Old 07-17-2015, 02:05 PM   #1
Benschneider06
Benschneider06's Avatar
Drives: Satin White Pearl Subaru BRZ
Question Blown engine due to 0W-20?
A person in my local 86 club recently threw a rod in his FR-S.
Car had 38k miles when it blew and he had just put Mobile 1 Extended Performance 15,000 mile rated oil in his car at 37k miles. So only 1000 miles in. The car had a tune and mild bolt ons. Never tracked but driven hard.
He claims it was a combination of heat and the low oil weight (0W-20) that caused the oil to break down and not lubricate....thus causing it to throw a rod.
I thought 0W-20 was the recommended oil from Subaru...?
I just put the same oil in my car yesterday... so what do you guys think?
Benschneider06 is offline   Reply With Quote
Old 07-17-2015, 02:06 PM   #2
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
I think it was most likely not the oil.
The Following 13 Users Say Thank You to Summerwolf For This Useful Post:
ATL BRZ (07-22-2015), Basket Case (07-18-2015), burdickjp (07-18-2015), DAEMANO (07-18-2015), fika84 (07-18-2015), humfrz (07-17-2015), HunterGreene (07-22-2015), PNW FRS (07-18-2015), pushrod (07-19-2015), soulreapersteve (07-22-2015), Tectoniic (07-22-2015), Teseo (07-19-2015), Thorpedo (07-18-2015)
Old 07-17-2015, 02:06 PM   #3
celek
Resident Gear Head
celek's Avatar
Bad tune with bad gas
celek is offline   Reply With Quote
The Following User Says Thank You to celek For This Useful Post:
BlueDubbinTDI (07-17-2015)
Old 07-17-2015, 02:25 PM   #4
Benschneider06
That's why I thought. He swears up and down that his AFR was reading perfect... I guess that's not the only factor though?
Old 07-17-2015, 02:30 PM   #5
s30series
Drives: 2015 BRZ Series.Blue
I think you should sell the car and never buy a subaru ever again. Stick with a Honda Fit
s30series is offline   Reply With Quote
The Following 2 Users Say Thank You to s30series For This Useful Post:
Captain Snooze (07-17-2015), NWFRS (07-18-2015)
Old 07-17-2015, 02:38 PM   #6
MAPerformance
Drives: Asphalt FRS
Been running 0w20 on my boosted FRS for over 25k miles now. No issues what so ever. Most likely not an oil weight issue.
MAPerformance is offline   Reply With Quote
Old 07-17-2015, 02:52 PM   #7
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
sounds like he's making speculation based on rather limited sounding knowledge
and he's SURE he threw a rod? It might just be crickets...or normal engine sounds. Not trying to sound like an a-hole, but sometimes people hear one noise and jump to some pretty wild conclusions.
Old 07-17-2015, 03:13 PM   #8
Benschneider06
Yeah... maybe so
and no I mean his car is completely out of commission. It blew up, lol.
Old 07-17-2015, 03:21 PM   #9
DarkSunrise
DarkSunrise's Avatar
I'm currently using Mobil 1 0w20 EP on my car. Tracked multiple times without issue.
Yep AFR is only one part of it. Was he also monitoring for knock?
2022 BRZ Build
2013 FR-S Build
Old 07-17-2015, 03:27 PM   #10
ybotspawn
ybotspawn's Avatar
Drives: 13 Subaru BRZ
Better question, when he was monitoring afr, was it the stock o2 sensor using torque or some similar android app? Unless he has a better o2 and possibly map sensor, torque is a pretty useless measuring tool.
ybotspawn is offline   Reply With Quote
Old 07-17-2015, 03:37 PM   #11
Toyarzee
Shibby!
Toyarzee's Avatar
Drives: '14 White FR-S, '01 turbo mini taco
Pssshh... ain't the oil, unless he has logged data to back up more of his story. ^^ Also curious if he's using a proper and accurate wideband afr meter tool... plus you could be dumping mass fuel from an ots tune and run a sub 10 afr and still throw a rod
Toyarzee is offline   Reply With Quote
Old 07-17-2015, 03:40 PM   #12
stugray
Drives: 2013 GBS BRZ Limited
So he is essentially saying that the cause of the failure was following the exact requirements of the engine engineers?
A failure that the other 99.99% of the other owners have not experienced?
Tell him he should become an engine designer.
The Following 2 Users Say Thank You to stugray For This Useful Post:
Captain Snooze (07-17-2015), ChrisD (07-17-2015)
Old 07-17-2015, 03:41 PM   #13
swarb
Unless he has data logs or stares at the afr gauge while driving...
The biggest factors in a blown engine at low power levels are usually-
-Tune or bad gas(which affects the tune)
-Driver/mechanic, mis-shifted, over-rev, too much/too little oil. Kept on driving when it felt funny, or just driven too hard for too long and did not watch the oil temps.
-Manufacturer, earlier model 2013's have the most problems. But if it was driven hard it would have blown a lot earlier.
Ask him what he was doing when it blew. And how long he was driving hard for. Ask him how many quarts of oil he put in, he should have it memorized @5.8quarts. This car is known to be difficult to check the oil level, maybe he just changed the oil on ramps and did not check on a level surface. Ask the right questions and the answer should present itself. People mis-shift all the time and never want to admit it.
Also does he have an oil cooler? I make one or two passes and my oil temps are already at 230f++
What tune does he have?
The Following User Says Thank You to swarb For This Useful Post:
Tcoat (07-17-2015)
Old 07-17-2015, 03:44 PM   #14
OkieSnuffBox
Drives: '23 BRZ Limited
I'm going with money shift.
The Following 6 Users Say Thank You to OkieSnuffBox For This Useful Post:
cdrazic93 (07-18-2015), fstlane (07-18-2015), soulreapersteve (07-22-2015), Tcoat (07-17-2015), Tectoniic (07-22-2015), Ultramaroon (07-18-2015)
0w-20, blown engine, frs, oil, oil change
CEL - Engine Blown!!!!!!! rapidcars Issues | Warranty | Recalls / TSB 65 12-10-2014 09:32 PM
Supercharger and blown engine Triumphrider Forced Induction 81 10-21-2014 03:49 PM
Blown Engine kombatlion Forced Induction 27 06-18-2014 06:21 PM
BRZ Blown engine question Mujen84 Forced Induction 118 04-02-2014 05:04 AM
Initial d blown engine be6sti Other Vehicles & General Automotive Discussions 6 10-15-2012 09:16 PM
