Old 07-13-2015, 11:46 AM   #71
PNW FRS
PNW FRS's Avatar
GS intake installed
Found one for sale (used)... at a reasonable price. Install took all of about 20 minutes. Reset the ECU and went for a spin. Did a few "known" roads with acceleration challenges for my NA rig... and found enough of an improvement -- especially with one roll-on acceleration (45'ish to 65'ish ~ 3K to 5K+ rpm...) turn that I'm glad I did the mod. Butt-dyno seemed to show a bit stronger and smoother pull.
Edit/Update: Went out this afternoon and romped around a bunch of familiar back roads where scooting through 50+ through twisties is fun-times. I've done these a bunch w/just the K&N drop-in and it was "OK" - did a bit more down-shifting than I'd like. This time... the diff was noticeable... especially when winding out 3-4 gears around 3.5 to 5.5K rpm. And with my Mich Pilot SS shoes... it's been a little tough to break the rear loose on take-off... not any more. Nice!
Side-benefit is how the install cleaned up the front of the engine bay w/o the Resonator Box (connected to OEM airbox).
2013 Asphalt / MT
Olympia, Washington
PNW FRS is offline   Reply With Quote
The Following User Says Thank You to PNW FRS For This Useful Post:
GrimmSpeed (07-14-2015)
Old 07-16-2015, 11:14 PM   #72
86_PWR
Drives: 2015 FRS RS 1.0
Hey grimmspeed, i want to buy your intake but also want to know if shiv ever made a tune for it. I have a uel header and oft. Was a map ever made by shiv for this?
86_PWR is offline   Reply With Quote
Old 07-17-2015, 10:21 AM   #73
GrimmSpeed
GrimmSpeed's Avatar
Drives: '13 BRZ, '12 WRX
Send a message via AIM to GrimmSpeed Send a message via MSN to GrimmSpeed
I do believe so, although I am not 100% sure one was made header specific. I see Steve answered your question here (there is also a ton of information in this thread regarding it's MAF scaling, running this with header tunes, e85 tunes, etc): http://www.ft86club.com/forums/showt...t=78903&page=4
And as Steve mentioned, give the folks at OFT an email requesting your tune, and they should be able to help you out. I would be surprised if they didn't have a GrimmSpeed intake MAF scaled tune for UEL, and if they didnt you could easily apply the MAF scale from a non header tune to their header tune. And to answer your other question I know that they have different octane tunes.
Chase
Engineering
GrimmSpeed is offline   Reply With Quote
Old 07-17-2015, 11:08 AM   #74
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
Originally Posted by akyp View Post
Just to let @GrimmSpeed know there's still interest in a dry filter option, especially if it proves to have an insignificant hp loss compared to the wet filter.
I'm holding out for a dry filter package!
I was considering grabbing an AEM dryflow filter and the Grimmspeed intake, but this is good news!
JazzleSAURUS is offline   Reply With Quote
Old 07-18-2015, 04:26 AM   #75
akyp
Drives: 2012 86
Yep this is the last missing piece I'm waiting for, before getting my car tuned on a dyno.
Hopefully they still plan to release it.
akyp is offline   Reply With Quote
Old 07-18-2015, 08:14 AM   #76
FrostedFlakes
Drives: 2013 Raven FRS
Chase
Engineering
There is no offical Grimm Intake specific Stage 2 UEL tune as I know. I had asked about this way back and so has a few other members.
We were all told to use the OTS UEL stage 2. Correct me if I am wrong. But if Shiv does have a Grimm specific UEL or OFH stage 2 I would love to get a copy.
http://www.ft86club.com/forums/showp...&postcount=115
From your posted link, a member Koa made his own by applying the MAF scaling, and was playing around with it. But its not perfect and experimental, running lean at times. But looks like the topic has kinda jump started again.
http://www.ft86club.com/forums/showp...&postcount=101
FrostedFlakes is offline   Reply With Quote
Old 07-18-2015, 10:27 PM   #77
steve99
Drives: FT86
If its leaning out in spots and the maf scaling is ok
check the engine load limit tables against the measured engine load\rpm where its leaning out you may need to increase the engine load limits, their are two tables usually in with maf scaling called engine load limiter A and B or soketimes B andC
FrostedFlakes (07-19-2015)
Old 07-20-2015, 10:51 PM   #78
86_PWR
As i said in the other thread, i dont know how to copy scalings or make map adjustments. Nor do i want to try and possibly have problems. That is why i asked for a premade map.
Old 07-20-2015, 11:15 PM   #79
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Don't know when we'll receive them yet, but when I know, I'll let everyone know.
There is probably no need to notify my mum.
wparsons (09-02-2015)
Old 07-21-2015, 12:13 AM   #80
Turdinator
Señor Member
Turdinator's Avatar
I heard she prefers it wet anyway...
(sorry I just couldn't let that one go through to the keeper)
1974 TA22 Celica
2013 86 GT
The Following 4 Users Say Thank You to Turdinator For This Useful Post:
akyp (07-21-2015), Captain Snooze (07-21-2015), Cesium Rainbow (08-06-2015), wparsons (09-02-2015)
Old 08-28-2015, 11:11 PM   #81
OkieSnuffBox
Drives: '23 BRZ Limited
@GrimmSpeed, any updates on an oil cooler friendly intake?
Old 08-29-2015, 02:30 AM   #82
Captain Snooze
Drives: Red Herring
Any update on the paper element?
(I think paper is the 91st element in the periodic table with the symbol Pa)
Old 08-29-2015, 04:02 AM   #83
tracerit
Drives: '13 SSM BRZ Limited 6MT
Anyone have the OFT stage 1 91 gas tune for this intake? Emailed shiv@openflash but haven't heard anything back in a week.
tracerit is offline   Reply With Quote
Old 08-29-2015, 04:30 AM   #84
steve99
Drives: FT86
I got a 700G version, honestly its very close to stock scaling the ol fuel table has a minor tweak as well. i can send you that rom and just copy accross the two changes tables
see the romraider tips link below their is a video tutorial
actually see post here
http://www.ft86club.com/forums/showp...4&postcount=67
GrimmSpeed (09-01-2015)
GrimmSpeed Lightweight Crank Pulley - New Product Information GrimmSpeed Engine, Exhaust, Transmission 14 12-09-2014 06:36 PM
GrimmSpeed License Plate Relocation Kit - Product Release/Group Buy GrimmSpeed Exterior Parts - The Rest 379 02-19-2014 11:19 PM
GrimmSpeed BRZ/FR-S Hood Struts - Product Release GrimmSpeed Exterior Parts - The Rest 16 07-23-2013 09:30 AM
A little fun product release...GrimmSpeed Project 86 T-Shirt GrimmSpeed Miscellaneous 10 03-16-2013 07:52 PM
AIRAID FR-S / BRZ Cold Air Intake system Sneak Peak / Development Information AIRAID Engine, Exhaust, Transmission 396 10-04-2012 07:27 AM
