Old 07-21-2015, 03:56 PM   #1513
nelsmar
Originally Posted by AppleSauce View Post
yes UEL header is what i meant to say. if i go without tune for a little while will it damage anything? if i autocrossed it untuned? im regretting buying an automatic and am looking to trade mine for a manual. wondering if i can go without tune so i can just swap back all the oem parts when i switch vehicles or would i also be able to do that with a tune anyways? (im thinking thats not likely possible?)
Damage? highly unlikely it will damage anything. The ecu is conservative and loves to pull timing when it see's an issue. Hoewever you might throw a check engine light and i never verified if that code actually changes the performance of the car.
As for the tune with ECUTek in odd scenarios such as that typically they will allow you to remove the license from the car (YOU HAVE TO REMOVE IT FIRST!) and after thats proven that it was removed and that you prove you purchased a replacement car or that you had yours swapped out for something like a warranty issue they will re-issue a new license. OFT is also transferable to the new car by unpairing and reverting the car to stock.
Your tuner should be able to help you with either of these setups =)
Also moving your tune from auto to manual is just a few minute job so I'm sure your tuner would work something out with you.
My flickr - Canibeat
Local magazine scout
Old 07-21-2015, 03:59 PM   #1514
UnOvertime
UnOvertime's Avatar
Drives: Firestorm FR-S AT
I ran mine without a tune for almost 6 months, no damage. The new header will make your car throw a CEL and eliminate your cruise control so if you don't mind that you can run without a tune no problem.
If you really want the manual then put on your header and run without a tune until you get it and swap everything over instead of paying twice for a tune. Besides when you get the manual tune you get additional options (if you go Ecutek of course) that the automatic simply doesn't get like launch control and flat foot shifting.
Be advised if you are going with anything other than the header, the front pipe is different between the manual and the automatic so save your money and get the manual front pipe if you truly intend to go full header back exhaust.
UnOvertime is offline   Reply With Quote
Old 07-21-2015, 07:05 PM   #1515
AppleSauce
Drives: FR-S black. Buell XB12s 25th anniv.
i already own the nameless overpipe/frontpipe combo i purchased last year. i thought it worked with both mt and at?
AppleSauce is offline   Reply With Quote
Old 07-21-2015, 08:07 PM   #1516
UnOvertime
UnOvertime's Avatar
I think I recall nameless came out with an op/fp combo that was a universal fit. JDL has a different front pipe for the manual and automatic. The difference is minimal, but there was a difference....I found out the hard way when they shipped me the manual one instead.
Old 07-25-2015, 10:34 AM   #1517
AznKirby
Are you 20/20?
AznKirby's Avatar
Drives: Hopes and dreams
How long of a wait am I looking at if I ordered about 2 weeks ago?
I bought an uel header, titanium coated.
Thanks!
2014 FR-S Monogram
2005 Acura RSX Type-S
IG: @MonKehC
The Following User Says Thank You to AznKirby For This Useful Post:
AREN (07-27-2015)
Old 07-27-2015, 09:46 PM   #1518
JB86'd
JB86'd's Avatar
Drives: JAWS
Thanks!
I ordered mine over a month ago and I'm still wondering the same thing
JB86'd is offline   Reply With Quote
Old 07-27-2015, 11:50 PM   #1519
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Just in case you missed from JDL's website for each item:
Special Order Notes
All manifolds, hot part kits, custom intercooler kits, and full turbo kits are built upon order unless otherwise stated.
If you opt for coating the wait time will be 4-5 business days after header completion.
JDL built to order manufactured parts are non-refundable.
Please allow 4-6 weeks for completion of said parts.
Build times are also subject to change without notice depending on current workload
My bold.
Old 07-28-2015, 02:40 AM   #1520
JB86'd
JB86'd's Avatar
Drives: JAWS
Special Order Notes
My bold.
I was more trying to make a point that it may take some time, and I haven't received a real update in over a month. By the way, I was quoted 2-3 weeks when I ordered.
But I'm trying to not be impatient, I know the wait is more than worth it, and top notch products take time. JDL
Old 07-28-2015, 08:13 AM   #1521
TatharPallan
Drives: 2015 Subaru Blue Series - Pearl
I was also quoted 2 weeks for the header and resonated FP/OP combo pipe . A few days after placing my order i decided to have everything black thermal coated . I knew the 2 week timeline was unrealistic as i placed my order a few days before the July 4th Holiday. We are on 4 weeks now and i'm sitting here twiddling my thumbs waiting for the delivery guy
2015 BRZ Series.Blue CWP (K1X) - JDL UEL Header, 3" JDL Res FP, 3" JDL OP, 3" Perrin Res Cat back, 3" Perrin BigMAF Intake/Inlet tube, Perrin Light Weight Pulleys (AC, Water Pump, Crank) - Moto-East FFK - E85 Tuned by HRI - ECUTEK - Eibach Pro-Kit Lowering Springs
TatharPallan is offline   Reply With Quote
Old 07-28-2015, 03:14 PM   #1522
JDLAutoDesign
JDLAutoDesign's Avatar
Drives: 13 FRS
We were down a fabricator for the past 2 weeks so that put us back a bit. Headers are on the current workload being built. They will start shipping the end of the week as they are complete. Give us a call if you have any questions.
Thanks,
Ronnie
JDLAutoDesign is offline   Reply With Quote
The Following User Says Thank You to JDLAutoDesign For This Useful Post:
AREN (07-28-2015)
Old 07-29-2015, 08:55 PM   #1523
Turdinator
Señor Member
Turdinator's Avatar
@JDLAutoDesign I just noticed on your website you have a recirculated catch can. It looks nice! Will you do a new thread about it? Mostly I am curious about how it is baffled/filtered and whether it will fit a RHD 86.
1974 TA22 Celica
2013 86 GT
Old 07-30-2015, 11:41 AM   #1524
Aegis3425
Drives: 2013 Asphalt FRS
Catted UEL Header without a tune
The catted UEL header is designed to be able to run without a tune just fine correct?
Aegis3425 is offline   Reply With Quote
Old 07-30-2015, 12:48 PM   #1525
kch
Senior Misanthrope
kch's Avatar
In theory, yes. However, even catted aftermarket headers have thrown CELs on occasion. You would also get much more out of the header with a tune.
Old 07-30-2015, 02:21 PM   #1526
TatharPallan
Just got word my parts are shipping today
The Following User Says Thank You to TatharPallan For This Useful Post:
JB86'd (07-31-2015)
JDL Auto Design ft_sjo User/Vendor/Sponsor Reviews, Feedback, Comments 58 04-28-2017 10:13 AM
JDL Auto Design alexand3r User/Vendor/Sponsor Reviews, Feedback, Comments 4 12-11-2013 12:05 PM
New Scion FR-S products by Coverking are now at TAP Auto parts TAP Auto Parts Interior Parts (Incl. Lighting) 9 06-06-2013 07:43 AM
Check out some of the new products from Auto Finesse DetailersDomain Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 2 05-08-2013 08:42 AM
JDL Auto Design...What We Do JDLAutoDesign Announcements, Contests, Giveaways 21 10-30-2012 09:05 PM
