Old 07-06-2015, 06:33 PM   #155
WORKS
WORKS's Avatar
Drives: WORKS CARB Legal Turbo BRZ
Originally Posted by stoked_on_spool View Post
Great news guys!!!
Can't wait to see a couple of these kits out in the wild! I'm running buttonwillow race track this weekend and it's 110 F outside right now... how do you think the turbo kit will hold up in this kind of heat during HPDE's?
(And yes, I already have an oil cooler. lol)
The weather ended up far from 110 F (ranging from the low 70's to high 80's) here at Sonoma Raceway, but the car ran very well!
This track day was also another shakedown due to a host of new parts to the driver and/or vehicle:
  • WORKS/Ohlins Road & Tracks (60N/mm front, 70N/mm rear)
  • Volk CE28Ns (17x9 +43)
  • Toyo R888 (255/40). We didn't notice any tire rubbing which we thought we would! These R888s are large 255s.
  • Subaru STi front and rear calipers with Endless brake pads
  • APR front canards
  • Complete SuperPro suspension bushings, sway bars, and rear lower control arms
We're looking forward to the next one!
WORKS is offline   Reply With Quote
Old 07-06-2015, 06:35 PM   #156
WORKS
WORKS's Avatar
Originally Posted by jflogerzi View Post
how much of an increase? Also will the tune still work on OFT?
Price increase will be announced when we create the commercial threads for the CARB compliant versions of Stage 1 and 2.
Our standard (non-CARB compliant) turbo kits will now be "tuner kits", that is to say, tune-it-yourself turbo kits that do not include ECU tuning.
The CARB compliant kits will include a locked tune file provided by us, which is required by CARB. We are still deciding which tuning platform to use with the CARB compliant kits, but OFT is unfortunately off the table.
Cheers.
Old 07-06-2015, 06:39 PM   #157
Kaotic Lazagna
Drives: GR Corolla
That is rather unfortunate. That was also another reason why I was wanting this kit since I already have an OFT. *Bummed out*
Old 07-06-2015, 06:45 PM   #158
WORKS
WORKS's Avatar
Originally Posted by vrtrasura View Post
Greetings,
I'd like to know:
Is it possible to upgrade a stage 1 install to a stage 2?
If so do you have any plans to sell the intercooler upgrade as a small kit?
I have an oft and an oil cooler and like the idea of an upgrade path.
Thanks!
We do not have plans to sell individual components from our kits, but we do offer an upgrade kit to turn a Stage 1 to a Stage 2.
PM sent regarding upgrade price.
Cheers.
Old 07-06-2015, 06:50 PM   #159
GhostOp86
Fr-s Whiteout
GhostOp86's Avatar
Drives: 2017 civic type R #1353 2017 ss1le,
Thursday re tune hopefully
Turbo Fr-s 2013 Cam Tuning SOLD
http://youtu.be/3vM-2MijcQQ
2017 ss1le
2017 Honda Civic Type R #1353
2002 Rsx Type s
GhostOp86 is offline   Reply With Quote
Old 07-13-2015, 12:39 PM   #160
JPDinCV21
Drives: Subaru BRZ
Carb Legal?
JPDinCV21 is offline   Reply With Quote
Old 07-13-2015, 01:05 PM   #161
JPDinCV21
Drives: Subaru BRZ
Nevermind got the answer, so with this kit, i could be okay on the streets?
Old 07-13-2015, 01:18 PM   #162
raven1231
It's carb legal if that's what you're asking?
Old 07-13-2015, 01:26 PM   #163
WORKS
WORKS's Avatar
Correct.
Under CARB Executive Order D-748, our CARB compliant Stage 1 and Stage 2 Turbo Kits do not violate any Vehicle Codes for 2013 through 2016 model year Subaru BRZ and Scion FR-S vehicles.
Old 07-16-2015, 12:24 PM   #164
Dukerade
Drives: 2015 brz
I am thinking of getting the perrin cold air intake. i was wondering would it be good enough for this stage 2 turbo kit, or will it compatible with the kit itself.
Dukerade is offline   Reply With Quote
Old 07-16-2015, 12:33 PM   #165
raven1231
It was designed for the stock intake. Any aftermarket would likely cause a lot of modification to the piping. I would suggest keeping the stock intake, especially if you plan on using their tune.
Old 07-16-2015, 02:06 PM   #166
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
Shouldn't be much modification since the Perrin pipe fits where the stock box does and connects to the intake tube the same.
Old 07-16-2015, 10:55 PM   #167
Fred E
Drives: WRB BRZ
Any intake that exits at the same location as the stock airbox (e.g. both Perrin intakes) will be compatible with the kit without needing any modification (there might be some exceptions.)
Source: using the 3" Perrin intake with this kit.
Fred E is offline   Reply With Quote
Old 07-16-2015, 11:01 PM   #168
Dukerade
Drives: 2015 brz
The Perrin intake is outside the engine bay, so I guess it will work right? Because I am thinking of getting that and then later on I'll get the stage 2 turbo from the works.
P&L Motorsports Stage 1 Turbo Kit Build Thread P&L Motorsports Forced Induction 31 10-25-2017 04:26 AM
WORKS Stage 1 Turbo Kit - Officially Released! - Now CARB Compliant/SMOG Legal WORKS Forced Induction 230 08-11-2016 06:01 PM
Stage 2 Cosworth Kit Preview!!!! Titanmotorsports Forced Induction 377 04-01-2015 07:29 AM
WORKS Stage 1 Turbo Kit Pre-Release Offer - Over $800 Discount! WORKS Forced Induction 107 11-22-2014 12:15 AM
WORKS Stage 1 Turbo Kit Pre-Release Offer WORKS Northern California 31 11-11-2014 07:24 PM
