Old 07-29-2015, 02:52 PM   #15
nunonuna
nunonuna's Avatar
Originally Posted by itsjustdavep View Post
Oh god too many different explanations. Brain meltdown imminent.
I have similar noise too.
I check for leak, but found no leak.
Some says its normal with thinner material used for aftermarket exhaust, but CSG mike's comment makes me confused too.
So I'm gonna take off header this weekend to take a look at the gasket.
nunonuna is offline   Reply With Quote
Old 07-29-2015, 04:56 PM   #16
kch
Senior Misanthrope
kch's Avatar
I get the whooshing sound with my JDL UEL. I pressure-tested by putting a shop vac exhaust up one tailpipe, plugging the other, and spraying soapy water on all connections. No leaks. Still whooshing.
Old 07-29-2015, 05:07 PM   #17
APEXIT53
Drives: 17 Camaro SS
Question for ya.
Is this header supposed to sound a bit different under throttle? I've got my burbles. But also this sound of... almost like air escaping.
But I have no exhaust leaks. After I installed I went to my dealership and they double checked my work said I was good to go.
I get the same issue when im next to buildings. its odd I cant find a leak at all but I can hear something. Could be the intake I have but no exhaust leak
APEXIT53 is offline   Reply With Quote
Old 07-29-2015, 06:32 PM   #18
CSG Mike
CSG Mike's Avatar
I think the confusion here is that we have inconsistent/different descriptions for the sound. Deleting BOTH cats will result in a tinny, high pitched sound, but not a wooshing, "air leaking" sound.
Check the areas around the gaskets for leaks. If there are none, then don't worry about it
Old 07-31-2015, 11:26 AM   #19
ANTLAY
Drives: 2013 FR-S in Whiteout
fwiw, goto my thread in this section.. its gotta be normal at this point, seems like everyone has a fairly similar description, mine sounds just like what most here are saying too.
ANTLAY is offline   Reply With Quote
Old 08-01-2015, 08:07 AM   #20
Chad11491
Drives: 85.5 Porsche 944, '15 mustang GT PP
I have the same noise. I've come to accept it's the way it's supposed to sound. I took the header off and replaced all gaskets with grimmspeed gaskets and even used copper gasket maker around the gaskets and tightened down to spec. I only hear the noise when in close proximity to something, and did the water and soap test. No bubbles, and felt no leak before OR after. So I'm guessing it's just the thinner metal, and sound of the air rushing through the pipes.
Chad11491 is offline   Reply With Quote
Old 08-01-2015, 09:14 AM   #21
vroom4
I think it's a leak at the slip joint. That's where my tomei leaks
vroom4 is offline   Reply With Quote
Old 08-01-2015, 09:17 AM   #22
itsjustdavep
itsjustdavep's Avatar
Drives: Asphalt Scion FR-S
That actually dawned on me last night.. any ideas on how to shut that down
2013 Asphalt HRI Tuned-K&N DropIn-Tomei UEL-Tomei OP-Invidia FP-Nameless Muffled Trackpipe...and corn
itsjustdavep is offline   Reply With Quote
Old 08-02-2015, 10:11 PM   #23
APEXIT53
Could be, I also thought about the slip joint as well but there is no evidence of a leak there. Oh well just have to live with it lol
Old 08-03-2015, 01:53 AM   #24
fantah
fantah's Avatar
Drives: 2013 BRZ Premium Black
its normal, had the same sound till it broke in.
fantah is offline   Reply With Quote
Old 08-03-2015, 06:58 AM   #25
itsjustdavep
How long was "break in"
Old 08-03-2015, 07:11 AM   #26
Chad11491
Mines been making the sound for like 300 miles/3 weeks now.
Old 08-03-2015, 10:48 AM   #27
86Tony
Drives: 2015 AOZORA EDITION
I have the same sound checked for lakes more then once and still have the noise
86Tony is offline   Reply With Quote
Old 08-05-2015, 06:15 AM   #28
ANTLAY
Just curious,those that also have the sound,what op/fp are yall running?
Tomei 60r + cash for Tomei type 80. SavingManuals Canada Classifieds 2 05-08-2015 11:06 AM
Trade: tomei 60r for tomei 60s Cole Canada Classifieds 5 04-13-2015 02:17 PM
WTB Tomei Type 80, Tomei UEL headers Justin91M Want-To-Buy Requests 1 12-19-2014 11:42 AM
Tomei Type 60R trade for Tomei Type 80? Krovi Engine, Exhaust, Bolt-Ons 5 06-11-2014 07:24 PM
Tomei Exhaust with Tomei Straight Pipe leech Engine, Exhaust, Transmission 10 01-07-2014 10:42 AM
