Old 07-24-2015, 05:13 PM   #9045
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Originally Posted by j_Zer0 View Post
I also got this model of Procede. Judging by Sojhinn's install video, the two green wires hook up to the ECU, the metal loop is the ground, the serial connection is for laptop hookup and the red wire is power. This leaves me with one problem:
How am I to connect my Procede with my ESC controller? After all, the wiring that connects my ESC controller to my throttle switch doesn't have an audio jack (I have a recent v2 kit). When I asked Fenton about this he said the new kits have different connections that should hook right up to the
Procede. But how? It looks like the only option is to have a male audio jack that would hook up to the black female audio port seen in the picture.
Any thoughts @fenton @Sojhinn ?
Checking out my install give me a few.
Installed Mods:
Old 07-24-2015, 05:49 PM   #9046
fenton
Talked with Rob and he said he will send instructions next week if Shiv can't respond. Rob is currently away camping.
Trust me I'm waiting on my install too!
fenton is offline   Reply With Quote
The Following User Says Thank You to fenton For This Useful Post:
j_Zer0 (07-24-2015)
Old 07-24-2015, 06:02 PM   #9047
Sojhinn
Sojhinn's Avatar
@j_zero
Ok so I'm assuming the colors of the wires on the procede match the colors on mine correct?
Also Let me know if you have the new version of phantom with the new bulky connection to the foot pedal.
Installed Mods:
Old 07-24-2015, 08:07 PM   #9048
j_Zer0
Drives: Asphalt FRS 2014
Originally Posted by Sojhinn View Post
@j_zero
@Sojhinn,
The colors on the wires do appear to be the same as those in your video: One green wire with a white-ish line and one with a black-ish line.
I've attached a pic of the connection to the pedal switch.
ESC+OFH | Borla Axleback | Helix clear side markers | Opti-coat | Beatsonic v2 Sharkfin antenna | TRD lowering springs | TRD sway bars | 18" Enkei Kojins + PSSs
j_Zer0 is offline   Reply With Quote
Old 07-24-2015, 08:11 PM   #9049
Sojhinn
Sojhinn's Avatar
Full throttle Electric Supercharger Build Thread
@Sojhinn,
Ok here's the fun part.... One of those wires (on the switch connection) is the one you would solder to the wire on the procede that contains the audio jack. Of course you would cut off the audio jack but which wire it needs to be is unknown.
You could test or wait for rob.
I'm assuming that one wire is the ground, one is the partial boost voltage wire and one is the full voltage wire.
Im guessing it would be the red one.
Installed Mods:
The Following User Says Thank You to Sojhinn For This Useful Post:
j_Zer0 (07-25-2015)
Old 07-24-2015, 09:14 PM   #9050
dtek
Drives: 86 A00I
One suggestion, YMMV...
connect securely all other Procede connections (ie, ecu, ground, power) and then remove the female audio end connector to give you a little free bare wire.
Similarly, get yourself access to the three wires that go to your pedal switch. It's possible I think, to press with a very tiny screwdriver in the barbed bit in the back of the pins in the connector and that lets you pull free the wires.
You can then go for a little test drive somewhere safe, hand twisting together the procede trigger wire with one of the pedal switching wires, take an educated guess and start with the red one. You'll know immediately when you press 70%+ throttle if it's the correct wire – it'll pull like a WOT run on the pedal switch setup, and the voltmeter will show a big drop off. If the red doesn't work try the next, and so on. Take note of the wire that works, then go home and make the connection properly. Done!
dtek is offline   Reply With Quote
The Following User Says Thank You to dtek For This Useful Post:
Gums (07-24-2015)
Old 07-24-2015, 09:17 PM   #9051
Sojhinn
Sojhinn's Avatar
That too.
Installed Mods:
j_Zer0 (07-25-2015)
Old 07-25-2015, 01:00 PM   #9052
j_Zer0
Good idea @dtek! I think I'll give this a shot later. If things don't go according to plan though, I think I'll wait for Rob.
Old 07-25-2015, 01:04 PM   #9053
Sojhinn
Sojhinn's Avatar
Also J load my map on the procede. It's just in general a better fit for the ft86. I'm guessing shiv hasn't started loading it yet.
Installed Mods:
j_Zer0 (07-26-2015)
Old 07-25-2015, 01:53 PM   #9054
alex345
FRS610
alex345's Avatar
Drives: Scion- Frs
Send a message via MSN to alex345
any videos running? with proceed? want to see hows the progress!
FRS 10-series- OFT,OFH,PerrinOP, Tanabee Fp.Perrin MAF intake,Cusco strut bar,Grimspeed tool tray, invidia Q300, Full JL Audio sound system, YO speed plaque.
Instagram: FRS610
"Project cars are like New Years Eve. Endless preparation, hype, a sleepless night of fun, followed promptly by massive headaches and regret." - Anonymous #maverick#
alex345 is offline   Reply With Quote
Old 07-25-2015, 02:10 PM   #9055
Sojhinn
Sojhinn's Avatar
I can do one tomorrow. Anything specific?
Installed Mods:
Old 07-25-2015, 06:22 PM   #9056
btoast
Alright, I have joined the ESC party.
I just completed my install and took a spin around the block. WOW! This is how the car should have felt from the factory.
It took me approximately 2.5 hours to complete the install. That includes accidentally dropping my socket wrench on the dump packs and creating a circuit which shot sparks everywhere and melted part of the wrench and bolts. I needed to run down to ACE for new bolts.
The only real issue I had with the kit (aside from my own dumb mistake mentioned above), is the hose leading from the air box to the compressor is too long. I tried to cut it, but I had too much difficulty doing so with my primitive tools (I broke my only pair of scissors the other day and my x-acto blade has a rounded tip. I ultimately gave up on cutting it shorter. You will see in my photos that the compressor really needs to be shifted over about 1/4 of an inch to line up perfectly.
Other than that, the install went smooth.
My ghetto cutting did not work:
This is my only concern. This red cable touches the heat sink on the main controller box. I tried moving it but there is no way to position it where it does not touch.
My poor socket wrench:
Overall, the kit is very well put together and very easy to install. I look forward to picking up the proceed controller in a month or two.
btoast is offline   Reply With Quote
The Following User Says Thank You to btoast For This Useful Post:
DAEMANO (07-25-2015)
Old 07-25-2015, 06:26 PM   #9057
Sojhinn
Sojhinn's Avatar
Welcome to the family. Make sure to check your batteries in a few days. There's a good chance they may not charge anymore.
Installed Mods:
Old 07-25-2015, 06:40 PM   #9058
btoast
Yeah, I figured I would keep an eye on the voltage meter in the car to see if it struggles to get back to 28.4v.
I hope they continue to work fine. It would suck to have to buy new batteries. I still cant believe I dropped the wrench and it just happened to fall perfectly straight onto the other side. What bad luck that was.
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
