Old 07-30-2015, 11:13 AM   #1
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
Emblem Replacement for Steering Wheel
Short/ Quick question;
http://koreanautoimports.com/86-matt...frs-subaru-brz
Will that emblem fit on ther steering wheel for a direct replacement of the Scion badge?
Instagram: trevor.parque
Old 07-30-2015, 11:41 AM   #2
Husker BRZ
Go Big Red!!
Drives: 2013 SSM BRZ Limited
If it's meant for the front or trunk of the car I think it would be too big for the steering wheel. I'm pretty sure the emblem on the steering wheel is smaller. And not sure if you want a projectile on your steering wheel when/if your airbag ever goes off...
Husker BRZ is offline   Reply With Quote
Old 07-30-2015, 03:04 PM   #3
Ketchum88
Ketchum88's Avatar
Drives: 2013 FR-S Hot Lava
http://www.ft86speedfactory.com/toyo...l#.Vbp1NPlVhBc
Ketchum88 is offline   Reply With Quote
Old 07-30-2015, 03:27 PM   #4
8R6
8R6's Avatar
Drives: FRS
i'd rather have a scion logo on my steering wheel instead of a toyota/86 logo on my face
8R6 is offline   Reply With Quote
Old 07-30-2015, 03:43 PM   #5
Ammunition
Ammunition's Avatar
Drives: 2014 Scion FR-S
Are you referring to this product on that website - http://koreanautoimports.com/scion-f...mblem-overlay/ ?
In which case, it states that it is a direct stick-on replacement over the existing steering wheel emblem, and without the need to remove anything.
Ammunition is offline   Reply With Quote
Old 07-30-2015, 03:51 PM   #6
MisterSheep
Killed Scion
No the one I quoted. I know that they have that 86 emblem to put over the steering wheel but quite frankly I do not like the look of that one. But thanks anyways. Maybe I'll end up making my own.
Old 07-30-2015, 07:33 PM   #7
Ammunition
Ammunition's Avatar
Ah - yeah seeing as the one you linked would be for the hood or trunk, I doubt it would look good being that the emblem is so large, and likely would have problems sticking to the material since the steering wheel isn't a flat surface - especially in the heat.
You also wouldn't want that large of a piece of solid stainless steel getting shot at your face in the event of airbag deployment - best bet would be to make your own if you're unhappy with the available options; this is why I haven't bothered replacing the emblem on my steering wheel even though I'm not a big fan of the "Scion" one.
Old 07-30-2015, 07:42 PM   #8
ZOMFGAARON
A Demon
ZOMFGAARON's Avatar
Drives: Raven GT86
This has been discussed numerous times. The flap opens upward if the emblem did come off from the air bag deploying its go in the roof.
Old 07-30-2015, 07:55 PM   #9
ZOMFGAARON
A Demon
ZOMFGAARON's Avatar
Drives: Raven GT86
Check this post out.
http://www.ft86club.com/forums/showthread.php?t=44720
TRD steering wheel emblem Sangthing Interior Parts (Incl. Lighting) 10 04-13-2015 09:57 PM
Toyota "T" Formed Aluminum Steering Wheel Airbag Emblem - Overlay VS Replacement fooddude Cosmetic Modification (Interior/Exterior/Lighting) 75 04-08-2015 01:33 AM
FS: Steering Wheel Toyota Emblem FRS_Jack Interior Parts (Incl. Lighting) 3 07-01-2014 03:29 AM
Scion steering wheel emblem replacement: any companies planning to make one? fooddude Cosmetic Modification (Interior/Exterior/Lighting) 8 05-13-2014 06:20 PM
TRD steering wheel emblem project d CANADA 4 02-10-2014 06:15 PM
