#43 |
Sarcastic SOB
Hopefully final update: My wife found a gasket under the couch that looks like the missing one from the male attachment to the sandwich plate to the male AN- fitting. Somehow the vacuum missed it!
So, with the fittings lined with Teflon tape at both ends, and now both gaskets, no oil leaks! The plugs for the sensors on the sandwich plate needed a ton of Teflon tape but they seem to be working fine as well! I do recommend the CX kit as a bang for the buck product, but make sure you use a ton of Teflon tape.
| The Following User Says Thank You to wbradley For This Useful Post: | DAEMANO (08-04-2015) |
#44 |
Drives: 2013 GBS BRZ Limited
FWIW - I dont use Teflon tape on engines any more at all. It is banned for anything other than water pipes.
Once you find a small piece of Teflon tape stuck down in an oil gallery leading to a failed main bearing, you might feel the same. I use loctite 567 now for all things engine related. |
#45 | |
Sarcastic SOB
| The Following User Says Thank You to wbradley For This Useful Post: | stugray (08-04-2015) |
| Heads up - Oil sandwich plate | protpibe | Engine, Exhaust, Transmission | 37 | 04-28-2017 04:15 PM |
| WTB: Quality Oil Cooler w/ thermo sandwich plate for NA application | AyJay | Want-To-Buy Requests | 11 | 02-20-2015 10:16 AM |
| Oil sandwich plate with TRD intake? | wootwoot | Engine, Exhaust, Transmission | 18 | 06-18-2014 10:17 PM |
| Greddy Sandwich Plate 12002802 | Captain Snooze | Australia Classifieds | 2 | 07-09-2013 07:41 AM |
| Casting Defect Sandwich Plate | Dezoris | Issues | Warranty | Recalls / TSB | 1 | 01-22-2013 03:04 PM |
