Old 07-25-2015, 12:28 PM   #3529
Taino-BRZ
Taino-BRZ's Avatar
Drives: Subaru BRZ-SWP
Originally Posted by beemer View Post
who has the Kraftwerks c30, tuned, and has gotten a time slip. I'm running tuned at 281whp with the SC and isis over pipe back (with resonator).
last night I ran it 5 times, and my best time was a 14.05.
and this is on factory tires, so I know I could have cut my time down with better tires.
let me know what you have done!
Sent from my SM-N900P using Tapatalk
I did 12.6 at 115mph c30 e85 high boost.drag radials
Taino-BRZ is offline   Reply With Quote
Old 07-25-2015, 09:34 PM   #3530
FirestormFRS
@KraftWerks when can we see the numbers the car makes with the CARB tune
FirestormFRS is offline   Reply With Quote
Old 07-27-2015, 01:11 PM   #3531
KraftWerks
KraftWerks's Avatar
Drives: Kraftwerks BRZ
We should have the vehicle back from their facility shortly and will re-dyno on the tune to show exactly what the test vehicle is making. - CJ
KraftWerks is offline   Reply With Quote
Old 07-27-2015, 03:19 PM   #3532
CSG Mike
CSG Mike's Avatar
Is your CARB tune different from the ones that went out with your kit in the past?
Old 07-27-2015, 03:57 PM   #3533
zoth
zoth's Avatar
Drives: 2013 BRZ Premium Dark Gray Metallic
Originally Posted by mit_peid View Post
These are the steps I took:
1) remove the pipe going into the intake manifold to make room
2) take the cover off of the KW plate
3) disconnect the inlet/outlet of the Rotrex traction lines (tie them together out of the way temporarily with an adapter so they don't leak)
4) loosen fasteners going into and out of the Rotrex blower
5) remove tensioner pulley
6) remove 4 bolts (2 on the Y, and 2 small ones on the bottom right) from the KW plate, keeping the single large bolt on the left
Now you can rotate the Rotrex assembly counterclockwise on that single large bolt, dislodging from the urethane charger piping, and replace your belt.
As he said doing this.
KraftWerks SuperCharger C30=HB-Waterless Coolant-(Mishi)Racing Thermostat & Oil Can
Tomei EL-PLM Overpipe-HKS Dual Resonated Front Pipe-Invidia N1
DR31 18x9+38 Square w/ 255/40r18 PT-722, TRD Quickshifter, ACT Streetlite Kit
Moto-East Flex-Fuel Kit (Almost running 100% E85 all the time)
DW 700 cc Injectors-Tune by (Moto-East)-KW Oil Cooler
zoth is offline   Reply With Quote
The Following User Says Thank You to zoth For This Useful Post:
mit_peid (07-28-2015)
Old 07-27-2015, 04:55 PM   #3534
FirestormFRS
Oil temp question. I was seeing 110c. Decided to wrap my header with the hope that would lower the temp down. I'm seeing 107c now. This is normal interstate driving in mid 80's high humidity day.
To oil cooler or not that is the question.
Old 07-27-2015, 06:55 PM   #3535
KraftWerks
KraftWerks's Avatar
Yes.
Some have the original Delicious tune and some have already received the revised tune which is what went to CARB. Shoot some have standalone tunes from the various tuners out there for the platform.
The Following User Says Thank You to KraftWerks For This Useful Post:
Rulin (07-27-2015)
Old 07-27-2015, 10:23 PM   #3536
zoth
zoth's Avatar
I'm in TX around 98 degrees my Temps are around 236 to 244 f but after the my oil cooler installed I'm around 204 to 208 at the same temp. and using using Evans waterless coolant. Also have Mishimotos racing thermostat.
Sent from my SM-N900T using Tapatalk
Old 08-06-2015, 12:25 PM   #3537
Wingnut537
Drives: 2015 FR-s RS1.0 0186/1500
add me to the list . Ordered my C38 kit this morning
Wingnut537 is offline   Reply With Quote
The Following 5 Users Say Thank You to Wingnut537 For This Useful Post:
Freeman (08-06-2015), KraftWerks (08-06-2015), mit_peid (08-06-2015), Rulin (08-06-2015), Triumphrider (08-06-2015)
Old 08-06-2015, 03:09 PM   #3538
rj101592
Drives: 2013 scion frs
Got my kit installed this past weekend. Loving it so far! C30 kit, put down 311 whp and 221 tq. Only issue is that it seems as though I will need to purchase the raceseng cam plate... as I am running into the famous problem of leaking oil from the stock one. Pump gas, 93 octane.
rj101592 is offline   Reply With Quote
The Following User Says Thank You to rj101592 For This Useful Post:
Old 08-06-2015, 03:15 PM   #3539
Triumphrider
Triumphrider's Avatar
Drives: 2013 Scion FRS in white out
I run the c38 on the moto East tune.... Love it!
2013 Scion Frs AT in Whiteout, Borla UEL header, Greddy SP Elite AxleBack. Kraftwerks C38 Supercharger tuned by Moto East and 2 kid seats in the back.
Triumphrider is offline   Reply With Quote
The Following User Says Thank You to Triumphrider For This Useful Post:
Old 08-06-2015, 06:26 PM   #3540
THE_FRS_KID
What other mods do you have? How much boost? What size pulleys?
THE_FRS_KID is offline   Reply With Quote
The Following User Says Thank You to THE_FRS_KID For This Useful Post:
Old 08-06-2015, 06:28 PM   #3541
KraftWerks
KraftWerks's Avatar
Impressive POWA!
Old 08-06-2015, 07:53 PM   #3542
rj101592
Tomei UEL header, berk overpipe/catted midpipe, invidia N1 catback and a national speed tune. 13psi. Not sure what size pulleys.. whatever came with the c30 kit.
THE_FRS_KID (08-07-2015)
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 12:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 12:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 05:27 PM
