Old 07-18-2015, 09:40 PM   #337
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
Turning some laps at NJMP the other day.
Biggest problem? Brakes. First session ended after 10 minutes due to lightning. Second session was wet so no problem aside from having no traction. Final session it was moving pretty quick but 15 minutes into it the brakes were giving up. We put a stop tech kit on it with race pads so should be fine at this point.
Otherwise power delivery was great and the car felt pretty solid with no power fade lap after lap, just needs a proper suspension and a little more seat time on this course. Having done lightning a bunch of times, thunderbolt is a whole different animal with decreasing radius turns and a pretty quick straight. We used the tribodyn supercharger oil.
Xero-Limit is offline
The Following 4 Users Say Thank You to Xero-Limit For This Useful Post:
BobbyBlue86 (07-19-2015), Chad86 (07-19-2015), SprintexUSA (07-19-2015), stockysnail (07-19-2015)
Old 07-29-2015, 06:39 PM   #338
dallenj
Drives: Grey FR-S
this might be a stupid idea, but it might be worth it to post it here. I read a lot on this post because i plan on getting the 335 kit for my car in the future. I read a lot about intake temps being to high or people trying to fit a larger throttle body to get more are through the supercharger my plan might eliminate both issues. We all know the colder the the air the more you can fit in somewhere. That's poorly explained, but most of you probably understand it. My idea is to put an intercooler on this kit. I know it already has one in the supercharger itself, but if we put one on like they do on turbos or on the vortech kit it will cool the air an eliminate the problem with the high intake temps. that could also eliminate the need for a larger throttle body with colder means more will get sucked in and be compressed. I do not know if this will work, but its worth a shot to tell some people that can test it out. Hope this helps and feel free to check out my nitrous build thread would love to get some advice on improving my car and my time.
http://www.ft86club.com/forums/showthread.php?t=91847
dallenj is offline
Old 07-29-2015, 08:53 PM   #339
xjohnx
Grip>Slip
xjohnx's Avatar
Originally Posted by stockysnail View Post
The Perrin intake with a metal charge tube instead of the plastic makes it much more noticable. Most of it is from the Perrin intake. I have a few videos of my car on the track in my build thread near the bottom of the first post in the build thread.
Here's a video of a 210 with the perrin 3" intake and stock plastic tube, if that helps:
[ame="https://www.youtube.com/watch?v=NIbYsN_rRsI"]Innovate Supercharged BRZ Dyno Run - YouTube[/ame]
xjohnx is offline
Old 07-30-2015, 02:38 AM   #340
stockysnail
Just the tip
stockysnail's Avatar
1. E85?
2. How much lower is the intake temp with the gold heat reflective tape?
3. Which header?
4. 3" exhaust and which one?
5. How much did the 3" intake increase HP?
Thanks for answering my questions.
stockysnail is offline
Old 07-30-2015, 06:23 AM   #341
xjohnx
Grip>Slip
xjohnx's Avatar
1. E85?
3. Which header?
1 -Around E65 on that run.
2 -Peak temperatures haven't changed all that much, but they come down a LOT quicker now.
3 - Nameless
4 - 2.5" exhaust
5 - didn't get a before/after on the intake.
xjohnx is offline
stockysnail (07-30-2015)
Old 08-06-2015, 04:10 AM   #342
smudge
Drives: Supercharged GT86
Would the 70mm pulley on the 335 be over-spinning the charger?
smudge is offline
Old 08-06-2015, 07:18 AM   #343
350matt
Drives: toyota mr2/ Toyota GT86
you're going to struggle here because the place to put an inter cooler is after your compressor
so you need to space the charger up off its manifold in order to fit an exit and a re-entry pipe into this gap and I doubt theres' the room to do this without cutting a large hole in the hood
350matt is offline
The Following User Says Thank You to 350matt For This Useful Post:
Dream20b (08-10-2015)
Old 08-06-2015, 12:56 PM   #344
FA5teryo
Drives: GT3076r 8th gen Si
it's taken 8+ years since they first released a supercharger kit for the 8th gen Civic Si before someone designed an A2A manifold for a roots/ts blower..
http://mercracing.net/products-page/...rger-manifold/
Jose(Merc Racing owner) designed the a2a manifold and runs one on his rsx with a Lysholm blower --- the only other one I'm aware of just recently got running with a TVS1900 blower(pictured below). He's aiming for 430-450whp at around 18psi..
I wonder how much room there is underneath the blower(basically how much room does the current a2w manifold take up) + hood clearance to squeeze in some sort of a2a manifold...
different platform, but I know we don't have an infinite amount of room to fit things up front either -- nice to see the creativity even tho this car is obsolete now..
Hopefully someone takes it upon themselves like Jose did, to fab up something similar for the FT86 chassis! Dat whine is pretty addicting!
FA5teryo is offline
Old 08-06-2015, 01:46 PM   #345
Kodename47
Kodename47's Avatar
Drives: UK GT86
Doesn't it have the same threshold as the 210?
.: Stealth 86 :.
Kodename 47 DJ:
Kodename47 is offline
Old 08-06-2015, 02:55 PM   #346
DIE1000DEATHS
TechNINJA
DIE1000DEATHS's Avatar
Drives: Whiteout MT, 87 Mustang, 09 RUCKUS
According to @moto-mike, for this kit you take the pulley size and multiply by 100, and that will give you the highest you'd want to spin the motor as far as engine RPM. That would mean you'd not want to exceed 7000rpm with the 70mm pulley.
DIE1000DEATHS is offline
Old 08-07-2015, 07:03 AM   #347
smudge
Hmmm....
My limiter is set to 7650rpm I think...that extra 650rpm shouldn't be an issue really...should it?
smudge is offline
Old 08-07-2015, 09:22 AM   #348
WHITE
Thats pretty neat
WHITE's Avatar
Drives: LOADING......
Hmmm....
75mm @ 7,650rpm = 15,235rpm
72.5mm @ 7,650rpm = 15,769rpm
70mm @ 7,650rpm = 16,307rpm
The "safe" CONTINUOS rpm of the 210 and 335 blower is 15,000rpm. I'm not going to tell you whether or not 1,300rpm momentary over spin is "ok" or not since I didn't build these units. I dont know the wiggle room they left on the table, and I'm sure they(sprintex) aren't going to tell you either.
WHITE is offline
The Following User Says Thank You to WHITE For This Useful Post:
Xero-Limit (08-08-2015)
Old 08-07-2015, 02:10 PM   #349
stockysnail
Just the tip
So basically multiply 2.13 by the RPM and if it's over 15k then you don't want to continuously be at that RPM. Based on the numbers it doesn't seem to matter which pulley you run, you'd never want to continuously run over 7k RPM.
Old 08-07-2015, 02:13 PM   #350
ybotspawn
ybotspawn's Avatar
Drives: 13 Subaru BRZ
I thought 15k was redline, not safe continuous.... My understanding is that generally you shouldnt run over 80% continuously. So if redline is 15k, you should not run over 12k continuous
ybotspawn is offline
500whp or bust, sprintex, sprintex 335
The new sprintex 335 supercharger jet86 Forced Induction 39 11-01-2014 11:27 AM
Innovate/sprintex SC rudysaliby Scion FR-S / Toyota 86 GT86 General Forum 3 10-28-2014 03:14 PM
Innovate/ Sprintex vs vortech GeeTee86 AFRICA 24 04-04-2014 02:38 PM
Innovate/ Sprintex vs vortech GeeTee86 AFRICA 5 03-05-2014 07:26 AM
TyperRspec789's Full Blown Stage 1 Base Turbo & e85 Progress and Testing TyperRspec789 Forced Induction 63 12-31-2013 07:39 PM
