#351 |
Drives: FT86
Do you mean Direct Injector Seal Failure ?
This was caused by transient ignition retard mapping error in early roms from factory you had to drive hard and shift at redline rpm to cause it early rom like 700x, 900x A00x had the problem was fixed in factory rom A01x and later rom all OFT roms have the fix as do most other tuners roms |
#352 |
Drives: 2010 MS3
I'm planning to pick up a OFT and run 91 tune. I only have the k&n drop in and a track pipe. That's it in terms of power mods.
Is the 91 tune pretty conservative? I do a lot of hard driving at the track and canyon. Thank you! |
#353 | |
Drives: FT86
Knock Correction for 91 Octane USA fuels http://www.ft86club.com/forums/showt...47#post2216047 |
| The Following User Says Thank You to steve99 For This Useful Post: | JS + BRZ (07-21-2015) |
#354 | |
Drives: 2010 MS3
#355 |
Drives: Whiteout FR-S
Received the P0462 code again after using E85. This time I go the full display of check engine, slip light, and ABS. Cleared code and will see if it comes up again.
2013 Ford Focus St
2013 Scion FR-S 2007 Honda Civic Si 2003 Acura RSX Type-S 1998 Ford Escort ZX2 |
#356 |
Drives: FT86
Its likely its an intermittent hardware fault with fuel sender in tank or the connection to sender at tank, might be worth checking\cleaning connector at tank
| The Following User Says Thank You to steve99 For This Useful Post: | Tt3Sheppard (07-22-2015) |
#357 |
I got this after a particularly hard start on E85 one morning. From what I could tell, driveability was not affected though I couldn't enter cruise control and it didn't go away without forcing a clear with OFT.
#358 |
Drives: FT86
i wonder if its battery volts related, ie particularly long hard start dropped battery volts low enough and long enough to cause ecu to see reading from fuel sensor out of tolrance. and set cel code.
#359 |
Drives: 2015 Scion FR-S
I've gotten the same thing, p0462. Its been 5 days since I cleared the code and I went with a different fuel brand like Shell.
#360 |
Drives: Ultramarine FRS, (MILA)
im a noob
really stupid question but i hope someone willl answer and not be to big of a **** haha.
SO do u have to have open flash headers to do the stage 2 tune with the open flash tablet or is it compatible with all aftermarket parts? |
#361 |
Drives: Asphalt FR-S MT
Open Flash Tablet - OFT TIPS Trick’s & FAQ
The stage 2 tune is optimized for the open flash header. However you can still use it with a Borla header or a tomie header for example. Stage 2 is mainly meant for an after marker header as that's the biggest restriction in our exhaust. So even if you replace the mid pipe and the rest of the exhaust and the header remains stock you'll need to use stage 1
| The Following User Says Thank You to Kronos For This Useful Post: | Deagle50 (07-29-2015) |
#362 |
Go Big Red!!
Drives: 2013 SSM BRZ Limited
So since I upgraded my OFT last week to the latest update every time I have it plugged in to the car it will run for a minute at most then freeze on the diagnostic page. Then I can only turn it back on after I turn off the car, and once I turn it back on and select diagnostic it freezes again. I'm at a loss as what to do next, I have tried to re-load the newest file and I still have the same issue.
Any help would be greatly appreciated! Thanks! |
#363 | |
Drives: FT86
#364 |
Drives: wrb brz
First time user here loving the new tune but curious to try out that tune to make the exchaust pop...downloaded the rom raider although i cant seem to figure how to upload a stock map to begin editing.
Ive looked through the youtube vids but none seem to help the maps seem to already be there in the vids. thanks for the help |
| WTB: Open Flash Tablet | TOZER | Canada Classifieds | 3 | 07-05-2015 07:13 PM |
| Open Flash Header & Open Flash Tablet | Calavera | Engine, Exhaust, Bolt-Ons | 9 | 05-11-2015 08:27 PM |
| FS: open flash headers / open flash tablet - SOLD | alanhung85 | Canada Classifieds | 12 | 02-10-2015 02:08 PM |
| FS: Open Flash Tablet (OFT) | mex2309 | Engine, Exhaust, Bolt-Ons | 1 | 10-29-2014 02:49 PM |
| Open flash tablet. | cooldandani | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 02-22-2014 07:14 PM |
