MisterSheep
Old 07-31-2015, 12:06 PM   #1
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
First Batch V.S. Second Batch of 2013's
We all know when there is a new car there are faults in the first couple of cars sold. My question to anyone who knows, what month/year should you not have to worry about your 2013 hitting the dust anytime soon?
EX: This car is a "2013" but was most likely released and manufactured in late 2012 correct?
If there was one manufactured in said 6/2013 would it be a "lemon" per se?
Instagram: trevor.parque
thecarfilmer (05-07-2016)
Old 07-31-2015, 12:36 PM   #2
FirestormFRS
I bought mine in May of 2012. First batch off the boat and have had the taillights replaced under warranty. That's it. Nothing else. Notta. No problems. No breakdowns. Nothing to report.
43k miles later with 4k of that FI and still waiting for the thing to break.
FirestormFRS is offline   Reply With Quote
The Following 7 Users Say Thank You to FirestormFRS For This Useful Post:
BlueDubbinTDI (07-31-2015), FRSBRZGT86FAN (08-01-2015), hmong337 (07-31-2015), Itsjusdame (08-09-2015), mr. slim (08-01-2015), scioneric (08-06-2015), Tcoat (07-31-2015)
Old 07-31-2015, 12:38 PM   #3
MisterSheep
Killed Scion
Not worried with the FI? I'm on the fence, I have 24k miles on my 2013 and don't want to mod it due to the fact that it's a first year car of a whole new style of car and I don't want to loose my warranty.
Old 07-31-2015, 12:48 PM   #4
FirestormFRS
Not concerned. I have 3 other vehicles that I can drive if something happens. I can assume the risk of the FI.
Old 07-31-2015, 12:53 PM   #5
Foobar
SLO NO MO
Foobar's Avatar
Nothing significant was fixed in the car since it was released other than some ECU re flash which you should have gotten regardless of model year via a TSB.
This is one of those rare cases where the early models are just as good (or as bad I suppose) as the later ones.
The Following User Says Thank You to Foobar For This Useful Post:
Old 07-31-2015, 12:55 PM   #6
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
12/12 40k miles, only had a coilpack fail so far.
Don't worry about it, if you skipped the CEL position sensor thing in the sticky then you're good, only other problem is the DI seals failing which seems to have been very isolated at only a couple hundred cars maximum out of at least 70k running around North America.
I wouldn't worry about any car, but if I had to pick a date it'd be 3/13 as that was 100% after the ECU update was for sure implemented at the factory for the DI issue.
Have patience, if you're truly concerned about warranty take a break from the internet getting you all hyped up and drive it as-is until you cross 60k miles, by the time that happens 90% of the bugs will be worked out from the guys who drive harder and have deeper pockets.
ineedyourdiddly
Tcoat (07-31-2015)
Old 07-31-2015, 01:22 PM   #7
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
What are you worried about losing?
If you want to mod your engine internals (I count forced induction as an internal mod as it greatly changes how the compression cycle works vs a normal tune), you need to do it based on an assumption you are going to write off the cost of the engine if something bad happens.
If you are worried about the bodywork, there isn't anything that can't be addressed by a TSB. If you want to continue having warranty, you can always buy extended warranty...
As for the 2013s, the only "major" issue was the ECU reflash to compensate for the specific throttle issue that would cause the DI seals to go bad. The bad idle TSB fix was addressed in the first 6 months of MY2013 production cars.
-alex
strat61caster (07-31-2015)
Old 07-31-2015, 02:21 PM   #8
My car was built in March of 2013 and I haven't had any trouble with it.
Old 07-31-2015, 04:02 PM   #9
Krispeee
March 2013 build with no problems, even with numerous track days.
Krispeee is offline   Reply With Quote
Old 07-31-2015, 04:08 PM   #10
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
March 2012 build. I had my differential and tails replaced under warranty. All else good at 43k miles.
Join the Galaxy Blue Silica BRZ registry below:
https://docs.google.com/spreadsheet/...2c&usp=sharing
Laika is offline   Reply With Quote
Old 07-31-2015, 04:34 PM   #11
CatDaddysBBQ
Drives: '13 FR-S
I have a later batch of 2013. Purchased in april of 13, and was only on the lot a few days when I bought it.
I have had NO tail light issue, plenty of crickets and just had a defective clutch fixed - throwout bearing went bad after 30k miles but had that replaced earlier this month. The reason I know it was defective not me ruining it? Numerous reasons of not being a kid and this is my 6th car owned with a manual transmission, etc...
But the main reason is that the replacement one feels miles different, better and has a proper engagement point instead of the too high one it used to have (that I just got used to so I never worried about it). Plus, it always took a tiny bit more effort to slide into 1st gear than I thought it should, and the new setup is butter smooth.
Other than that, it's been great. Love the car.
CatDaddysBBQ is offline   Reply With Quote
Old 07-31-2015, 04:42 PM   #12
EXCellR8
FR-S Driver (MT)
EXCellR8's Avatar
Drives: 2013 Whiteout FR-S
Damn, you guys drive a lot. First batch 2013 no warranty replacement on anything but I still have less than 10k on her.
EXCellR8 is offline   Reply With Quote
Old 07-31-2015, 05:04 PM   #13
BlueDubbinTDI
BlueDubbinTDI's Avatar
Drives: 2013 FR-S, 2012 MCS
May 2013 build. No issues at all (not even crickets) besides taillight condensation that I just replaced with aftermarket instead of pursuing a warranty claim. All other problems are likely self inflicted.
Old 07-31-2015, 05:33 PM   #14
yaguphire
Drives: white-out FR-S
squeaky windows when wet is a common one.
yaguphire is offline   Reply With Quote
WORK Emotion XD9 - 18x10.0 +38mm 5x100 *** Last Batch *** RavSpec Wheels and Tires 16 09-22-2015 02:06 AM
WORK Emotion XD9 - 18x10.0 +38mm 5x100 *** Last Batch *** RavSpec Exterior Parts - The Rest 4 04-22-2015 11:01 AM
First batch of Buddy Club Lights. Evasive Motorsports Cosmetic Modification (Interior/Exterior/Lighting) 8 11-14-2013 08:10 PM
[GTA]Next batch of BRZs? 8987846 CANADA 65 09-09-2012 06:53 PM
Titan Performance second batch of pulleys Amalgamo User/Vendor/Sponsor Reviews, Feedback, Comments 0 07-30-2012 10:57 PM
