#15 |
I've noticed this as well. Very odd as I know all mine are formatted exactly the same.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
#16 | |
Drives: 2016 Halo FR-S
Do you think maybe this head unit has some type of size limitation on the jpgs? Mine vary from 400x400 to 500x500. Pretty standard. I shall keep looking for the solution. |
#17 |
I found out the OS on the stock Pioneer is Linux. I want to change the splash screen. Any HU hackers out there? :P
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
#19 |
Yes it's quit annoying.
#20 | |
What this means to me is that I have little control over anything this Pioneer does. |
#21 | |
#22 |
Drives: 2016 FRS
Any one know what the max size USB device you can use and what file formats are supported (ie ntfs fat32)
2016 pioneer head unit |
#23 |
Drives: 2016 FRS
Nm read the above pdf, it's fat16 or fat32 which limits it to 32gigs
#24 | |
Look for a program called guiformat. It'll do the job for you. |
#25 |
Drives: 2016 FRS
I think if you format your device with fat32 it will only make a partition size 32gigs max as that's it's limitations. So it would be pointless using a larger device as it will only use 32 gigs of it, you would have to format it as ntfs or exfat to support a larger file size but the headunit does not support those. This is all theory though What do I know! And I like pink
#26 | |
I've been doing this for years in cars and MP3 players that "only" support up to 32GB USB drives and/or microSD cards. Just use "guiformat" or a similar tool (I have an old one made by Panasonic that's basically the same thing) and you can give a virtual middle finger to Microsoft and "the man" at the same time. Last edited by Astral Abyss; 09-01-2015 at 06:18 PM. Reason: spelling fail |
| The Following User Says Thank You to Astral Abyss For This Useful Post: | Newtothegrounds (09-01-2015) |
#27 |
Drives: 2016 FRS
I'm not saying you can't use a larger device but fat32 will only make a 32gigs partition on that device unless you have some type of black magic wand, I like green
#28 |
Drives: 2016 FRS
I apologize your black magic program defies science you are correct
| BRZ Head Unit Question | MalcolmHimself | Electronics | Audio | NAV | Infotainment | 2 | 07-19-2015 01:14 AM |
| Pioneer Head Unit Question | jjkerr626 | CANADA | 0 | 03-23-2014 11:23 PM |
| BRZ Stock Head Unit + Aftermarket Amp + 3-way Components question | daforce007 | Electronics | Audio | NAV | Infotainment | 13 | 04-14-2013 05:42 PM |
| New Head Unit Wiring Question | sikest | Electronics | Audio | NAV | Infotainment | 2 | 01-17-2013 06:15 PM |
| question about stock F-RS head unit | mezdup | Electronics | Audio | NAV | Infotainment | 3 | 10-02-2012 01:15 PM |
