Old 07-23-2015, 10:11 PM   #57
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by solidONE View Post
so there was an one inch gap between the spring and the upper perch thing? If that the case you know for sure it unthreaded. I doubt Tein use spring material that is that shitty and sag that much.
No, my bad. It wasn't 1 inch. I haven't measured. I meant 1 inch the car lowered itself, but that doesn't have to do with the preload.
Old 07-24-2015, 05:12 AM   #58
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
No camber plate no care..
you drive a hard bargain, but I guess I'll recommend the penske and raceseng combo
The Following 2 Users Say Thank You to cdrazic93 For This Useful Post:
CSG Mike (07-24-2015), Sportsguy83 (07-24-2015)
Old 07-24-2015, 08:52 PM   #59
Sportsguy83
Drives: Limited BRZ
So I adjusted everything today. Cleaned the surfaces, adjusted preload and tightened them....
Now that I tightened them per the manual (I initially didn't use the manual because there were like 4 friends at home who were Tein owners and they just said bro just tighten them with the spanner wrench as much as you can by hand and you're good).
Now after tightening them via torque wrench, I definitely had not tightened them properly before. I still had way more to go.
thanks to all that replied and helped here! I think my issue is no more.
The Following 2 Users Say Thank You to Sportsguy83 For This Useful Post:
CSG Mike (07-24-2015), solidONE (07-24-2015)
Old 07-24-2015, 09:39 PM   #60
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
There's your problem... you used girly-man torques. Supposed to use dude-bro torque specs. j/k
The Following User Says Thank You to solidONE For This Useful Post:
Old 07-24-2015, 11:25 PM   #61
Sportsguy83
Drives: Limited BRZ
I agree
Now a new one. I started getting a clunk after a Saturday night drifting. I thought it was the not preloaded spring just bouncing around.....
tonight I still have it.
I had never had it before saturday. I checked the nuts on the top hat and they are tight. I might remove the strut tomorrow and check, but any ideas?
Old 07-25-2015, 04:43 AM   #62
Mars2
Drives: GT86, AUDI RS2, VW T5 R32 Vortech
Originally Posted by superleggera View Post
This show like I thought in te FLEX Z thread that the USA version is just different high and preload spring setting.
I just installed my Flex Z ordered in France also got that manual with those setting and I have put on USA setting. But it's a bit low for my road touching exhaust often I will rise it by 1cm.
Mars2 is offline   Reply With Quote
Old 07-25-2015, 02:08 PM   #63
solidONE
solidONE's Avatar
I agree
Double check all the hardware for girly man torques. If it still making noises, call cusco lol.
Old 07-25-2015, 09:49 PM   #64
Sportsguy83
Drives: Limited BRZ
Hahhahahaha
The top nut came loose... of course I had never taken it apart, so that was left as Tein left it....
Got a nice bruise in the hand from holding the spanner wrench while torquing the top nut down but was able to do it.
Old 07-26-2015, 05:00 PM   #65
solidONE
solidONE's Avatar
Hahhahahaha
Suspension components... actually any component on the car that will see a lot of vibration should always be rechecked for torque periodically. Or at least once after initial install. girly-man torque
Sportsguy83 (07-27-2015)
Tein Street flex JM'sFR-S562 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 05-09-2015 11:04 AM
Tein Street Flex installation Help eguzman6 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 02-08-2015 03:08 PM
WTB - Tein Street Flex and some LCA's Sugi Want-To-Buy Requests 1 01-25-2015 03:12 PM
WTB - Tein Street Flex and some LCA's Sugi Want-To-Buy Requests 1 01-25-2015 12:40 AM
25% Off Tein Street Flex's!!! RallySport Direct Brakes, Suspension, Chassis 0 12-31-2014 04:52 PM
