Old 06-09-2015, 02:15 AM   #197
YouShallKnow
Drives: Man
Send a message via ICQ to YouShallKnow Send a message via AIM to YouShallKnow Send a message via Yahoo to YouShallKnow
Today was not a good day to spend screwing around with the clutch spring.
Anyway, not sure how I feel about the mtec spring.
It's a lot lighter than no spring but gets rid of the slop.
It brings back a bit of the vagueness at the top of the release.
Only went for a quick drive so far but I'm gonna give it a week or so to test it.
I recently swapped in the MTEC spring as well. It was INSANELY hard to install for me, could not find a way to get easy access, I cut my hands up some how, and after all that I didn't get the retainer clip back on.
On top of being an incredibly frustrating install, the benefits don't seem worth it.
To anyone considering this part; don't buy it unless you have real issues with the stock clutch feel. I didn't mind the stock clutch, so although it feels a bit different, doesn't feel better at all for me.
YouShallKnow is offline   Reply With Quote
The Following User Says Thank You to YouShallKnow For This Useful Post:
jcw99 (06-10-2015)
Old 06-09-2015, 02:39 AM   #198
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
I used like 4 of my own zipties because the ones provided stripped when the spring was compressed all the way.
I also disconnecting the clevis pin from the other side to give some extra play while putting the pin in.
After that, I sat the spring on it's perch and pointed the assembly upward while pulling the clutch forward (toward the steering wheel) and then setting the top part of the spring holder-whatever-it's-called in place, then pivoted the assembly down in place to put the pin in while wiggling the spring assembly so it went in.
The Following User Says Thank You to Andrew025 For This Useful Post:
jcw99 (06-10-2015)
Old 06-09-2015, 03:18 AM   #199
ck-GT86
ck-GT86's Avatar
Drives: '13 Raven FR-S, MT
I used additional zip ties like the next poster. It helps to remove the pin that connects to the clutch arm to the master cylinder. I was able to freely move the pedal back and forth. It was a little troublesome getting the pin out of the clutch arm to the spring.
For me, i like the feel of the pedal fully returning vs the little slop left around if you were the remove the spring entirely. Sorry you guys dont like it, but for me its worth it with the slave cylinder swap. I dont think the spring would be worth it by itself.
Edit: be mindful that i went springless back to spring, then mtec spring. I was able to feel a difference between the oem and mtec
|| My Build Thread ||
ck-GT86 is offline   Reply With Quote
The Following 2 Users Say Thank You to ck-GT86 For This Useful Post:
jcw99 (10-30-2015), Ultramaroon (06-09-2015)
Old 06-09-2015, 02:43 PM   #200
This all speaks to my rantings in the spring removal and clutch adjustment threads. They're nice but don't address the root cause of the vagueness in the oem setup.
Don't feel bad, @ck-GT86. Everyone has a different preference. It's just great that we have these options.
For those installing either the MTEC or OEM spring, remember, the spring is at it's loosest when the clutch pedal is fully depressed. Now, whether or not it's feasible to work in that position is another story. I haven't reinstalled mine yet so,
ck-GT86 (06-09-2015), jcw99 (06-10-2015)
Old 07-27-2015, 12:50 PM   #201
stockysnail
Just the tip
stockysnail's Avatar
I drove @Ultramaroon's car around the block. This convinced me to also do the mod. He said parts only cost about $35ish so why not right?
Old 07-27-2015, 01:42 PM   #202
Much ado about the spring and pedal adjustment in other threads but, as you now see, it's not the root of the issue. Bring your car by my place if you like. We can do it together.
stockysnail (07-27-2015)
Old 07-27-2015, 01:53 PM   #203
Andrew025
Andrew025's Avatar
I think I need to bleed my slave.
I had my wife helping me last time and it didn't go so well.
Old 07-27-2015, 01:54 PM   #204
yaguphire
Drives: white-out FR-S
What did u do wrong? Should be simple.
yaguphire is offline   Reply With Quote
Old 07-27-2015, 01:58 PM   #205
Andrew025
Andrew025's Avatar
The timing, making sure no air is in the system.
Ultramaroon (07-27-2015)
Old 07-27-2015, 05:02 PM   #206
stockysnail
Just the tip
Speed bleeders make it so much easier! It's a one person job instead of two. Part # is SB1010-SS
Old 07-27-2015, 06:00 PM   #207
yaguphire
Hold clutch pedal bleed and lock no go?
Old 07-27-2015, 09:48 PM   #208
If both parties aren't on the same page it's quite possible. I made a big deal about proper bleeding in the instructions specifically because of past struggles with a less motivated partner.
Old 07-27-2015, 09:54 PM   #209
Andrew025
Andrew025's Avatar
My wife was uh... Maybe a bit less than willing that day lol
sato (07-27-2015)
Old 07-27-2015, 10:05 PM   #210
Oh, I feel your pain.
clutch line, slave cylinder
Clutch Engagement Improved! enjoyminutemaid Engine, Exhaust, Transmission 53 11-07-2018 06:31 PM
Can steering feel, tactility, be improved? Without sacrificing adjustability? Trettiosjuan Suspension | Chassis | Brakes -- Sponsored by 949 Racing 101 08-16-2016 08:14 PM
Aftermarket Clutch Master and Slave? Yruyur Engine, Exhaust, Transmission 5 07-27-2013 10:22 AM
Hate the feel of the clutch FRSGeek Engine, Exhaust, Transmission 18 07-10-2013 01:24 PM
Clutch feel? Shit Luck Engine, Exhaust, Transmission 5 04-21-2013 05:32 PM
