Old 07-23-2015, 10:40 PM   #6455
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Originally Posted by ybotspawn View Post
Hey, so yeah... I tried that. I'll detail a bit more, but it will slow burning. The redline fluid is real shit, honestly. I'd recommend using the Jon Bond specifically formulated supercharger oil. It runs a little cooler but is also a bit thinner. The kicker about it being thinner is if your seals are a little toasted you'll burn oil at a faster rate.
Why not this oil?
JB PERFORMANCE SUPERCHARGER OIL WITH TRIBODYN
It's made for gear-driven twin-screw superchargers.
Old 07-23-2015, 10:42 PM   #6456
ybotspawn
ybotspawn's Avatar
Drives: 13 Subaru BRZ
Originally Posted by Draco-REX View Post
Why not this oil?
Thats what I'm talking about, im switching to that with my rebuild. The only slight problem to consider is that its thinner than the 90w. If you have burning oil issue now, this MIGHT increase it.
Heres the question.. Is your blower still under warranty? Yes? Use the 90w, otherwise use the Jon Bond oil you posted just above.
ybotspawn is offline   Reply With Quote
Old 07-23-2015, 11:04 PM   #6457
xjohnx
Grip>Slip
xjohnx's Avatar
Ah, i ordered the "high performance" one listed on his Sprintex page ( http://jonbondperformance.com/index....ex&cPath=10_44 ). I figured more expensive meant higher quality. I wonder what the actual difference is between the two? I'll fire off an email to him tonight to see what he says.
Old 07-23-2015, 11:06 PM   #6458
ybotspawn
ybotspawn's Avatar
90w is thicker. The Jon Bond stuff is thinner and has a custom formulated mixture of oil and tribodyne
Old 07-24-2015, 01:14 AM   #6459
Ethan
Drives: Subaru BRZ
Has anyone tried to fit the Top Secret hood over the innovate/sprintex SC? This is the one I am talking about: http://www.fastscions.com/Scion-FRS-...bon-Fiber.aspx
Ethan is offline   Reply With Quote
Old 07-25-2015, 03:04 AM   #6460
Ethan
Drives: Subaru BRZ
Well, I ordered it. I will post pics.
The Following User Says Thank You to Ethan For This Useful Post:
Chad86 (08-31-2015)
Old 07-25-2015, 03:05 AM   #6461
Ethan
Drives: Subaru BRZ
Here is what it looks like on someone else's car:
http://www.fastscions.com/images/pro...rethoodfrs.jpg
Old 07-25-2015, 03:10 AM   #6462
Cross
It's the Mad Cow
Cross's Avatar
I have been looking at a hood to help cool my Innovate/Sprintex kit.
Let me know what you think of this one, I like this one:
http://www.fastscions.com/seibon-fa-...SCNFRS-FA.aspx
Sent from my SM-G920V using Tapatalk
Old 07-25-2015, 07:42 AM   #6463
ybotspawn
ybotspawn's Avatar
Before you go buying hoods... What temp is your blower reaching? Go buy an infrared heat gun for $20 and measure heat after a hard run.
Old 07-25-2015, 11:39 AM   #6464
Cross
It's the Mad Cow
Cross's Avatar
I don't care if it's within spec, I want it cooler.
The Following User Says Thank You to Cross For This Useful Post:
Ultramaroon (07-25-2015)
Old 07-25-2015, 03:02 PM   #6465
ybotspawn
ybotspawn's Avatar
Then ceramic coat.
Old 07-25-2015, 03:03 PM   #6466
Cross
It's the Mad Cow
Cross's Avatar
While that may be something I do it's not going to be the only thing thanks though.
Old 07-25-2015, 03:07 PM   #6467
ybotspawn
ybotspawn's Avatar
Are you intercooled?
Old 07-25-2015, 03:08 PM   #6468
Cross
It's the Mad Cow
Cross's Avatar
No I'm running E85
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
