Old 07-16-2015, 09:05 PM   #211
FLIPs_FR-S
KCCO
FLIPs_FR-S's Avatar
Drives: 2013 Raven Scion FR-S, AT
Originally Posted by Scuba86 View Post
what about with springs around a 1 inch drop?
Should be fine my fronts are 19x8.5 +45 and I have no issues. I am on 1.25" lowering springs. 225/35 19 tires
Sent from my SAMSUNG-SM-N910A using Tapatalk
Alabama state head for Southeast 86
https://www.facebook.com/groups/Southeast86/
FLIPs_FR-S is offline   Reply With Quote
Old 07-17-2015, 12:53 AM   #212
Fakk
Drives: 13 BRZ Limited 6MT CBS
I'm on ST coilovers w/ 18x9.5 +40, 255/35 all around. Measured today after settling for a week, I dropped about 1.2" and I have no visible rubbing, although I think my front tires hit the fender once, I hit a shitty bump.
Fakk is offline   Reply With Quote
Old 07-17-2015, 07:52 PM   #213
Mikey2style
Drives: FR-S Release Series 1.0
Originally Posted by Kami Speed View Post
Yes a newer size. They made so that the FRS could have concave face in the front.
Are there are any info/pictures on that size (18x8.5 +42)?
I was trying to do some research but found no info on that specific size nor have I even seen pictures of anyone with that size.
I really want these rims but I don't want to purchase coilovers; I'm sure I'm not the only one.
Mikey2style is offline   Reply With Quote
Old 07-20-2015, 07:39 PM   #214
Scuba86
Drives: 2014 FR-S Monogram Raven
What would be the ideal tire size if I were to run 18x8.5 +42 all around with a 1 inch drop so they sit flush and no stretch on the tires? Would 245/35/18 fit or would I need to go smaller?
Scuba86 is offline   Reply With Quote
Old 07-21-2015, 02:23 AM   #215
Fakk
255/35 on 18x9.5 has just the slightest amount of stretch. I feel like 245/35 might be the slightest too wide, but I'm not sure. I am also not a pro
http://www.frsproject.com/tire_size.php
Old 07-21-2015, 08:30 AM   #216
ZZT86
ZZT86's Avatar
Drives: BR86
You're not the only one - I'm in the same boat although getting confirmation that there's no issue after fitting is another story. By my calculation there's 21-22mm clearance stock on the fronts, this size wheel will net you an inset of 13mm which means you'll be left with 8-9mm clearance depending on tyre before lowering - enough ?
Rears are a non issue as there's plenty clearance.
Edit: Have spoken to 3 local Rays wheels suppliers & ALL are 100% confident that there will be NO rubbing on this car with stock struts even 1" lowered using the 18x8.5+42 size, one of them will even guarantee it ! I guess it's fine then.
ZZT86 is offline   Reply With Quote
The Following User Says Thank You to ZZT86 For This Useful Post:
Mikey2style (08-01-2015)
Old 07-28-2015, 12:10 AM   #217
Scuba86
Originally Posted by Jive Turkey View Post
its really preference.
there are 255's out there that will fill this out just as much as the tires i have. 255 should still be find though, and not be stretched. assuming you're talking 255/35 though. i think a 40 sidewall will just be too big. either way, as you can see with my car, you can still be fully functional running this kind of setup.
What would be the ideal setup to run 18x9.5 +40 square closest to your setup without rolling fenders. Im considering fortune auto 500 and bilstein b14 coilovers would I need camber plates or LCA's? What brands would you recommend for these?
Old 07-28-2015, 09:35 PM   #218
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
i honestly have no clue what you can run without rolling fenders. if you don't want to deal with rubbing done go bigger than a 255/35, even then you may rub.
i don't consider fortune auto a good coilover, bilstein will prevail in my book every time over fortune and once you get into their custom built stuff you open up yourself to much better option than that such as AST, MCS, etc etc... it all depends on your budget.
consider RCE tarmac zero with upgraded swift springs/stiffer rates, or pick up set of KW v3's for a good price and you can simply use your stock tophats for V3's since the front is notched and you can pull camber that way.
i personally do not have camber plates but do have LCA. if your'e on a budget get SPC rear arms. if you want the best of the best get SPL.
if you must have tophats vorshlag, MSI, and raceseng are all quality options. avoid whiteline com-c like the plague.
Jive Turkey is offline   Reply With Quote
Old 07-28-2015, 09:36 PM   #219
Jive Turkey
the tuna, no crust.
245/40.
Old 07-31-2015, 07:12 PM   #220
Terran
Terran's Avatar
Drives: Raven FR-S 6MT
I'm on the same, ST coilovers, 18x9.5 255/35/18, dropped about 1.5". Only visible rubbing I saw when I jacked it up to change tranny fluid, is a small spot on the inner fenderwell probably from going full lock. No fender issues from what I can tell.
Terran is offline   Reply With Quote
The Following User Says Thank You to Terran For This Useful Post:
Fakk (08-02-2015)
Old 08-01-2015, 12:49 PM   #221
Mikey2style
So glad they made 18x8.5 +42 so I don't have to deal with rubbing or getting coil overs. Now just to find the best price for that size...
Old 08-01-2015, 04:13 PM   #222
SoCalArgento
Drives: 2014 Argento FRS
Any idea where they might sell those wheels in that particular spec?
SoCalArgento is offline   Reply With Quote
Old 08-01-2015, 05:14 PM   #223
Scuba86
evasive motorsports sells them on there website or you can email maximal performance or infamous performance on here.
The Following User Says Thank You to Scuba86 For This Useful Post:
Old 08-07-2015, 08:14 PM   #224
godzuki
godzuki's Avatar
Drives: frs
I'm having a hard time deciding on whether to go with 18x9.5 +40 or 18x8.5 +42 in the rear. It's hard for me to tell how much the 9.5 +40 wheels stick out from flush (poke?). I've seen plenty of above pics of the fronts, but does anyone have pics taken from above for the rears in 9.5 +40s?
godzuki is offline   Reply With Quote
gramlights 57xtreme, toyo tyres
Wheel Directory: Gram Lights 57Xtreme 17x9.0 +40 L8Apex Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 71 08-05-2023 10:20 PM
Wheel Directory: Gram Light 57Xtreme: 18x8.5 +33 / 18x9.5 +40 jadewbj Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 378 06-26-2017 06:57 AM
Wheel Directory: Gram Lights 57Xtreme 19x9.5 +43 RavSpec Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 31 12-04-2014 11:56 PM
Wheel Directory: Gram Lights 57Xtreme 17x7.0 +42 MVJ1975 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 10-05-2013 03:29 AM
Wheel Directory: Gram Lights 57Xtreme 18x7.5 +40 quik1987 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 09-05-2012 01:44 PM
