Old 07-17-2015, 01:12 AM   #169
raven1231
Originally Posted by Fred E View Post
Any intake that exits at the same location as the stock airbox (e.g. both Perrin intakes) will be compatible with the kit without needing any modification (there might be some exceptions.)
Source: using the 3" Perrin intake with this kit.
Good to know. I figured at minimal the tune would need adjusting but I guess not lol.
Old 07-17-2015, 01:53 AM   #170
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
Keep mind that if you are going for CARB the tune will be locked and cannot be adjusted.
Old 07-17-2015, 10:17 AM   #171
Fred E
Drives: WRB BRZ
Well yes, the tune would need to be adjusted to run optimally, but as with any forced induction kit, there's no reason to use the base tune for longer than it would take to get a proper tune tailored to your car. Obviously, if one is looking to keep the CARB certification, you can't modify the tune, but you also can't modify the intake.
Fred E is offline   Reply With Quote
Old 07-17-2015, 10:01 PM   #172
WORKS
WORKS's Avatar
Drives: WORKS CARB Legal Turbo BRZ
Our 50-state smog legal, CARB compliant turbo kits are now available for 2013, 2014, 2015 & 2016 model year Scion FR-S and Subaru BRZ vehicles!
Visit http://www.ft86club.com/forums/showthread.php?t=91803 for purchasing information.
Cheers,
WORKS Motorsports
WORKS is offline   Reply With Quote
Old 07-17-2015, 10:48 PM   #173
Phantobe
Phantobe's Avatar
Drives: 14 Ultramarine FR-S
Pretty cool to see another CARB legal kit! I wonder how it'll stack up against the JRSC
2014 Ultramarine Scion FR-S
2000 Integra LS - SOLD
Phantobe is offline   Reply With Quote
Old 07-18-2015, 04:26 AM   #174
Alltezza
Alltezza's Avatar
Drives: WRB Limited BRZ
What are the potentials if someone was to buy the stage 2 Kit but was to run full headerback catless setup? and Possibly E85?
Alltezza is offline   Reply With Quote
Old 07-18-2015, 06:04 AM   #175
ravisraval
Drives: 2013 FRS
Also interested in JRSC vs Works Stg 2. Would be nice to have these both on the same type of dyno and get the results overlaid on one graph.
ravisraval is offline   Reply With Quote
Old 07-18-2015, 11:24 AM   #176
Fred E
Drives: WRB BRZ
I'm running the stage 2 kit with a full exhaust on E85, but I still have both catalytic converters. I haven't gotten on a dyno yet, but I should be getting on one within a couple weeks, so I'll let you know.
Old 07-18-2015, 11:25 AM   #177
sato
sato's Avatar
Drives: Dodge Patitas
Well, get to the dyno! Haha
sato is offline   Reply With Quote
Old 07-18-2015, 01:04 PM   #178
Fred E
Drives: WRB BRZ
Haha, working on it! I did need a new clutch after installing the stage 2 upgrade, so that says something about what to expect.
Old 07-20-2015, 12:57 AM   #179
SPCorBUST
SPCorBUST's Avatar
Looking into this as a turbo build now that you are CARB approved! Definitely interested in some additional results. @WORKS thanks for going through the trouble of the CARB process, its definitely appreciated!
Briefly looked through the install instructions, and appreciate the detail there as well.
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East
Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church
Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor
Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor
SPCorBUST is offline   Reply With Quote
Old 07-20-2015, 11:41 AM   #180
LucidMomentum
No Money, No Problems
LucidMomentum's Avatar
Yes, thank you very much @WORKS for the CARB approval. It means a lot to some of us that you're willing to work with them to get it approved, even if it may be a hassle.
Old 07-22-2015, 01:37 PM   #181
WORKS
WORKS's Avatar
We plan to setup our BRZ for E85 eventually as well.
Old 07-22-2015, 01:42 PM   #182
WORKS
WORKS's Avatar
Thank you everyone! CARB compliance is no walk in the park.
Cheers.
P&L Motorsports Stage 1 Turbo Kit Build Thread P&L Motorsports Forced Induction 31 10-25-2017 04:26 AM
WORKS Stage 1 Turbo Kit - Officially Released! - Now CARB Compliant/SMOG Legal WORKS Forced Induction 230 08-11-2016 06:01 PM
Stage 2 Cosworth Kit Preview!!!! Titanmotorsports Forced Induction 377 04-01-2015 07:29 AM
WORKS Stage 1 Turbo Kit Pre-Release Offer - Over $800 Discount! WORKS Forced Induction 107 11-22-2014 12:15 AM
WORKS Stage 1 Turbo Kit Pre-Release Offer WORKS Northern California 31 11-11-2014 07:24 PM
