Old 06-19-2015, 05:01 PM   #323
r0nd3L
Drives: 2015 FRS
Just loaded E85 stage 2 EL tune on my stock 2015. So far, so good!
What I'm wondering if there is a procedure to do throttle calibration on these cars? For example, VW/Audis have throttle body alignment feature available in VAG-COM. It's super annoying waiting till the pedal becomes responsive in these cars after a flash or ECU reset.
r0nd3L is offline   Reply With Quote
Old 06-19-2015, 05:34 PM   #324
steve99
Drives: FT86
Read the Flashing-Reset-Learning link below :-)
Old 06-19-2015, 06:57 PM   #325
r0nd3L
Drives: 2015 FRS
I actually read it right after I made the post
Thanks for posting very useful information!
Old 07-26-2015, 02:40 PM   #326
Texas2016Frs
Bottled FRS
Drives: 2016 manual frs
Can running an e85 fuel cleaner help reduce General wear?
I am debating using e85 in the future, power would be awesome just don't want to break the car. I was thinking something like this
http://lucasoil.com/products/fuel-tr...th-stabilizers
Texas2016Frs is offline   Reply With Quote
Old 07-26-2015, 04:54 PM   #327
phrosty
I haven't seen any independent studies indicating these actually do anything. Shouldn't be needed in any case, we've got lots of people running E85 here without issue.
phrosty is offline   Reply With Quote
Old 07-27-2015, 06:27 AM   #328
504
504's Avatar
Drives: 2014 86 GTS
Just to instil some confidence in this fuel, here is my port injector after 4000km on full time eflex and 10000km garbage 98 before that..
It's absolutely squeaky clean both inside and out, the camera exaggerates the dirt alittle and what you see on it is just pcv residue which was left also in the rest of the manifold which I cleaned out. Ethanol is awesome.
504 is offline   Reply With Quote
The Following 4 Users Say Thank You to 504 For This Useful Post:
housecat (08-15-2015), Kronos (07-28-2015), phrosty (08-28-2015), steve99 (07-27-2015)
Old 08-28-2015, 12:24 AM   #329
pinoybrz15
Drives: 15 CWP
I have a greddy intake and ofh/oft do i need go get custom dyno tune so they re scale maf?before running e85 fuel and flashing to stage 2 e85 uel?thanks
pinoybrz15 is offline   Reply With Quote
Old 08-28-2015, 03:15 AM   #330
steve99
Drives: FT86
I think the Gready intaker is a Takeda clone
It would be better if you scaled your maf on petrol tune then transfered that scaling to the E85 tune you can do the scaling yourself if you want
see here http://www.ft86club.com/forums/showthread.php?t=64790
their is also a baseline Takeda maf scaling attached
shiv could do you a customised e-tune for $200 that would be heaps cheaper than dyno
Old 08-28-2015, 04:20 AM   #331
pinoybrz15
Drives: 15 CWP
thanks for your help so you think e tuning is better than dyno tuned?also can shiv do the re scaling for me when i get e tune?i just dont trust myself doing it thanks again
Old 08-28-2015, 04:32 AM   #332
steve99
Drives: FT86
Dyno tunes will always be better than an e-tune, as the tuner is right their at the dyno and can make changes on the fly and see the results instantly and do the runs he/she wants at specific loads ect dialed up on the dyno.
However if you have a good base tune that was dialed in on dyno and it just a clean up and intake scaling required it probably not worth the expense of a full dyno tune.
you might also be hard pushed to find a tuner that works with opensource tunes like openflash as they generally want to lock their tunes.
Old 08-28-2015, 05:07 AM   #333
pinoybrz15
Drives: 15 CWP
thanks i'll probably just ask shiv do do the tuning for me since i have oft
Old 09-05-2015, 03:51 AM   #334
LOLS2K
/scion
LOLS2K's Avatar
Drives: '13 86 M/T
I understand that we are able to run e85 with OFT tune. If I wanted to have a Zeitronix ECA2 to view e% on a gauge, would I need to buy flex fuel lines to connect to the FF sensor? If so, am I better off just going with a plug n play FF kit?
LOLS2K is offline   Reply With Quote
Old 09-05-2015, 04:00 AM   #335
ZOMFGAARON
A Demon
ZOMFGAARON's Avatar
Drives: Raven GT86
Old 09-05-2015, 07:24 AM   #336
steve99
Drives: FT86
Yes you would need to buy the whole kit.
oft tunes dont yet have the software required to read the e% from the sensor and adapt the tune, your going to need ecutek flex fuel tunetune and licience and flex fuel kit for a full flex fuel setup that arround $750 or so usa from memory.
Stock FR-S Tune Just Done Zach3794 Engine, Exhaust, Transmission 67 11-05-2017 03:01 PM
stock BR-Z, much detonation during shifts: tune? elefunkd Engine, Exhaust, Transmission 69 07-26-2013 05:20 PM
Anyone have a stock tune from Visconti? Bleevin CANADA 3 07-03-2013 02:01 AM
My Initial (all stock) BRZedit tune mad_sb Engine, Exhaust, Transmission 6 02-16-2013 01:20 PM
Save stock tune with ecutek? gdrider77 Engine, Exhaust, Transmission 7 01-06-2013 01:50 AM
