Old 06-29-2015, 02:49 AM   #43
Dr. BRZ
Dr. BRZ's Avatar
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
is an 02 space senor necessary?
i dont a CEL to come on.
Dr. BRZ is offline   Reply With Quote
Old 06-29-2015, 01:36 PM   #44
kch
Senior Misanthrope
kch's Avatar
An O2 spacer can in some cases prevent a CEL, but it is not guaranteed. The only way to avoid a CEL for 100% sure is with a proper tune, and you really should be getting a tune with a catless header anyways.
Old 06-29-2015, 02:54 PM   #45
Dr. BRZ
Dr. BRZ's Avatar
Gotcha! So it's a 50/50 shot. I'm down for a tune but the problem is I live in boring oklahoma! There are no tuners, I have to travel to Dallas for the closest tune.
Old 06-29-2015, 02:59 PM   #46
kch
Senior Misanthrope
kch's Avatar
Many excellent tuners can do so remotely (moto-east, delicious, etc) if you want ecutek. Another option is the openflash tablet.
Of course, the absolute best option is always a dyno tune, but like you said, that's not always easy.
Old 08-05-2015, 07:16 PM   #47
rawbeeast
Drives: 2015 Asphalt FR-S
Bringing this back up cause I'm having problems with my Tomei UEL and OP.
Just recently installed it, with new gaskets. the headers came together not sure if you guys had to put it together, but I kinda figured that it would be set to go and put on so that's what I did. everything is bolted down tight from block to headers, headers to overpipe and overpipe to front pipe.
Now when starting the vehicle it sounded very lovely, love the rumble. gave it couple revs before putting back on plates just to check if I had any leaks, and it sounded just fine.
car is on ground afterwards and gave it a test drive on the freeway, now what I don't get is that, while driving and in gear while accelerating I would hear a slight leak/bleed... 😪
I haven't done any water soap or shop vac trouble shoot.. I would've if I heard the leak in idle, while rev'ing.. someone please help, cause the noise is driving me crazy..
rawbeeast is offline   Reply With Quote
Old 08-05-2015, 07:42 PM   #48
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
I have a tsudo uel header and I have what sounds like air streaming/flowing/hissing after installing mine. I read that it's from the thinner metal of the header piping (compared to oem) and no heat shield which results in you actually hearing exhaust flowing through piping. Not sure if we're talking about the same sound here though.
B-R-Z is offline   Reply With Quote
Old 08-05-2015, 07:59 PM   #49
rawbeeast
it's hard to explain, even through videos its hard to hear, it sounds like I'm boosted.. lols
Old 08-05-2015, 08:18 PM   #50
ajcarson11
Drives: 2013 Subaru BRZ Limited (Black)
Does it sound a bit like sand spilling into the pipe? kind of a gritty, almost raspy (more than airy) sound? If so i've got that too... and based upon responses around here it is normal. You should only really hear it while accelerating, not during idle. I think it is just the way it is!
ajcarson11 is offline   Reply With Quote
The Following User Says Thank You to ajcarson11 For This Useful Post:
rawbeeast (08-05-2015)
Old 08-05-2015, 08:56 PM   #51
B-R-Z
B-R-Z's Avatar
Yes only when accelerating it sounds like air spewing out kinda, I think you're fine.
The Following User Says Thank You to B-R-Z For This Useful Post:
Old 08-05-2015, 09:40 PM   #52
rawbeeast
could it happen to be from where the headers joint together ? where you can adjust ?
blahhhhhh I am on stock exhaust so yes I hear my headers more than anything else in the damn car, hopefully when I pick up my expreme test pipe the sound will overcome it lols! thanks you so much bro for your feedback.
Old 11-01-2015, 07:05 PM   #53
vvtlift
vvtlift's Avatar
Drives: 2015 BRZ
How to tighten the near impossible bolt on header tomei uel;
Flex head ratcheting wrench with adjustable wrench.
vvtlift is offline   Reply With Quote
Old 11-05-2015, 05:04 PM   #54
hide
Drives: 2014 GT86
I had the Borla UEL with stock exhaust and this noise was louder than the rest of the car but it is definitely reduced or at least hidden by a catted resonated Milltek exhaust. It is still quite loud though.
hide is offline   Reply With Quote
The Following User Says Thank You to hide For This Useful Post:
lakestreet (11-09-2015)
Old 01-23-2016, 01:04 PM   #55
KoolBRZ
KoolBRZ's Avatar
Drives: Silver 2013 BRZ Ltd Auto 45,000 mi
If you can't smell it, you're not leaking, it's just the sound of the pipes. The header to over pipe connection is the usual suspect, but you will smell it if it's leaking.
If I say yes, will that make you think I understand?
KoolBRZ is offline   Reply With Quote
Old 02-22-2016, 03:12 PM   #56
zkahle
zkahle's Avatar
Drives: 2013 Scion FRS Asphalt
Hey guys so I installed my Tomei UEL's last weekend. Two days later, my CEL came on as I am waiting for my Open Flash to arrive. A day after that I started noticing my car would kinda jerk when decelerating at exactly 10mph. The issue persists even when I am not using the brakes, however it does not occur when the car is thrown into neutral and allowed to decelerate. What could be the cause of the jerking motion and will my tune with the OFT possibly fix it? My buddy thinks the car is jerking because my car is running lean without the proper tune. Also here is a sound clip of the set up with my Berk muffler delete. Pure Eargasm.
[ame="https://www.youtube.com/watch?v=EgXLgRx0gmA"]Tomei UEL Header and Berk Muffler Delete - Scion FRS, BRZ GT86 - YouTube[/ame]
Hook Em'
zkahle is offline   Reply With Quote
Evasive Tomei Header Group Buy Evasive Motorsports Groupbuys 424 08-05-2018 12:55 PM
*Groupbuy: Invidia N1 and Q300 Cat-Back Exhausts (SS tips, T.I. tips) -fteightysix* 86SPEED Groupbuys 74 11-09-2016 01:45 PM
Quick tips for Remote Start installation trueno86power DIY (Do-It-Yourself) Guides 12 12-07-2014 03:47 PM
Tomei Exhaust with Tomei Straight Pipe leech Engine, Exhaust, Transmission 10 01-07-2014 10:42 AM
FS: Tomei UEL Header (WRX) [deleted] Miscellaneous 0 03-19-2013 09:58 PM
