Old 07-24-2015, 11:22 AM   #757
Sleepless
Sleepless's Avatar
Drives: 2016 FR-S
Some info on supercharger and longer intake runners: http://www.ft86club.com/forums/showthread.php?t=85168
Also, since these raise the manifold, you'll need make some adjustments for most SC kits.
30 seconds of SEARCH... Just sayin'
Sleepless is offline   Reply With Quote
Old 07-24-2015, 03:27 PM   #758
Deepseadiver
Drives: 2013 BRZ DMG manual Limited
Thanks for the link, however not a lot of information there. I think only two people have tested with them Shiv and Delicious. No word from Crawford.
Deepseadiver is offline   Reply With Quote
Old 07-25-2015, 03:47 PM   #759
Sleepless
Sleepless's Avatar
Drives: 2016 FR-S
Mine are being installed Aug 12 @Drift-Office. There is a very good chance that this winter I'll be having them install the JRSC so we can experiment
The Following User Says Thank You to Sleepless For This Useful Post:
Jmonty (07-25-2015)
Old 07-25-2015, 04:11 PM   #760
Sammakko
Bilge monkey
Sammakko's Avatar
Drives: '13 BRZ, 82 starlet
i heard in another thread that these are not recommended with e85. is that really the case?
n/a car, e85 tune from OFT
Sammakko is offline   Reply With Quote
Old 07-25-2015, 05:30 PM   #761
Jmonty
Realtor/ Principal Broker
Drives: JRSC BRZ GBS LTD 2010 LTD Outback
I was running with for a couple of weeks with the JRSC but have now removed them.
Jmonty is offline   Reply With Quote
Old 07-26-2015, 02:29 PM   #762
Sleepless
Sleepless's Avatar
Drives: 2016 FR-S
Did it make a difference? Any before/after dyno?
Old 07-26-2015, 03:28 PM   #763
Jmonty
They seemed to heat soak, different days butIi made more power without. I don't have before and after dyno to compare side by side, when I pulled them off I also added the oil cooler
Old 07-30-2015, 08:21 AM   #764
FTemplar
Drives: BRZ Sport-tech 2013
Originally Posted by Matey View Post
Can someone explain to me why it doesn't benefit FI? it'd be doing the same thing it is right now, would it not? don't troll me. this is a 100% serious question. thanks.
If i'm not wrong, I read somewhere that it doesnt fit physically after you go FI.
FTemplar is offline   Reply With Quote
Old 07-30-2015, 12:09 PM   #765
sidesleeper
Drives: BRZ series blue
I also had the same results.
They heat soak. Power drops off up top with them installed hot or cold.
I took them off and sold them to the next sucker.
sidesleeper is offline   Reply With Quote
The Following 2 Users Say Thank You to sidesleeper For This Useful Post:
raven1231 (07-30-2015), Wayno (08-03-2015)
Old 07-30-2015, 02:02 PM   #766
celek
Resident Gear Head
celek's Avatar
You guys do not understand the point behind the product.
This product is basically changing the intake runner length.
Result is more TQ and shifted power band. If you are worried about PEAK power and hovering your engine at 7000RPM all day the product is not for you.
The faster you can make peak power the faster the car goes.
Same in Forced induction world. If you make 800 HP but don't hit full boost until 6000RPM the guy with full boost @3000RPM making 400 HP will beat you because his power band is reached faster.
The fact the TQ band and power band is shifted makes for faster acceleration. If you are worried about that last 300RPM go ahead and hover as it flattens out on the track for a good second while the other guy has already shifted into his power band pulling on you.
This scenario is the same for any engine as well. Longer runner = more TQ less top end. If you want extreme top end go with Individual throttle bodies but you will lose the Torque down low. Trick is finding the happy medium.
celek is offline   Reply With Quote
The Following 3 Users Say Thank You to celek For This Useful Post:
drewbot (07-31-2015), FTemplar (07-30-2015), Snake (07-30-2015)
Old 07-31-2015, 02:20 PM   #767
sidesleeper
Your perception is your reality, not mine.
Old 07-31-2015, 02:55 PM   #768
stugray
Drives: 2013 GBS BRZ Limited
Here is another way to think about it:
With NA, the engine is a vacuum pump and it is pulling air through the intake manifold.
So in this "regime" the smoothness of the intake path is the primary contributing factor to how much air charge you get into each cylinder during the intake stroke.
With FI, the engine is no longer pulling a vaccum at the intake valve, the FI is pressurizing the intake manifold side.
So that air charge is just sitting on the other side of the door (valve) to get in.
In this regime, the smoothness of the intake manifold is NOT the primary contributing factor to ho much air charge you get.
Another factor is the momentum of the air charge rushing towards the intake valve when it closes causes a "standing wave" of pressure in the intake that changes frequency (and therefore wavelength) with RPM.
Under FI, the standing wave is completely different so may/may-not benefit from the change in intake runner length that the BPBs provide.
Old 08-03-2015, 12:03 PM   #769
celek
Resident Gear Head
celek's Avatar
not my reality, it is simple physics and velocity. You see the same thing in the Honda world with the Acura GSR that has 2 different length runners and a butterfly valve to divert air flow to a shorter runner at a specified RPM for high horsepower.
The longer runners provide more TQ while the shorter runners provide less TQ at higher RPM resulting in more top end.
This is why the Type R has a really short straight runner for more top end but not as much TQ because its designed for road racing and staying in a Power band when it was a Spec car in the late 1990s.
Same can be achieved on the exhaust manifold.
https://www.physicsforums.com/thread...eaders.208674/
Same can be seen here in Lemans cars ITBs.
https://grassrootsmotorsports.com/fo...s/58727/page1/
The Crawford BPB have been proven by numerous 3rd party reputable sources who originally doubted the claims. If you had a different experience you may want to find a different tuner for the VVC maps and Injector timing since they have been moved up slightly.
The Following 2 Users Say Thank You to celek For This Useful Post:
drewbot (08-03-2015), FTemplar (08-03-2015)
Old 08-03-2015, 06:19 PM   #770
stugray
His "perception" IS REALITY, therefore it is your reality too.
(unless you live in an alternate universe).
Perhaps what you meant to say was "My observations do not match your explanation"
The Following 2 Users Say Thank You to stugray For This Useful Post:
Andrew025 (08-03-2015), FTemplar (08-03-2015)
billet, crawford, magic blocks
Crawford Performance Turbo BRZ! Balance Meets Power - Ignition Episode 71 ZetaVI BRZ Photos, Videos, Wallpapers, Gallery Forum 22 04-01-2014 05:19 PM
short blocks? 350matt Engine, Exhaust, Transmission 4 11-04-2013 08:37 PM
Billet Oil Catch Can #BC-175 by Billet Custom Tim_Asphalt_FRS Engine, Exhaust, Transmission 48 10-27-2013 02:29 PM
***Blitz Advance Power Air Cleaner and SUS Power Core Intakes*** FT-86 SpeedFactory Engine, Exhaust, Transmission 1 10-07-2013 09:40 PM
