View Poll Results: Have you blown your stock motor with boost?
Yes complete failure needs rebuild 32 5.39%
No been boosting and running strong 188 31.65%
Nope because I am not boosting my motor 374 62.96%
Voters: 594. You may not vote on this poll
Old 07-21-2015, 03:15 AM   #435
hotfootpowder
Drives: Toyota 86 G Spec
I may hv blown my engine. I hv a Sprintex SC tuned to 220ps, with everything else stock. Yesterday i sent my car to install an hks oil cooler kit. Picked it up just now and was driving about 15km with no problems. Suddenly my temp starts to rise gradually and next thing i know when i stop at a traffic light the engine just died. Tried to start but the engine seems heavy and i can hear klanking sound coming from the engine. Currently waiting for tow truck. I hope it's not bad 😖
Sent from my D5503 using Tapatalk
hotfootpowder is offline   Reply With Quote
Old 07-21-2015, 03:26 AM   #436
SPCorBUST
SPCorBUST's Avatar
Fingers crossed for you!
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East
Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church
Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor
Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor
SPCorBUST is offline   Reply With Quote
Old 07-21-2015, 05:06 AM   #437
tostidos
Drives: 07 Tacoma (Race Truck)
This thread solidifies my idea of swapping the motor.
tostidos is offline   Reply With Quote
Old 07-21-2015, 05:34 AM   #438
hotfootpowder
Got a call from mechanic. Confirm the engine needs to be rebuild. Not sure why yet, but one of the reason could be the engine oil. I changed to a new engine oil, which is petronas 0w-40 high grade oil. Chances are the oil is too thin, hence the blown engine.
Old 07-21-2015, 06:44 AM   #439
s2d4
s2d4's Avatar
Sounds like oil leaked but you'd never know if it's the same mechanic
The Following User Says Thank You to s2d4 For This Useful Post:
Astroboy (07-21-2015)
Old 07-21-2015, 08:48 AM   #440
Astroboy
Astroboy's Avatar
Drives: None
To thin, or to thick?
Sent from my LG-D850 using Tapatalk
Astroboy is offline   Reply With Quote
Old 07-21-2015, 10:49 AM   #441
hotfootpowder
Hmmm... This is where i get confused. A lot of guys here mention 0w-20 or 0w-30 to be the right weight for supercharged engines. But a lot of the mechanics at my place recommends thicker oil for supercharged engines. I also checked hks website for reference, and they recommend 0w-42 for their supercharged engines. So which is which :confused:
Old 07-21-2015, 10:56 AM   #442
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
The higher the number, the thicker the oil. 0w-20 is what Toyota/Subaru recommends, however it is (IMO) far too thin. I run German Castrol 0w-40 on my NA car.
Parting out HERE
civicdrivr is offline   Reply With Quote
The Following User Says Thank You to civicdrivr For This Useful Post:
Old 07-21-2015, 11:57 AM   #443
Astroboy
Astroboy's Avatar
Drives: None
Any problems with the thicker oil?
Old 07-21-2015, 12:34 PM   #444
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
Subaru only recommends 0w20 for NA. all turbo motors from subaru runs 5w30, and I mean all... guinea pig all you want with 0w20 and boost.
http://www.subaruofkeene.com/synthetic-oil.htm
GsxrMe is offline   Reply With Quote
The Following 2 Users Say Thank You to GsxrMe For This Useful Post:
Chad86 (07-21-2015), civicdrivr (07-21-2015)
Old 07-21-2015, 02:29 PM   #445
Astroboy
Astroboy's Avatar
Drives: None
Avo stated a good weighted 0w20 would be fine with their turbo and tune
Old 07-21-2015, 02:59 PM   #446
MAPerformance
Drives: Asphalt FRS
I have over 20k miles of 0w-20 oil on my boosted FRS. No issues what so ever running in -10 degree winters, and 95 degree summers.
MAPerformance is offline   Reply With Quote
The Following 2 Users Say Thank You to MAPerformance For This Useful Post:
Astroboy (07-29-2015), raven1231 (07-21-2015)
Old 07-21-2015, 03:10 PM   #447
AVOturboworld
We've run up to 10w60 - on our dedicated race car. But for a street and light track duty car, I will stick to recommending 0w20. The way Subaru put together this particular FA20 (which is indeed similar, but not the same as the FA20DIT) really points to a lighter weight oil to get through the oil passages at the front correctly, along with working with the bearings well.
I've had no issues with the 0w20, especially the better ones like joe gibbs make, over the last 42,000 miles boosted. If I was going to track it full time I would recommend a slightly heavier weight oil.
The Following User Says Thank You to AVOturboworld For This Useful Post:
Old 07-21-2015, 03:24 PM   #448
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
None thus far. As always, YMMV.
My previous engine was run on 0w-20 or 5w-30.
Parting out HERE
How much HP can the stock motor handle? FullTuneZN6 Engine, Exhaust, Transmission 34 11-16-2017 01:22 AM
Full Blown 521hp Stock Motor @ 20psi FullBlown Forced Induction 276 08-31-2016 02:05 AM
FBM 604Hp 472Tq -- Stock Motor Stage 2 Turbo Kit FullBlown Forced Induction 414 07-14-2014 09:52 PM
FRS300 Rebuild Has Begun..Blown Motor to Built Monster FA20Club.com Forced Induction 917 10-20-2013 06:26 AM
Highest HP on stock motor using only 93/94 octane? hmong337 Forced Induction 11 09-09-2013 10:53 AM
