Old 07-24-2015, 02:35 AM   #1
medhead
Drives: 2014 BRZ
Maintenance and Warranty
Do I have to have a dealer do the maintenance to maintain my warranty?
medhead is offline   Reply With Quote
Old 07-24-2015, 02:44 AM   #2
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Check the warranty booklet that should be in the glovebox there should be a clause that specifically states that performing your own maintenance will not cause issues with warranty claims as long as you use the appropriate parts and do not cause any problems yourself.
ineedyourdiddly
humfrz (07-24-2015)
Old 07-24-2015, 02:53 AM   #3
You may wish to maintain a log that notes date, mileage, what fluids and parts (filters) were used.
strat61caster (07-24-2015)
Old 07-24-2015, 07:00 AM   #4
microbionic
microbionic's Avatar
Drives: 2013 Subaru BRZ
I am currently getting a new short block due to spun bearing, I presented them with my oil receipts as I order everything online, that was sufficient for Subaru to warranty it. it helps if you have the dealer do it, as they would have all the records. but, i am not driving 40 min away to get my oil changed...
microbionic is offline   Reply With Quote
Old 07-24-2015, 10:24 AM   #5
medhead
Drives: 2014 BRZ
Thanks all. I bought mine used (from Carmax) and it didnt come with the warranty manual and I haven't been able to find one online. Good to know I can do my own. Ill start keeping a log.
Warranty Work With Mods + Extended Warranty Wyattkb Issues | Warranty | Recalls / TSB 3 01-20-2015 04:23 PM
First warranty service maintenance vinh359 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 16 07-09-2014 01:54 PM
Complimentary maintenance + tuned ECU, will the dealership know and void my warranty? retrosmiths Issues | Warranty | Recalls / TSB 4 08-07-2013 07:27 PM
Maintenance or Service Warranty? or Both? JohnAyySays Issues | Warranty | Recalls / TSB 24 03-27-2013 02:04 PM
FR-S quick reference and warranty / maintenance guide is up pkny Scion FR-S / Toyota 86 GT86 General Forum 15 06-20-2012 11:33 PM
