#85 |
Sarcastic SOB
The FA20T setup in the WRX with a smaller twin scroll unit is just about as close to that as you can get. However the high torque at low RPM's is a recipe for losing traction in a lightweight RWD car.
#86 |
No rice, no life
Drives: 2013 Asphalt FR-S
Turbos and SCs are just different kinds of glorified air pumps. They obviously both work just as well, otherwise everyone would just use one while the other went extinct.
2013 Asphalt Scion FR-S | Jackson Racing Supercharger | KW V3 | Enkei RS05RR 18x9.5
#87 | |
No Money, No Problems
A lot of times these topics on the forums end up devolving into "I like this one more, so it has to be the best choice right? RIGHT GUYS?"
#88 |
Drives: 2010 MS3
#89 | |
Drives: 2022 BRZ Limited
25% performance gain for only $2k, hard to beat that for sure...I really wanted to get an electric supercharger but opted for Kraftwerks for extended track use, hopefully in the future they will come up with more advanced options
#90 | |
many people use left foot brake the adjust the load on the front suspension and maintain balance and in RWD cars you can get away with lift-off throttle.. when I had my vette, I was lifting the throttle if I feel I entered too hot and/or noticed some understeer, those are the things you can never do with a turbo... if you don't like the parasitic loss and look for big numbers on the dyno and umph feel on the street then turbo it is, there's nothing wrong with that, I still miss my turbo cars, they were fun... (except track days )
#91 |
The procede controller that pairs with it, while an extra $500, does a good job of managing the boost for you so you're rarely without it. It delivers the power more linearly and makes it feel like a more powerful engine.
#92 | |||||
Drives: 2015 Series.Blue
Porsche isn't a good comparison for that as with their variable technology it would be a moot point. The 911 doesn't come in stick anymore anyway as well. It's also ignoring that they use dual clutch gearboxes which have lower losses than a conventional auto and can shift faster than you can blink. Even if boost didn't drop on shifts with a stick, you'd still lose. But yes, on an old school journal bearing turbo with a normal conventional auto and stick, the auto will usually win so long as the drivetrain loss isn't excessive. Quote:
Have to see the dyno sheets, the main gain is low end and in the factory dip. It's also being continuously developed and getting better. Quote:
RPM =/= boost with a turbo. If you want boost off the line, you need load (building boost with the torque converter on an auto) or a 2-step. Quote:
This alone means you don't have the slightest clue about what you're talking about. Turbos are a restriction (so much so that they can seriously quiet down a car) and if they did flow like a straight pipe, that would in essence be breaking the laws of physics.The main reason turbos are better than superchargers is that they're low maintenance (they use the same oil as the engine) and they're more efficient than superchargers (though a Rotrex gets damn close). They're also in essence a "displacement on demand" as load = boost = more power. This is why the OEM's like them because they can have the passing ability of a larger engine, with good fuel economy. Quote:
Bypass/blowoff valve doesn't only work when the throttle is closed, it also kicks in at smaller pressure differential changes (like if you let off the throttle). Pushing the clutch is removes the load on the engine so it's also going to cut boost. If you've ever driven a car with a loudish BOV you'd know all this... |
#93 | |
All the truly ridiculous Supras are automatic... for good reason Old school torque converter, old school turbo, and all.My example was really geared toward older Turbos, but yes, you are correct. |
#94 | |
Hey man, a powerglide doesn't really count ![]() Anyway, the main reason I think a lot of people go SC is because it's a truly bolt on affair and there are good off the shelf tunes for them. |
#95 |
Drives: frs
Why not install both? SC for mid-range and TC for top-end.
For those who dont like "lags" meanwhile cornering, try brake with left foot meanwhile right foot is slighty on the gas pedal. This is a matter of preferrence, i like blonde chiks the other like brunette |
#96 |
That has extremely limited application...
#97 | |
Drives: 86
I am thinking about adding a turbo to my setup to give me a punch of power in the high rpm range. Still not sure what turbo size I have to go and who is the tuner to contact for this. Sent from my iPhone using Tapatalk
VOLK LE37 17X7.5, SWIFT Springs, Bilstein B8, HKS intake duct, Cosworth Air Filter, HKS headers, PLM Over Pipe, EVS Down Pipe & Exhaust, FD 4.55, GFB pulleys, Axle-Exchange Drive Shaft, Mishimoto oil cooler, Cusco F&R strut bar, TRD door stabilizer, Innovate SC, Delicious Tuned
#98 | |
Drives: 2015 WRX
There is more to power delivery than peak numbers. When you see quoted figures they are referencing only two points of the cars entire RPM range. Peak Torque and Peak HP. There is a whole RPM range to deliver power through and focusing solely on peak numbers isn't exactly telling unless your main concern is bench racing. The main reason people look at the electric superchargers is to get loads more low down torque while also getting some decent gains up top while remaining a fairly inexpensive mod. Obviously it doesn't replace a purpose built turbo or supercharger but its pretty good at what its intended purpose is. Start to look at the complete package instead of number chasing and you'll end up much happier with whatever car you have. |
| charged86 supercharged to build motor turbo | charged86 | Member's Car Journals | 9 | 07-24-2015 11:48 PM |
| turbo/supercharged FRS ride along? | dgerny | Northwest | 26 | 05-15-2015 11:43 PM |
| wtb Turbo or Supercharged auto FR-S/BRZ | TurboCarder | Want-To-Buy Requests | 1 | 01-27-2015 07:10 PM |
| wtb Turbo or Supercharged auto FR-S/BRZ | TurboCarder | Cars for Sale/Trade | 0 | 01-27-2015 09:31 AM |
| Turbo BRZ smashes a Supercharged v8 in a drag | CSI:86 | Forced Induction | 41 | 05-14-2013 09:12 PM |
