Old 07-20-2015, 02:56 PM   #1
Devante
Crescent fresh at best.
Devante's Avatar
Drives: 2016 Scion FR-S - Asphalt
2016 Head Unit Question / Discussion
Posting this because I had a question but also feel free to talk about the new head unit.
My question is that I have a Note 4 and one time I connected it to the unit and it had a browse button that let me browse through my phone's library by artist, song, or album.
That was one time. I've never been able to get that browse button to appear again.
Also, I have album art for pretty much ever song. But some of my Thin Lizzy songs show album art that I didn't put for the song. It's like this group photo of them instead of the album cover embedded in the song. Where is it getting this photo and how to I get it to show my actual artwork?
Thanks!
Some things I noticed that I don't like:
One thing about the browsing that kind of sucked was that it doesn't let you type in the first couple of letters of what you want and jump to it, nor does it let you drag the slider down the side.
It has no screen auto-off.
Can't directly touch where you want to jump in the song progress bar.
Little things aside, it seems like a step up from last year's model.
Devante is offline   Reply With Quote
Old 07-20-2015, 03:35 PM   #2
Datcrazyeric
gotta go slower
Drives: 2014 FR-S
Once we PDI the 2016 we have in stock I'll check it out for you if I get a chance.
"While you have to push it to be fast, it always wants to be pushed, abused even. It can live at those high RPMs just fine. Zero to 60 mph arrives in who gives a shit."
Datcrazyeric is offline   Reply With Quote
Old 07-20-2015, 03:36 PM   #3
stevesnj
stevesnj's Avatar
Try unpairing and repairing. I wish a user manual came with it, I can't even find one on Pioneers site and nothing in my manual or in the manual case.
My 2016 Build thread
Old 07-20-2015, 04:24 PM   #4
Devante
Devante's Avatar
There's an option that basically says pair device from vehicle or pair device from phone.
I've selected both. Will mess with it some more and report back.
Old 07-20-2015, 04:31 PM   #5
Datcrazyeric
gotta go slower
Drives: 2014 FR-S
http://www.scion.com/audio/
Download the PDF and see if that helps
The Following User Says Thank You to Datcrazyeric For This Useful Post:
stevesnj (07-31-2015)
Old 07-20-2015, 04:54 PM   #6
PatSciFRS
Drives: Scion FRS 10 Series
Thanks!
For the song list browsing to work, you need to hook up your Note 4 using a data USB cable and set the audio source to USB.
PatSciFRS is offline   Reply With Quote
Old 07-20-2015, 05:26 PM   #7
Devante
Devante's Avatar
But... It already worked without using a cable at all. In fact, I haven't even lifted up that little USB flap yet.
Old 07-20-2015, 07:10 PM   #8
Devante
Devante's Avatar
Thanks!
Just read through it and it doesn't mention anything about hooking it up one way or another to get the browse button to show up. :/
Old 07-20-2015, 08:30 PM   #9
I have a similar but unrelated problem with the 2014 BeSpoke unit in mine (swapped out the original 2013 base unit). With an iPod plugged in, if I go to Browse/Songs, it lists the songs in alphabetical order, but by Artist/Album/Song. I want it to just list the bloody things by song title. It even has the guide at the bottom to jump between letters of the alphabet, but that jumps by artist, not by song title.
Very aggravating because I typically listen to music by starting with the 1st song, and playing all the way through my entire collection in alphabetical order (gives you the effect of random, without the repeats). I ended up having to create a playlist.
Old 07-20-2015, 09:52 PM   #10
Devante
Devante's Avatar
Dude it just happened again when I got in my car! It connected, said browse, I clicked on browse and started going through songs, then it kind of went back to the main audio screen and the browse button was gone.
Also, when I touch the album art, it doesn't show me a list of songs queued up.
Old 07-23-2015, 12:00 AM   #11
Devante
Devante's Avatar
So I figured out the browse button situation.
I use PowerAmp for my music.
I decided to test using the built in music player app and as long as I use that, the browse button appears.
The Following User Says Thank You to Devante For This Useful Post:
RustySocket (07-27-2015)
Old 07-27-2015, 01:28 PM   #12
RustySocket
Slow Learner
RustySocket's Avatar
Drives: 15 Halo FRS
I like it when people post the solution after they figured it out.
RustySocket is offline   Reply With Quote
Old 07-30-2015, 01:37 AM   #13
Astral Abyss
Drives: 2016 Halo FR-S
I'll never like a device that forces me to sort via ID3 tags instead of folders. I had to go through all my music, I have over 500 albums, and fix a lot of tags that never were a problem with my JVC in my last car. Call me anal, but when all my bands that begin with "The" get lumped together, I get annoyed. And artists should be sorted by last name. Especially when literally every other device and program reads them that way, including Foobar, my main PC program, except this Pioneer unit. Seriously?
The best part is that after I did all that and plugged my 64GB USB card back in, it takes over 15 minutes to update and recreate the catalogue. And if i add another album... Another 15 minutes. I can't do anything in the interim... Just watch the spinning wheel and wait. Like I said, I have a lot of music. The JVC didn't use ID3 tags so it could load in about 15 seconds.
Also, if you just change the tags and don't delete\add something to force a media update, it doesn't actually recreate the catalogue so none of your changes take effect.
As Devante noted, it has issues with album art. Seems to like a separate jpg and not integrated into the song. That's great. I guess I'll get to add jpegs to 300+ albums now since I stopped doing that a couple years ago since EVERYTHING else can read it from the song itself. Disappointing really.
I'm ridiculously anal about my music. I will force this thing to sort and play my music correctly if it kills me.
Astral Abyss is offline   Reply With Quote
Old 07-31-2015, 01:49 AM   #14
Devante
Devante's Avatar
Well the weird thing about the album art is some songs have the right art, some songs from the same album show a group picture it got on its own, and some don't show the art at all.
BRZ Head Unit Question MalcolmHimself Electronics | Audio | NAV | Infotainment 2 07-19-2015 01:14 AM
Pioneer Head Unit Question jjkerr626 CANADA 0 03-23-2014 11:23 PM
BRZ Stock Head Unit + Aftermarket Amp + 3-way Components question daforce007 Electronics | Audio | NAV | Infotainment 13 04-14-2013 05:42 PM
New Head Unit Wiring Question sikest Electronics | Audio | NAV | Infotainment 2 01-17-2013 06:15 PM
question about stock F-RS head unit mezdup Electronics | Audio | NAV | Infotainment 3 10-02-2012 01:15 PM
