Old 04-29-2015, 08:11 PM   #57
Haeb
Haeb's Avatar
Drives: 2014 Scion FR-S Monogram Series
Originally Posted by churchx View Post
Wild guess .. depending on how thorough tests are .. how do you guys think - can catless header + custom frontpipe with 2 cats slip through for less thorough checks, that simply will look up how much cats car should have without inquiring where exactly they are mounted?
Imho if it MAY slip through 85% cases, it's good enough. For those less lucky 15% there is option of bolting back stock one.
I have no clue how really tests are performed and how thorough they are over in CA though, hence just an mad idea. But if it will work .. replacing just frontpipe should be easier then regular remounting of headers, no?
For lulz. If catback is legal, so do probably this.
The visual inspections are quite thorough, and if theres a question about somethings legality - its almost certainly going to fail the test. Any type of modification throws up red flags, and since the state routinely modifies cars, and then sends them through as an undercover car, licenses are on the line for both tech and station. Only takes one mistake to cost them big...so they tend to be hyper critical. That said, the test for our cars is mainly visual, and relies heavily on the cars computer to pass or fail its self tests. So if modifications were made, and made in such a way that the computer is tricked into thinking the set up is still stock and in working order, and the inspector is dating your sister (or something along those lines), then you have a shot at passing. Otherwise....keep those stock parts for smog time!!!!
Haeb is offline   Reply With Quote
Old 04-29-2015, 11:28 PM   #58
cslntuee
Drives: Subaru BRZ Limited
Originally Posted by mav1178 View Post
FALSE FALSE FALSE.
If you buy a new car from out of state, you smog when you bring the car in, and the normal 6 year exemption period applies for all cars less than 6 model years old.
-alex
Did this post real?
http://www.ft86club.com/forums/showp...3&postcount=45
CA start to rolling the SMOKE Test?
cslntuee is offline   Reply With Quote
Old 04-30-2015, 12:21 AM   #59
aegisdrgn
aegisdrgn's Avatar
Drives: Scion FR-S 10 Series #2263
Originally Posted by cslntuee View Post
Did this post real?
Man, that would blow so hard, for many people...
Back to OT, Jackson Racing Supercharger is CARB certified.
http://jacksonracing.com/shop/superc...harger-system/
aegisdrgn is offline   Reply With Quote
The Following User Says Thank You to aegisdrgn For This Useful Post:
Bonburner (04-30-2015)
Old 04-30-2015, 01:08 AM   #60
Hyper4mance2k
Alexandrino_Auto
Hyper4mance2k's Avatar
Drives: series.Blue
Just like DUI check points, they are voluntary. As persuasive as cali law enforcement can be, you do not have to take the roadside smog tests.
The Shadetree Project: I turn wrenches
Hyper4mance2k is offline   Reply With Quote
Old 04-30-2015, 01:43 AM   #61
Kostamojen
Thise have been around awhile. I saw one once awhile ago, but they were meant for targeting old clunkers and such. I would't even worry about it.
Old 04-30-2015, 02:26 AM   #62
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
i am honestly amazed .. i never thought i'd see the day lol
technically speaking you need to buy the pretuned ecu btw
"... ecu upgrade without user adjustments, ..."
http://arb.ca.gov/msprog/aftermkt/de...eo/D-700-2.pdf
Old 04-30-2015, 03:46 AM   #63
churchx
churchx's Avatar
Drives: 2014 GT86
It almost seems that future CA-legal performance upgrades for twins will lay only with forced induction only, such as with few SC kits like this or Cossworth's, NA/headers/tune path will slowly close.
Old 05-02-2015, 12:54 AM   #64
cslntuee
Is there any aftermarket catted manifold with heat shield or
can installed with stock heat shield?
I understand this is still illegal.
However, it will have more chance to pass visual inspections @CA.
Thanks.
Old 05-02-2015, 10:54 AM   #65
churchx
churchx's Avatar
Drives: 2014 GT86
Hmm, try these. Never head of that feat mentioned for any other header, and haven't checked for these, if true as claimed, but supposedly:
Originally Posted by aFe POWER
Originally Posted by Bonburner
any idea if the stock manifold's cover fits (it is covered right?) on this header - that way it looks stock lol
and if it does the weight?
Yes the covers do fit, but I do not have the weight with the covers on though.
Covers? It's not about ones that are on stock very header (doubt a bit if they can be mounted on any other header), but about engine underside protection plate, right?
Both the underside and actual stock exhaust manifold covers fit on our header.
cslntuee (05-02-2015)
Old 05-09-2015, 02:54 PM   #66
cslntuee
Did you think aftermarket catted manifold with heat shield can pass
the smoke test in CA?
I am thinking buying this header.
http://www.ft86club.com/forums/showthread.php?t=87055
Thanks.
Old 05-12-2015, 04:11 PM   #67
Haeb
Haeb's Avatar
Thanks.
The smoke test is a visual inspection for visible smoke in the exhaust. If theres smoke in the exhaust the catalyst is the least of your worries - your looking at at least valve stem seals, if not rings, engine etc with smoke. As for that header / cat setup your looking at, it will fail a California smog inspection - Available with 48 state legal cats or non-catted (CA is not one of those 48 states lol). Smog techs in CA will be looking at the catalyst, they will notice it is aftermarket right away, and they will notice it does NOT have the CA required info on the catalyst.....namely an Executive Order number that shows it is a legal replacement. If you buy it, save the OE one.....you'll need it in a couple years, or if you sell the car.
The Following User Says Thank You to Haeb For This Useful Post:
cslntuee (05-13-2015)
Old 07-30-2015, 06:02 PM   #68
plynnjr92
plynnjr92's Avatar
Drives: 2015 Halo FR-S 6-Speed
Made the biggest discovery today.. a CARB-legal turbo kit!!! http://store.worksmotorsports.com/mo...tCode=142.212C
+90 crank hp @12psi keeping both cats. Comes out to around 250whp, not bad
Sent from my Samsung Galaxy S5 using Tapatalk
plynnjr92 is offline   Reply With Quote
Old 08-04-2015, 02:17 PM   #69
WORKS
WORKS's Avatar
Drives: WORKS CARB Legal Turbo BRZ
Thanks for the shoutout @plynnjr92. We actually offer two CARB-compliant turbo kits: our Stage 1 kit, which boosts to ~7psi, and our Stage 2, which adds an air-to-liquid intercooler and boosts to ~12psi.
WORKS FR-S/BRZ Stage 1 Turbo Kit - CARB Compliant
WORKS FR-S/BRZ Stage 2 Turbo Kit - CARB Compliant
Both are fully CARB compliant and therefore pass SMOG without issue. Feel free to reach out to us with any questions.
WORKS is offline   Reply With Quote
The Following 2 Users Say Thank You to WORKS For This Useful Post:
Lonewolf (12-06-2020), plynnjr92 (08-04-2015)
Old 04-03-2016, 11:58 AM   #70
yamrossi
Drives: Saving for a BRZ
Software tuning will probably pass smog check too. Since there is no way for the tech to catch that.
Sent from my Nexus 10 using Tapatalk
yamrossi is offline   Reply With Quote
Recent Thread List Anthony Site Announcements / Questions / Issues 0 07-21-2013 10:24 AM
Any of the FI kits CARB approved yet? RYU Forced Induction 27 05-05-2013 10:51 PM
Carb legal intakes EN2_Squirrel Engine, Exhaust, Transmission 2 04-18-2013 05:59 PM
Parts.com = Master Limited BRZ > FR-S Thread? dkenne2586 Cosmetic Modification (Interior/Exterior/Lighting) 1 03-12-2013 12:44 AM
B2autodesigns Master exhaust thread. Invidia,Takeda, Berk, Magnaflow and more b2autodesigns Engine, Exhaust, Bolt-Ons 29 01-02-2013 10:44 AM
