Old 08-04-2015, 09:45 PM   #12433
iarefluffy
iarefluffy's Avatar
Drives: CWP series blue brz
Originally Posted by kch View Post
New, wider, and stickier tires. Michelin PSS 225/45/17 on stock wheels.
Do you have spacers? Are those wheels the stock series.blue ones?
Sent from brick
iarefluffy is offline   Reply With Quote
Old 08-04-2015, 09:49 PM   #12434
kch
Senior Misanthrope
kch's Avatar
Sent from brick
Stock suspension, stock series.blue wheels (same specs as normal), no spacers.
Old 08-05-2015, 08:32 AM   #12435
Lebby83
Drives: 2019 BRZ, 2016 Touareg
[/QUOTE]
Need pictures of these on the car!
Rob
2019 BRZ Limited Sport
2016 VW Touareg TDI
Lebby83 is offline   Reply With Quote
Old 08-05-2015, 09:21 AM   #12436
s30series
Drives: 2015 BRZ Series.Blue
Sent from brick
How does it feel?
I've got a series.blue and I am keeping stock wheels....my stock tires are worn down to like 3/32nds, I'm about to buy some RS3s for street/track.
I can decide on 215 or 225. Is it a big difference? It does add weight. It does had sidewall height which equals tire roll....I just cant decide if those cons outweigh the plus of looks and obviously more meat on the ground
Also can you please take a side shot of the car near ground level so I can see what it looks like please?
I say all this, but the RS3's are only 1lb more per tire (spec sheet) for 225 vs 215.......hmmmmmmm now I'm just concerned about tire roll
s30series is offline   Reply With Quote
Old 08-05-2015, 12:34 PM   #12437
kch
Senior Misanthrope
kch's Avatar
Originally Posted by s30series View Post
How does it feel?
I obviously haven't tracked or anything yet. First impressions are the initial turn-in is a bit softer. Massive grip, but I'm not sure how much of that is the better rubber and how much is the width.
The sidewall is only ~4.4mm taller than stock. It's not a huge difference.
Old 08-05-2015, 12:45 PM   #12438
PERRIN_Chris
Drives: 2014 Subaru BRZ
Send a message via AIM to PERRIN_Chris
Wow, your car looks great! Maybe I should get those side skirts one of these days!
PERRIN_Chris is offline   Reply With Quote
The Following User Says Thank You to PERRIN_Chris For This Useful Post:
kch (08-05-2015)
Old 08-05-2015, 01:10 PM   #12439
kch
Senior Misanthrope
kch's Avatar
Thanks! The skirts look good but make jacking up the car a royal pain. I have to drive up on 2x4s to get it on a local shop's 2-post lift.
Old 08-05-2015, 01:30 PM   #12440
PERRIN_Chris
Are you using a low profile jack? You're running stock height right?
Old 08-05-2015, 01:39 PM   #12441
kch
Senior Misanthrope
kch's Avatar
Stock ride height. The main problem is with this particular shop's lift. I can jack up the car just fine at home with a low profile, but tech days with the lift are a little more difficult. No matter how we position the arms, they end up pressing on and bending the sti skirts when the car's up. Everything goes back to where it was afterwards, but it's still scary seeing them all bent.
Old 08-05-2015, 01:51 PM   #12442
echo419
echo419's Avatar
Drives: 2014 BRZ Limited
damn I should have gotten white.
just put down some small pieces of wood to drive up on.
Old 08-05-2015, 01:54 PM   #12443
kch
Senior Misanthrope
kch's Avatar
Yeah, but that only helps me get the arms under. The problem is the arms press on the skirts when the car is up on the lift. Only way to fix that would be to put pieces of wood on the lifting pads, and I'm not that brave/stupid.
Old 08-05-2015, 02:11 PM   #12444
PERRIN_Chris
Sorry, I didn't read your original post, that makes sense. They must have one of those really high lifts! Sounds scary, my skirts got messed up on my BMW from a lift like that, I think they were made out of a different material though.
Old 08-05-2015, 03:23 PM   #12445
kch
Senior Misanthrope
kch's Avatar
Forgot to mention earlier, but it sounds great, too, thanks to y'alls catback (and other bits, of course)
Skip to 0:21
[ame="https://www.youtube.com/watch?v=VnEYvkiW5k0&t=21s"]BRZ w/ JDL UEL & Perrin resonated drive by - YouTube[/ame]
The Following 8 Users Say Thank You to kch For This Useful Post:
austinbrz (08-06-2015), DocWalt (08-06-2015), echo419 (08-05-2015), Husker BRZ (08-05-2015), MJones_RB (08-06-2015), PERRIN_Chris (08-05-2015), sprintertrueno86 (08-05-2015), TurtleFace (08-06-2015)
Old 08-05-2015, 03:45 PM   #12446
echo419
echo419's Avatar
very nice @kch
The Following User Says Thank You to echo419 For This Useful Post:
kch (08-05-2015)
