly recommend the Nameless downpipe(replaces overpipe version) with Helmholtz resonator(I also got the catted version) it makes the Greddy Evo3 sound amazing! lessens "drone" a bit. I also removed all trunk interior pieces down to bare metal and used some "hushmat"(like dynamat) under where the spare would be etc and it was amazing the difference in sound inside cab. point is there are many solutions to loudness inside cab, but nothing beats the beautiful sound of this exhaust.
13 FRS Asphalt
Jackson Racing Supercharged, Nameless Performance front pipe with cat and helmholtz resonator, Greddy EVO3 exhaust, tuned by Church Auto Testing. Cusco braces all around, KW V3 coilovers. Winmax brake pads with DBA rotors. Thank you CSG for all the useful help!
IllusiveFRS is offline   Reply With Quote
The Following User Says Thank You to IllusiveFRS For This Useful Post:
akahenry (09-07-2013)
Old 08-05-2015, 09:40 PM   #17
bryan767
bryan767's Avatar
Drives: 13' AVO Whiteout
Can someone take a picture of the silencers, I'm looking for replacements.
bryan767 is offline   Reply With Quote
Old 08-05-2015, 09:42 PM   #18
IllusiveFRS
Have you tried contacting Greddy to see if they can sell you replacements?
Sent from my SAMSUNG-SM-N910A using Tapatalk
13 FRS Asphalt
Old 08-06-2015, 03:18 PM   #19
bryan767
bryan767's Avatar
I decided to buy a vibrant ultra quiet resonator that I'm getting welded into the cat back. This way I don't have a restrictive ugly silencer.
Does anyone know of any resonated front pipes that fit the evo3 catback?
Old 08-13-2015, 12:58 AM   #20
IllusiveFRS
I used the Nameless Performance front pipe with highflow cat and helmholtz resonator, I found that it smoothed the exhaust note. It is still loud of course, but sounds amazing. I recommend using a bit of dynamat/hushmat/sound deadening stuff in the trunk to help with sound in cab. I removed trunk pieces and spare, and matted the whole floor. it helped quite a bit. hope this helps
13 FRS Asphalt
Old 08-13-2015, 09:31 AM   #21
bryan767
bryan767's Avatar
Great advice, I think I'll pick up some dynamat and do the trunk. I'm getting the resonator welded into my non resonated front pipe so I'm hoping it kills some of the drone. I watched a few exhaust note videos on before/after install and it really does seem to work. I'll post a video of my before/after this weekend.
I should mention I'm on a AVO UEL turbo kit, and the exhaust sounds soo mean. But certain rpms I can't take the drone lol.
The Following User Says Thank You to bryan767 For This Useful Post:
IllusiveFRS (08-20-2015)
Old 08-20-2015, 01:54 PM   #22
Mirageo
Drives: Subaru BRZ
Originally Posted by eddieEndo View Post
I finally got the silencers out!! Had to dremel two of the bolts off but THEYRE OFF!!
Silencers off review: LOUD!!!!! The interior drone doesn't bother me if you know the sweet spots of where the drone doesn't occur!! Definitely gives the car some BALLS!! and brings some of that familiar boxer rumble out!! VERY HAPPY and i think it's safe to say the silencers will not be going on ever again
I've had the evo3 silencers off from day one when I got it installed. You're right about that sweet spot!! It depends howuch pressure you're putting on the gas pedal 😂. I recently put on the HKS dual resonated front pipe. It reduced the drone substantially in the cabin and gave it some top end rumble. Look into it! It sounds even more aggressive. I commute 80 miles a day for work too haha
Mirageo is offline   Reply With Quote
Old 08-20-2015, 01:55 PM   #23
Mirageo
Drives: Subaru BRZ
Also I've loved the sound of the evo3.nice and deep when it's on idle but can be very loud when you want it to be
Old 08-20-2015, 08:32 PM   #24
Hawk77FT
Drives: GTS 86
Have the silencers on all the time...way to loud for me it just makes my ears bleed. I had HKS headers, with Ultimate racing front pipe and over pipe in 2.75" and f me...it was loud and the drone killed my ears. I have taken them off when I went on the dyno though.
Maybe I am just getting old!
Hawk77FT is offline   Reply With Quote
Old 08-20-2015, 10:07 PM   #25
bryan767
bryan767's Avatar
I know the feeling, and I'm UEL turbo. Still drones so much. I ended up getting a vibrant 1141 welded into my catless/nonresonated front pipe. Next I'm getting a magnaflow shorty race muffler welded into the catback. It should produce a much lower dB.
Currently I'm running at 75-78dB incabin at 60-70mph. Was upper 80s without the resonator. I'm hoping for mid/low 60s with the new muffler, which will be a lot more daily driver friendly.
Old 08-20-2015, 10:10 PM   #26
Hawk77FT
Drives: GTS 86
My front pipe is cated atm. Where did you weld the vibrant 1141 on the front pipe..as in which end? Did you have enough room? Pics? I need to do the same thing
Sent from my HTC_0P6B using Tapatalk
Old 08-20-2015, 10:39 PM   #27
bryan767
bryan767's Avatar
I'll get pics when it's on the lift but it's where the front and mid pipe connect. I actually had them move the flange up. It's technically right below the shifter as this was the only place big enough to fit the large resonator.
Which is better ARK DTS, Grip Vs Greddy Evo3 Vs N1 ? TRD_86 Engine, Exhaust, Transmission 21 03-20-2013 02:03 PM
***GREDDY EVO3 EXHAUST ONLY ONE AVAILABLE!*** genometuning Engine, Exhaust, Bolt-Ons 9 11-12-2012 12:20 PM
Greddy EVO3 or Invidia N1 gmanculb Engine, Exhaust, Transmission 9 10-23-2012 09:40 PM
GReddy evo3 possibly FS Toyobaru808 Hawaii 2 10-21-2012 10:39 PM
GReddy Evo3 Exhaust price available mikeg7827 Engine, Exhaust, Transmission 5 08-03-2012 03:09 PM
