Old 07-20-2015, 03:38 PM   #57
BlueSky
BlueSky's Avatar
Drives: 2015 Aozora BRZ
Looks like you got your hands full eh
How much did a wreck like that run you?
BlueSky is offline   Reply With Quote
Old 07-22-2015, 01:12 AM   #58
im_topher
Originally Posted by ZOMFGAARON View Post
Check the fuses under your dash if you haven't.
Checked all the fuses under the drivers side left foot area, the small fuse box with 3 rows. Is that the only one under there? They were all good.
Can anyone show me on a diagram where the starter is? id like to put the multimeter on there and see if its getting a signal. Also does anyone elses car go into gear without starting?
im_topher is offline   Reply With Quote
Old 07-22-2015, 02:03 AM   #59
http://www.ft86club.com/forums/showthread.php?t=8374
Old 07-22-2015, 02:49 AM   #60
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
Mind taking more pics overall of the car? This would be a good build. If not already.
Found it http://www.ft86club.com/forums/showthread.php?t=90987
Old 07-24-2015, 03:18 AM   #61
im_topher
Yeah ive been a little hesitant to update my build thread because i dont have much to say other than that i fixed one fuse lol.. itll be moving along quickly soon though because im running out of time and need to move past this little not starting problem
The Following User Says Thank You to im_topher For This Useful Post:
Packofcrows (07-24-2015)
Old 07-24-2015, 03:36 AM   #62
Speed2th
I love my series blue brz
Speed2th's Avatar
Drives: 2010 335d
Looks like your air box is missing. Where is maf sensor ? Without that, I don't think your car know how to breath
Speed2th is offline   Reply With Quote
Old 07-24-2015, 03:40 AM   #63
Fastbrew
Drives: 2014 Pearl White BRZ
Dude - you have a decent size project going there! Good luck
Fastbrew is offline   Reply With Quote
Old 07-25-2015, 12:17 PM   #64
Gords_zenith
Gords_zenith's Avatar
Drives: WRB BRZ Sport Tech
Originally Posted by im_topher View Post
OK, i pulled that fuse out and it was blown. I grabbed the 20 in the spare section, that one was blown too. I pulled the other 20 from here:
And put it in there, the second i seated it i heard a little pop, and i checked it, and it was dead.
I looked at the positive connection to the battery and the left side looks a little fucked, are those fuses in there? And is that one on the left/bottom blown?
Also that fuse is for the dome light, do you think fixing the dome light is going to help my problem?
I think what that is - is a fusible link, and if you read it it says 80 amps per side, so 160 total= which to me, means it's your starter circuit. Might want to check out the wiring on your starter and grounds for your engine.
Typically you will have a straight wiring setup to the starter with a switching relay in between from the battery because that will be the biggest amp draw of the whole car!
Edit: at second look, that blown link looks like it's for the starter alone, I'll look at my car and confirm!
Edit 2: just checked it's a 140 amp fusible link for the alternator!
Gords_zenith is offline   Reply With Quote
Old 07-25-2015, 12:26 PM   #65
Gords_zenith
oh also can anyone tell me what this is? Mine is smashed but i couldnt figure out what it was to order a new one.
This is a 80 amp fuse for the electric power steering like someone else mentioned.
Old 07-25-2015, 12:33 PM   #66
stugray
Drives: 2013 GBS BRZ Limited
Originally Posted by cjd View Post
Do be wary. It's 12v but can be deadly.
If you are a fuse maybe...
12VDC will not hurt a person.
Dont believe me? Go ahead and touch the + and - battery terminals with your hands and let me know what happens.
You can even lick them first.
We tend to think that it can hurt us when we see sparks.
It is more likely to hurt us when we jump to get away from an arc (kind of like a spider for me).
Not exactly what I was thinking, but I'll go with that
The Following User Says Thank You to stugray For This Useful Post:
Ultramaroon (07-25-2015)
Old 07-25-2015, 12:34 PM   #67
Gords_zenith
Check the AT 7.5 amp fuse near the top right of the diagram, could have something to do with the computer I detect it's in park or neutral to start.
Old 07-25-2015, 03:01 PM   #68
stugray
In my business the first thing to do is make a list of all the things that need to be true for the "system to reach a desired state" (starter cranks).
Then verify (dont assume) that each of these things are true and that it is being reported as true to the ECU.
This would usually require probing the signals that the ECU sees while exercising every option.
At work we have a Break Out Box (BOB) for every type of connector on every box in the system, so doing this kind of test is trivial.
For us hobbyists, probing every signal in the ECU connector while leaving it connected is difficult.
The pros would use a "Insulation displacement probe" which is a fancy way of saying "poke the DMM probe through the wire insulation".
The professional probes have a clip that supports the wire and a needle that penetrates the insulation.
If you could make yourself one of these it might help.
Then probe every signal that the ECU uses to verify "OK to start" and do not make any assumptions.
The #1 cause of failed electrical troubleshooting is making incorrect assumptions because you dont have the tools to verify.
That and - Write shit down :-)
Old 07-25-2015, 03:34 PM   #69
Spartarus
...Just add nauseum
Spartarus's Avatar
Drives: 2003 (AP1) S2000
Doesn't matter. It will start in limp mode with MAF disconnected completely
There are many ways to displace.
-Spartarus
Spartarus is offline   Reply With Quote
The Following User Says Thank You to Spartarus For This Useful Post:
Sportsguy83 (11-09-2015)
Old 07-25-2015, 06:18 PM   #70
cjd
cjd's Avatar
Drives: 2017 BRZ
I was thinking what it can do with respect to fire... Or the battery being direct shorted with something that doesn't act like a fuse. It's the amperage potential.
The Following User Says Thank You to cjd For This Useful Post:
stugray (07-25-2015)
Battery dies, push start car in gear.... push start button rhythmM Scion FR-S / Toyota 86 GT86 General Forum 7 02-27-2014 06:06 PM
No maf no start? Silverdub Engine, Exhaust, Transmission 14 03-30-2013 11:21 AM
Pop-Start with Push-Button Start cmspooner BRZ First-Gen (2012+) — General Topics 5 03-22-2013 02:45 PM
Push Start Rough Engine Start Up joergasm Engine, Exhaust, Transmission 3 12-12-2012 03:44 AM
Car Won't Start schtebie Issues | Warranty | Recalls / TSB 25 10-15-2012 04:06 PM
