Old 07-09-2015, 09:54 PM   #127
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
Well we are up to no good. Thanks to full blown for the adaptor plate. And no, a v160 is not what's being bolted up
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
The Following 3 Users Say Thank You to spitfire481 For This Useful Post:
IBill4You (07-10-2015), M1K3 (07-10-2015), Sportsguy83 (07-09-2015)
Old 07-10-2015, 12:03 AM   #128
IBill4You
Drives: 2015 Subaru BRZ
Please tell me that isn't your built motor?
IBill4You is offline   Reply With Quote
Old 07-10-2015, 09:58 AM   #129
spitfire481
Drives: 2JZ FRS
Nah, spare stock motor someone blew up
MoTeC
Build Thread
@spitfire481
The Following User Says Thank You to spitfire481 For This Useful Post:
Old 07-14-2015, 11:50 AM   #130
BRZGM3
BRZGM3's Avatar
Drives: CBS brz limited
Crossfire gxp trans?
Sent from my SAMSUNG-SGH-I317 using Tapatalk
BRZGM3 is offline   Reply With Quote
Old 07-22-2015, 12:22 AM   #131
JD86
Drives: 2013 Toyota 86 GT
Originally Posted by spitfire481 View Post
Full blown fuel return system going in next week with ecutek fuel pressure input. Tune on Friday
Your full blown return fuel kit, do you need to run their fuel rails with it? Also are the black fuel rails the default colour on their website it looks like purple or polished is the default and I'm trying to keep my engine bay bling to a minimum.
JD86 is offline   Reply With Quote
Old 07-22-2015, 12:53 AM   #132
Sammakko
Bilge monkey
Sammakko's Avatar
Drives: '13 BRZ, 82 starlet
Spec 2+ clutch, boost controller, Toyota emblem steering wheel badge and traction control off on startup mod complete. Busy weekend. Injectors, map sensor come in this week then tune in a couple weeks once the clutch is broken in
interested to see how long before your Spec clutch grenades.
edit.. oops, i'm sure i'm waaaay behind
Sammakko is offline   Reply With Quote
Old 07-22-2015, 08:06 AM   #133
spitfire481
Drives: 2JZ FRS
I made 400whp 350wtq for a year with that clutch with the avo kit. It's in another car and still fine
MoTeC
Build Thread
@spitfire481
Old 07-22-2015, 08:07 AM   #134
spitfire481
Drives: 2JZ FRS
They came black. Contact LJ at full blown. You should be able to get all black rails with all black fittings as well
MoTeC
Build Thread
@spitfire481
Old 07-22-2015, 08:09 AM   #135
spitfire481
Drives: 2JZ FRS
Got the driveshaft shop axles installed yesterday
MoTeC
Build Thread
@spitfire481
R2RO (10-25-2015), SkAsphalt (07-25-2015), Sportsguy83 (07-22-2015)
Old 07-24-2015, 11:51 AM   #136
spitfire481
Drives: 2JZ FRS
washed for the first time in months. finally back on the road. stock trans and stock clutch for the rest of the year it looks like. at least i can drive it, just cant make power
MoTeC
Build Thread
@spitfire481
Lorico (10-16-2015)
Old 07-24-2015, 12:55 PM   #137
Carlos_M
Carlos_M's Avatar
Drives: 2014 BRZ Limited
I believe I have seen this car twice, once at Pubdog then again at Brady's. These pictures do it no justice lol. Awesome build!
Carlos_M is offline   Reply With Quote
Old 08-14-2015, 10:52 AM   #138
spitfire481
Drives: 2JZ FRS
A little hks hi-power muffler action. Just because we had it laying around haha
MoTeC
Build Thread
@spitfire481
mrk1 (08-22-2015)
Old 08-14-2015, 10:54 AM   #139
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
All I could think of was a supra with that shot^^.
Car looks great. Keep up the good work
The Following User Says Thank You to DustinS For This Useful Post:
spitfire481 (08-14-2015)
Old 08-21-2015, 11:59 PM   #140
spitfire481
Drives: 2JZ FRS
So we had a good time out at 86expo. If I knew we were going to get some free track time on summit main I would have brought non-drag radial rear tires to swap out lol. The et streets worked good enough to have some fun though. Also, we have a precision ball bearing 6466 turbo and FIC 1650cc injectors on the way. Gonna make some more power to balance out the loss from the new trans this winter. Should be a good time. Also playing around with a molded in rocket bunny v3 spoiler
MoTeC
Build Thread
@spitfire481
The Following 2 Users Say Thank You to spitfire481 For This Useful Post:
mrk1 (08-22-2015), SkAsphalt (08-24-2015)
God's Build GodSays Member's Car Journals 13 04-17-2013 01:31 PM
My build... well some of it cruzinbill Electronics | Audio | NAV | Infotainment 41 04-01-2013 04:02 PM
STX build Evil86 Tracking / Autocross / HPDE / Drifting 2 01-08-2013 03:40 PM
My BRZ build brztj Mid-Atlantic 3 09-08-2012 05:52 PM
