Old 07-20-2015, 01:37 PM   #547
Andreas83
Andreas83's Avatar
Drives: 2013 Subaru BRZ
Originally Posted by grant View Post
did anyone ever do a review on the reimax pump gears? I know Element has their fix that they hold closely to their chest (rightfully so, and don't blame you for keeping your secret) but like others interested in a weekend project/insurance policy, until motor build funds are sourced it would be nice to see if there's a cheaper quick fix/band-aid like the gears and oil coolers
My car is up and running with the reimax pump gears.
I will try and get some numbers when i go back onshore.
English is my 2. language. Typos might occur.
2013 BRZ, kraftwerks supercharged.
Skunk2 Ultra radiator with oilcooler
KW v3 - enkei 17x9 with PSS
Andreas83 is offline   Reply With Quote
The Following 8 Users Say Thank You to Andreas83 For This Useful Post:
BatStig (07-20-2015), celek (07-20-2015), ChrisD (07-20-2015), GhostOp86 (07-21-2015), grant (07-20-2015), sato (07-20-2015), spitfire481 (07-20-2015), Ultramaroon (07-20-2015)
Old 07-20-2015, 03:27 PM   #548
D K
Stig's dark passenger
Originally Posted by Element Tuning View Post
I'm running a pretty big core now but I did look into massive radiator size coolers like used in Nascar. You either spends thousands on that or on a dry sump and the dry sump won out for me.
How did it go at vir?
D K is offline   Reply With Quote
Old 07-20-2015, 09:13 PM   #549
BatStig
Some say.....
BatStig's Avatar
Drives: 2007 Subaru Impreza 2.5i
This is EXACTLY what I have been waiting for. Thank you very much. I can't wait to see your results!
BatStig is offline   Reply With Quote
The Following User Says Thank You to BatStig For This Useful Post:
grant (07-20-2015)
Old 07-23-2015, 03:59 AM   #550
Hector
Drives: Toyota GT86 Satin-White-Pearl
Why should they keep their fix secret? I think it would be most positive to post the solution and proove their skills. There are a lot of people here that would acknowledge that. That would also help the reputation of the FA20 being a not so bad engine to get past 400HP!
Hector is offline   Reply With Quote
The Following User Says Thank You to Hector For This Useful Post:
Kris86 (07-19-2016)
Old 07-23-2015, 05:56 AM   #551
Calum
That Guy
Drives: 2013 asphalt FRS MT
Because if they release the info then every half assed engine builder out there will copy it. There's no secret sauce to this stuff, they just went through the trial and error to find the right combination. That trial and error likely cost them a ton of money and time.
The Following 5 Users Say Thank You to Calum For This Useful Post:
BatStig (07-24-2015), grant (07-23-2015), Kris86 (07-19-2016), spitfire481 (07-24-2015), Trac Toy (07-23-2015)
Old 07-24-2015, 02:36 AM   #552
sam69
Drives: GT 86
When are you due to get back onshore ?
sam69 is offline   Reply With Quote
Old 07-24-2015, 10:09 PM   #553
Darryljr11
Sideways and Smiling!
Darryljr11's Avatar
Drives: Scion FR-S
Anyone else here running Element Tunings Built longblock in their twin?
Element Tuning 10:1 Pro Comp Long Block, Ptuning SS GT3076R turbo kit, Exedy Stage 2 Clutch, and a bunch of other stuff
Darryljr11 is offline   Reply With Quote
Old 08-10-2015, 03:13 AM   #554
sam69
Drives: GT 86
Just bumping this in the hope to get feedback on the reimax pump gears
The Following 2 Users Say Thank You to sam69 For This Useful Post:
ajc209 (08-10-2015), Kris86 (07-19-2016)
Old 08-10-2015, 06:11 PM   #555
ChrisD
ChrisD's Avatar
Drives: GT86
Yeah I'm still interested too. Seriously considering getting forged pistons and rods soon so while the engine is out I guess it would make sense to do the reimax gear at the same time if its actually going to help at all, but I don't want to bother doing it if it'll make no difference
My GT86 build so far:
AVO Stage 4 Turbo, Carrillo forged con rods, 10:1 CR Carrillo pistons, AVO 3 inch turbo back exhaust, Helix clutch, TheDriveShaftShop drive shafts, lightweight flywheel, NamelessPerformance hydraulic hand brake, KW V3 coilovers... and lots of other little bits
ChrisD is offline   Reply With Quote
The Following User Says Thank You to ChrisD For This Useful Post:
sam69 (08-10-2015)
Old 09-01-2015, 09:56 AM   #556
celek
Resident Gear Head
celek's Avatar
Update on the Reimax???
Bump
celek is offline   Reply With Quote
The Following User Says Thank You to celek For This Useful Post:
Kris86 (07-19-2016)
Old 09-01-2015, 10:15 AM   #557
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
Well, 3 weeks ago my car shut off while idling. 2 cranks and the battery died. Subaru had the car at a dealership 75 miles away and we just rescued it on Saturday as Subaru is currently refusing to work on it (SoA. The dealership wants to get the car fixed).
Anyway, when we were picking it up at the dealership, they told us to fire it up and it sounds like a spun bearing. I'm not sure if this was an inherent oiling issue, but we are most likely going to tear the block down in two weeks unless the dealership convinces Subaru to cover it (the service manager is still working on it).
If we do end up rebuilding the block, are there any suggestions you have for it while we have it apart? I'm thinking better valve springs wouldn't hurt if they can be sourced. I know a cam shaft probably still isn't available. Anything that would help the motor survive?
Luckrider is offline   Reply With Quote
Old 09-01-2015, 04:52 PM   #558
FRS Justin
Drives: 2013 Asphalt FRS
If you need a rebuild I suggest the following:
West coast: Outfront Motorsports
East coast: Element Tuning
Central: Accelerated Performance
I have spoke to all 3 of these shops and they are top notch...
Good luck
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
The Following 3 Users Say Thank You to FRS Justin For This Useful Post:
celek (09-01-2015), civicdrivr (09-01-2015), Kris86 (07-19-2016)
Old 09-01-2015, 05:11 PM   #559
nelsmar
There are multiple valve springs available. I used shelf units on mine well over a year ago... And there are multiple cam setups available right now that can use stock springs or more aggressive cams for cars that have a more aggressive head setup...
My flickr - Canibeat
Local magazine scout
Old 09-01-2015, 05:26 PM   #560
Luckrider
Luckrider's Avatar
I haven't really been watching the forums for several months now and last I heard, there were some new springs, but cams would have to be custom ground. I don't want to go crazy (a junkyard motor right now feels tough on the wallet) but if there are reasonable upgrades that can be done NA that make sense to do (like a profile that safely revs and actually makes power to 8,000rpm) I think it would be nice to do while the motor is apart.
About 15 minutes I got the call. Subaru will pay to have the motor disassembled at any dealer of my choice (since the car is now sitting back in my driveway) to the point of failure to determine what happened. Then they will send out their engineer and tech to determine if they will fix the issue. The problem is, they just did this to the STI they looked at and denied the warranty so that car is sitting with a disassembled motor that's in pieces. They will not pay to put it back together if it is not covered under warranty and after the way SoA has continually jerked me around, this is my fear for my car.
The Following User Says Thank You to Luckrider For This Useful Post:
strat61caster (09-01-2015)
FA20 Engine component photos Crawford FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 89 02-22-2016 03:31 AM
FA20 Engine component photos Crawford Engine, Exhaust, Transmission 46 01-26-2015 06:19 AM
Engine Hardware, Gaskets, & Bearings Oh My; All on sale at FR Sport. FRSport.com Engine, Exhaust, Bolt-Ons 0 01-10-2014 01:33 PM
FA20 Le Mans Race Engine SilverSkyline210 Engine, Exhaust, Transmission 11 11-18-2013 12:24 AM
