Old 06-27-2015, 05:56 PM   #533
LittleBlueGT
Drives: 2013 STI
What about an oil-cooler built into the core of a custom Radiator?
I have one that I put into my STI, got it from Ron-Davis. It is similair in concept to an auto-tranny cooler, but the cooler is designed a bit different.
LittleBlueGT is offline   Reply With Quote
Old 06-27-2015, 07:41 PM   #534
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Robispec did that. Then a bunch of them corroded and he disappeared off the forum.
The Following 2 Users Say Thank You to EAGLE5 For This Useful Post:
Kuri (09-01-2015), Ultramaroon (06-27-2015)
Old 06-27-2015, 08:49 PM   #535
Element Tuning
Drives: Hydra EMS Powered FRS Raven Black
I'm running a pretty big core now but I did look into massive radiator size coolers like used in Nascar. You either spends thousands on that or on a dry sump and the dry sump won out for me.
Element Tuning is offline   Reply With Quote
Old 07-18-2015, 07:50 PM   #536
ChrisD
ChrisD's Avatar
Drives: GT86
Originally Posted by Element Tuning View Post
Maybe the Remax gear can get people without our engine build up some but I'm really not optimistic it's going to be enough for you guys on it's own. We have with our build 85 psi to 8k and about 80 psi to 9k RPM at operating temps (dyno and hard street) and most OEM engine builds are lucky to see 55 psi to 7000 RPM. I'm asking the Remax gear to give me plus 20 psi under racing conditions but many are hoping it will give them what we already have (+30 psi) along with what we need for racing (+20) which would total +50 psi more oil pressure. It's a long shot!
So what would you recommend doing on top of (or instead of) getting the Reimax pump gear? Sorry if it was mentioned earlier in this thread but its now 25 pages long. I'm not going to be pushing my car to the limits you are (it will mainly be used on the street), but I'm getting forged internals soon so that I can increase the turbo boost a fair bit and I was wondering if I needed to do anything with the oil pump at the same time - the only suggestion has been to get this Reimax gear but it seems like you're saying that probably won't be enough.
My GT86 build so far:
AVO Stage 4 Turbo, Carrillo forged con rods, 10:1 CR Carrillo pistons, AVO 3 inch turbo back exhaust, Helix clutch, TheDriveShaftShop drive shafts, lightweight flywheel, NamelessPerformance hydraulic hand brake, KW V3 coilovers... and lots of other little bits
ChrisD is offline   Reply With Quote
Old 07-19-2015, 12:31 AM   #537
sam69
Drives: GT 86
I'm in the same boat re the Riemax gears but it might not be enough for racing although it could be more than enough for a DD and occasional club track run
At least this is what I'm hoping but Element might be able to shed more light on this.
The guy who is doing the motor has suggested getting the crank oil phased as well and cleaning up the galleries where possible so what are the thoughts on this with the FA20 ?
sam69 is offline   Reply With Quote
Old 07-19-2015, 12:36 AM   #538
EAGLE5
Dismember
EAGLE5's Avatar
Read through the thread. It will explain all.
In sum:
Can't modify the pump enough for big power on the track.
Between pump mods, accusump, massive cooling, and thick oil, massive power can be handled at the track.
A dry sump is the long term solution, but it's expensive and might require deleting the AC.
If you're just driving on the street, none of this probably matters, and a reimax pump upgrade might get you some peace of mind.
If you're buying forged parts piecemeal to put together yourself or with some local shop, you're doing it wrong. Hire somebody who knows what they're doing, like Element or perhaps a few other shops. They've already broken everything on the FA20 that you're going to break by not going to them, and they know how to build your engine so it won't break.
Element is running massive power and pounding on the track with high-g turning, including down force and slicks, with an expert driver. Is that you?
The Following 5 Users Say Thank You to EAGLE5 For This Useful Post:
Captain Snooze (07-19-2015), ChrisD (07-19-2015), new2subaru (12-27-2015), RavioliG (09-01-2017), Trac Toy (07-19-2015)
Old 07-19-2015, 02:32 AM   #539
Kodename47
Kodename47's Avatar
Drives: UK GT86
Chris, take it to Abbey. Mark has been looking into the oiling issues more than anyone else AFAIK. Plus he'll have built a few engines too by then.
.: Stealth 86 :.
Kodename 47 DJ:
Old 07-19-2015, 06:12 AM   #540
Hector
Drives: Toyota GT86 Satin-White-Pearl
550HP@9000rpm is where Element Tuning operates, but what about lower power levels and different methods of FI?
Some say 350 turbo-PS@7300rpm are no problem for street use and occasional track days on stock internals.
When does it really start to starvate? Do i have that issue on a completely stock car while abusing it on track?
Hector is offline   Reply With Quote
Old 07-19-2015, 07:34 PM   #541
ChrisD
ChrisD's Avatar
Drives: GT86
In sum:
Thanks for the summary, and yeah that was my thinking too - that the reimax pump is better than nothing and in reality will probably be enough for my needs. I won't be hammering it round track with down force and sticky tyres, I'm just using it for street driving and the occasional track day on the stock tyres (before anyone tells me to get different tyres - I like going sideways as much as possible). Oh and some slow speed drift days where they wet the track and you don't really get above 30 mph.
I can't take it to Element as they're in a different country to me, but I've been using Fensport to do a lot of the tuning/modification work so far and they seem to be known as one of the best places in the UK for GT86 work (they have a track only car themselves that they're running about 450 bhp on, albeit with race fuel). I'll definitely be consulting them but just looking to get opinions on here as well so that I'm not completely relying on their recommendations and nothing else.
Old 07-19-2015, 07:50 PM   #542
grant
Drives: too many to list
did anyone ever do a review on the reimax pump gears? I know Element has their fix that they hold closely to their chest (rightfully so, and don't blame you for keeping your secret) but like others interested in a weekend project/insurance policy, until motor build funds are sourced it would be nice to see if there's a cheaper quick fix/band-aid like the gears and oil coolers
grant is offline   Reply With Quote
Old 07-19-2015, 08:33 PM   #543
ChrisD
ChrisD's Avatar
Drives: GT86
I have already spoken to them, but I'm a little put off by the fact that he said a few things that everyone here seems to disagree with (like saying he's never heard of needing stronger valve springs, yet a lot of people here say valve float is a common problem on higher powered engines with the stock springs and retainers).
Old 07-20-2015, 10:56 AM   #544
ChrisD
ChrisD's Avatar
Drives: GT86
Originally Posted by Tim Radley View Post
Stock valve springs are weak. You will get float with decent boost.
Exactly, everyone seems to agree on this. So when Abbey told me that I didn't need to bother with valve springs, it kind of made me think I can't really trust everything they say (though don't get me wrong, I'm sure they know their stuff in general)
Old 07-20-2015, 12:37 PM   #545
Andreas83
Andreas83's Avatar
Drives: 2013 Subaru BRZ
My car is up and running with the reimax pump gears.
I will try and get some numbers when i go back onshore.
English is my 2. language. Typos might occur.
2013 BRZ, kraftwerks supercharged.
Skunk2 Ultra radiator with oilcooler
KW v3 - enkei 17x9 with PSS
Andreas83 is offline   Reply With Quote
The Following 8 Users Say Thank You to Andreas83 For This Useful Post:
BatStig (07-20-2015), celek (07-20-2015), ChrisD (07-20-2015), GhostOp86 (07-21-2015), grant (07-20-2015), sato (07-20-2015), spitfire481 (07-20-2015), Ultramaroon (07-20-2015)
Old 07-20-2015, 02:27 PM   #546
D K
Stig's dark passenger
How did it go at vir?
D K is offline   Reply With Quote
FA20 Engine component photos Crawford FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 89 02-22-2016 02:31 AM
FA20 Engine component photos Crawford Engine, Exhaust, Transmission 46 01-26-2015 05:19 AM
Engine Hardware, Gaskets, & Bearings Oh My; All on sale at FR Sport. FRSport.com Engine, Exhaust, Bolt-Ons 0 01-10-2014 12:33 PM
FA20 Le Mans Race Engine SilverSkyline210 Engine, Exhaust, Transmission 11 11-17-2013 11:24 PM
