Old 08-01-2015, 10:23 AM   #239
alamando
Drives: 2014 86 GT
Originally Posted by alamando View Post
thanks for your all your work Wayno.
Is the A01G E85 tune on the first post for MT, AT or both?
NM just realised all G roms are MT
alamando is offline   Reply With Quote
Old 08-02-2015, 07:15 AM   #240
alamando
Drives: 2014 86 GT
Flashed the v80 A01G E85 rom with EL AVCS tables on my stock 86
here's a 3rd gear pull
http://www.datazap.me/u/almando/oft-...om=16350-16482
rich after 3.8v but ok elsewhere? Should I use the type 2 "AT2" MAF scale?
Old 08-02-2015, 09:26 PM   #241
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
No, don't do that.
Multiply 3.91 and above by 0.99.
That will get you close to 12.0
With headers it likely wouldn't run rich like that, so when you get headers, go back to my default MAF scale.
Old 08-02-2015, 09:52 PM   #242
alamando
Drives: 2014 86 GT
Awesome. Thanks Wayno
Sent from my SM-G900I using Tapatalk
Old 08-03-2015, 02:24 AM   #243
Wayno
Wayno's Avatar
Good on your for having a go yourself. Fellow Queenslander.
Old 08-03-2015, 11:18 AM   #244
alamando
Drives: 2014 86 GT
Here's a pull with the MAF changes.
For some reason it is richer everywhere.
Did I not give it long enough to learn fuel trims properly?
http://datazap.me/u/almando/e85-oft-...zoom=3722-3916
Old 08-03-2015, 01:17 PM   #245
mid_life_crisis
Drives: FR-S 10 #103 AT
@Wayno @steve99
I'm curious how the new values in the O2 sensor scale were determined. Not only were the values changed, the scale itself was significantly altered. I'm mostly curious about the reference scale changes.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
Old 08-03-2015, 03:18 PM   #246
phrosty
Originally Posted by mid_life_crisis View Post
@Wayno @steve99
Pretty sure @Wayno is using @ztan's scaling, which is described here:
http://www.ft86club.com/forums/showthread.php?t=82875
phrosty is offline   Reply With Quote
Old 08-03-2015, 06:12 PM   #247
steve99
Drives: FT86
@Wayno @steve99
yes as above ztan rescaled stock o2 sensor using an aftermarket widenband as the reference
Old 08-03-2015, 07:21 PM   #248
Wayno
Wayno's Avatar
You need to wait until your LTFT is under -6 in OL. Basically that whole AFR curve will go up 0.9.
You must have an extremely high E content at your station (Doonan, Hearvey Bay, Gladstone?). For my testing all year I've had LTFT of 0 +- 1 with that scale on United E85 from Bald Hills.
Old 08-03-2015, 11:22 PM   #249
alamando
Drives: 2014 86 GT
Thanks Wayno. Will wait till the trims improve before I do my next pull. Getting my E85 at Doonan.
Loving the power gains btw, do headers get you much more? Do you recommend EL or UEL?
Old 08-04-2015, 02:44 AM   #250
Wayno
Wayno's Avatar
See Australian dyno thread for what uel vs el looks like on oft.
Old 08-04-2015, 03:49 AM   #251
steve99
Drives: FT86
below is a reasonable representation of where the differences are that was with stock tune, with tune it just all moves up maybe 10hp
another comparision here
http://blog.vittuned.com/just-a-coup...-vs-tomei-uel/
thats on USA petrol which is far better than ours. our crap petrol newters the gains you get, hence great results with E85
Old 08-04-2015, 08:56 AM   #252
mid_life_crisis
All right, I'm confused again.
I'm looking at the changed tables and I find the one for requested torque. The two axis are RPM and some representation of the ECU requested torque. The result in the field is the required Throttle Angle.
What has me scratching my head is the Requested Torque. There are multiple columns with the same value?!?!? Which one does the ECU use? It makes no sense to me. Can someone explain this set of values? Remember, this is not the first row of data, it's the lookup value across the top.
This isn't a change Wayno made, it's in the Openflash tune as well.
[Selection1D]
0.0 0.0 0.0 0.0 0.0 0.1 0.1 0.2 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 0.9 1.0 1.0 1.0 1.0
Help uploading 2.06 tunes to OFT Jimmy817 Software Tuning 3 12-28-2014 09:06 PM
Custom Az Tunes Juggles Arizona 13 11-08-2014 10:15 AM
EcuTek Tunes Rio Engine, Exhaust, Transmission 1 04-29-2014 12:10 AM
How long until *other tunes? ScionFrsFan Engine, Exhaust, Transmission 61 12-07-2012 05:34 PM
Speedhunters - TRD TUNES THE 86 quik1987 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 69 05-22-2012 04:26 PM
