Old 07-16-2015, 05:52 PM   #379
aa_chow
aa_chow's Avatar
Drives: 2015 FR-S, 2020 Mazda 3 Sport
Don't know for sure but since daytime lights are required by law in all of Canada the ability to turn them off may be disabled on our version.
That's what I think too. I just want to know if other Canadian owners actually have this option or it's my adapter.
aa_chow is offline   Reply With Quote
Old 07-16-2015, 05:56 PM   #380
1Cor10:23
1Cor10:23's Avatar
Drives: '13 Whiteout FR-S (M/T)
@aa_chow only turns off if parking brake is up or you turn on light stalk
Sent from my SGH-I317M using Tapatalk
1Cor10:23 is offline   Reply With Quote
Old 07-16-2015, 06:16 PM   #381
ZOMFGAARON
A Demon
ZOMFGAARON's Avatar
Drives: Raven GT86
You can pull up your hand brake ever so slightly and it will turn them off or remove the bulbs?
Old 07-16-2015, 11:22 PM   #382
jonzhuxD
Drives: Ultramarine FR-S
You could remove/disconnect the resistor and that should do it.
jonzhuxD is offline   Reply With Quote
Old 07-17-2015, 12:47 AM   #383
D_Thissen
D_Thissen's Avatar
^^ this. Under the front bumper (passenger side) there is a small access panel. Remove the cover and you'll be able to see it. I believe it's a brown plug. You will need to jack the front end up though.
Old 07-17-2015, 01:46 PM   #384
PNW FRS
PNW FRS's Avatar
Originally Posted by duke_FRS View Post
How?
There are only 6 gears.... we need a dash indicator to tell someone using (hopefully correctly) a MT what gear s/he is in? I'm sure anyone who has been driving with a MT for any length of time knows by sheer intuition -- by the orientation of the shifter -- what gear is engaged.
IF someone is new to MT.. then get in the car and obtain, "...length of time..." with your rig so you can keep your eyes on the road and not the dashboard.
2013 Asphalt / MT
Olympia, Washington
PNW FRS is offline   Reply With Quote
Old 07-23-2015, 10:25 AM   #385
aa_chow
aa_chow's Avatar
Yes, thanks. I found that out from another thread before. I was able to reach in without jacking up.
The reason for my first post was that I want to make everyone aware that on a 2015 Canadian FR-S the option for DRL disable is not present in Carista.
Old 07-23-2015, 11:27 AM   #386
D_Thissen
D_Thissen's Avatar
Ahhh gotcha. My bad dude
Old 12-20-2015, 04:10 PM   #387
notout86
Drives: GTS 86 auto
If you prop up the hood you can clean the area where the wipers rest completely without dislocating your wrist.
GTS86 Auto (Australia)
Old 12-20-2015, 04:18 PM   #388
notout86
Drives: GTS 86 auto
Before lifting the hood, to prevent damage, ensure the wipers are down.
Old 12-20-2015, 05:25 PM   #389
KR-S
Sporadic Member
KR-S's Avatar
Drives: 2016 Halo FR-S M/T
If you put a custom-made intake on the car, you can make 221whp N/A.
Old 12-21-2015, 09:48 PM   #390
nova.86
Legendary Member
nova.86's Avatar
Drives: HyperBlue BRZ
Originally Posted by ericmpena View Post
I don't think this was mentioned, but in the same menu where you set up the Gear Indicator, there is also an option that says S-On/Off.
S-On = Tachometer needle will shoot up and back down when car is started.
S-Off = Tachometer needle will not move when car is started.
Also, if you're in a BRZ Limited then you will need to set the alarm manually if the dealership did not do it for you:
1) Get in the car
2) press the start/stop button two times, with makes the car to be in the start position (all your dash lights light up)
3) Lock the car with the physical button on the door
4) Press the unlock button on the door and open the door while still pressing the unlock door button.
5) Still pressing the unlock button, wait about 10 seconds, the car will beep once for activated and twice for deactivated and the information panel in the cluster will say either "AL on" or "AL off"
Lifesaver bro, apparently the dealership didn't do it on my HyperBlue. I live in a sketchy neighborhood good to know I have an alarm now. A truck on the street behind me had their windows broken..it was a regular truck as well.
nova.86 is offline   Reply With Quote
Old 12-22-2015, 06:57 AM   #391
RichardsFRS
RichardsFRS's Avatar
Drives: 2013 Pearl White 6MT
Originally Posted by FRSBRZGT86FAN View Post
My U.S. car doesn't have any sort of warning at 75mph (120 kph) but I have heard that it's behind the instrument cluster in EU cars and is tied into the same "dinger" as the seatbelt chime and people just taped it over
Sent from my A0001 using Tapatalk
That would suck having some crappy 75mph warning LOL. Thats the legal speed limits of most the freeways I drive here lol. I would hate that and I would find away to get rid of it or by pass it. WTF 75mph, thats normal cruise speed on the way to work
RichardsFRS is offline   Reply With Quote
Old 12-22-2015, 07:01 AM   #392
RichardsFRS
I want a way to have all my guages on at once. Odometer, mpg, gear, outside temp how many miles left before fill up. LIGHT IT UP!
scion brz hidden features
Ideas for a hidden magnetic phone-mount. MmmDieselFumes Cosmetic Modification (Interior/Exterior/Lighting) 40 05-09-2016 01:14 PM
Bespoke A/V Hidden Option UbSaMrC Electronics | Audio | NAV | Infotainment 58 12-13-2015 11:14 PM
FS: Custom Stainless Lightweight Hidden Hitch that_guy Canada Classifieds 3 06-11-2014 07:13 PM
Hidden Rusting issue FRSHunter Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 1 04-07-2014 05:02 PM
DIY: access hidden menus on BRZ head unit robot DIY (Do-It-Yourself) Guides 0 10-22-2013 11:59 PM
