Old 07-20-2015, 11:50 PM   #15
Devante
Crescent fresh at best.
Devante's Avatar
Drives: 2016 Scion FR-S - Asphalt
I've read great things about 303 and Gummi Pfedge. The latter being hard to find.
Will see if O'Reilly's near me has 303. Thanks.
Devante is offline   Reply With Quote
Old 07-20-2015, 11:58 PM   #16
WhiteFRS69
WhiteFRS69's Avatar
Drives: 2014 Scion FRS
just wait till OP gets his first paint chip on the front bumper....
The Following 4 Users Say Thank You to WhiteFRS69 For This Useful Post:
PICKLEBOY (07-22-2015), Purdue FR-S (07-21-2015), shifter907 (07-21-2015), Tcoat (07-21-2015)
Old 07-21-2015, 12:19 AM   #17
Originally Posted by Devante View Post
So I've had my car less than a week. A 2016 model. The weather stripping that's vertical between the glass on the door and the body of the car already has sun damage (I think that's what it is).
Devante, welcome to new car ownership.
Well, first off, it would take the sun longer than a week (even California sun) to do almost any kind of damage to a car.
I suspect you are "looking" for things ..... that may not be significant or not even exist at all.
Like mentioned above, if it makes you feel better, get some of that stuff and put it on the weather stripping.
Meanwhile, it’s one thing to be proud and fret over a new car ...... it's another thing to be paranoid over the car getting "hurt".
Take it from ol humfrz, ….. take "reasonable" care of the car, but DO drive it ..... it exists to serve YOU ....... NOT the other way around ......
Old 07-21-2015, 12:29 AM   #18
Devante
Devante's Avatar
Er... ok? Thanks for the... advice I guess?
Anyway, the discoloration is most definitely there and if you've done anything by posting your slightly dismissive reply, it is confirm that the weather stripping shouldn't be discolored already.
Yes, paint chips, scratches, blemishes will come. My wife scuffed up the inner door area by dragging her heel across it while getting in the car not less than 24 hours of owning the car. She also put a small scratch on that side of the car at the same time with her purse. That's no big deal (well the scratch is irksome). That I can live with because it was human error, not a defective part or shoddy craftsmanship.
If everyone else said the same thing happened to their car, I'd be relieved and not think twice. However, you yourself confirmed it shouldn't be damage so quickly by the sun.
So for that, I say thanks again.
Old 07-21-2015, 12:31 AM   #19
fx1mark
fx1mark's Avatar
Drives: red 2014 FR-S
I just went out and looked at mine. it looks the same. It looks like it's just the way it's manufactured. I thought I was picky, I hadn't even noticed it. never will again.
fx1mark is offline   Reply With Quote
Old 07-21-2015, 12:49 AM   #20
Shady195
Drives: '13 10 Series FRS #1203
It's normal. its rubber weatherstrip exposed to the elements so it will lose its brand new shine rather quickly, especially considering the window is constantly dragging whenever you open and close the door or roll down your windows.
It's not a cosmetic item, its a rubber seal meant to keep water out of your car. Unless its cracking/coming apart it's not defective. It's simply lost its luster. If you're that worried about it, take some non-greasy protection such as the 303 and wipe it down. Will look darker for a short period of time.
Unless water is pouring into your car during a rainstorm or wash its fine. Any sort of rubber will do that rather quickly when exposed to the elements.
Shady195 is offline   Reply With Quote
Old 07-21-2015, 12:56 AM   #21
Devante
Devante's Avatar
I'll probably end up getting that 303 and just making it part of my car wash routine.
When I washed my car for the first time, I noticed quite a bit of water went into the car and ended up on the inside of the window. It didn't make it past the weather stripping, though it seemed close.
When I opened the door, there was a border of water all around the inside of my window.
Just thought it was kind of weird. Never seen a car's striping let some water in like that. It was on both side so I assume that's just normal.
Old 07-21-2015, 12:57 AM   #22
Shady195
It's normal with these types of windows. They are meant to keep a better seal at speed.
Old 07-21-2015, 12:59 AM   #23
Devante
Devante's Avatar
Cool. Welp thanks for the replies, guys.
Old 07-21-2015, 01:39 AM   #24
Zhangy
Drives: 2015 FRS
its perfectly fine, where is the issue
Zhangy is offline   Reply With Quote
Old 07-21-2015, 07:45 AM   #25
jlugo711
Drives: 2014 GT86
Water seeping around the window gives more of a reason to clean around the jambs! _
jlugo711 is offline   Reply With Quote
Old 07-21-2015, 09:39 AM   #26
Take it from ol humfrz, ….. take "reasonable" care of the care of the car but DO drive it ..... it exists to serve YOU ....... NOT the other way around ......
Dude! It is not "damaged", "defective" nor an "issue" but just the way it is.
If this has you bent out of shape already and you are going to respond to some of the best advice on here (as per above) in such a manner then I anticipate many hours of entertainment as you panic over every squeak, click and perceived "defect" that is going to manifest itself with these cars.
Bergen23 (07-21-2015), humfrz (07-21-2015)
Old 07-21-2015, 10:12 AM   #27
stevesnj
stevesnj's Avatar
I started using this MeGuiar's stuff first day I had it, and I used it on all the weather stripping and dash, interior bits. Wanna get a jump on protecting the multiple plastic and rubber compounds they put in this car. UV resistant, non greasy or greasy looking on the dash and other parts.
http://www.meguiars.com/en/automotiv...tectant-spray/
My 2016 Build thread
The Following User Says Thank You to stevesnj For This Useful Post:
Tcoat (07-21-2015)
Old 07-21-2015, 10:22 AM   #28
Wyattkb
Drives: 2014 Whiteout FRS
Here's mine. 2014 and it gets Arizonas terrible sun everyday.
Oh well.
Wyattkb is offline   Reply With Quote
Week-End Pics ? Did you get any sweet shots of your 86 this week-end ? BC-Boy BRZ Photos, Videos, Wallpapers, Gallery Forum 36 05-28-2014 02:14 AM
FR-S/BRZ Week – Exciting Week For Owners 86_Insider Scion FR-S / Toyota 86 GT86 General Forum 2 08-09-2013 07:38 PM
Already damaged paint... ktulu7 Scion FR-S / Toyota 86 GT86 General Forum 20 05-09-2013 08:13 AM
clear bra damaged triwoody Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 4 03-17-2013 04:10 AM
MY GF's FRS confirmed for last week of May or first week of June clayrush Scion FR-S / Toyota 86 GT86 General Forum 45 04-19-2012 05:45 PM
