#29 |
Thupercharged
I really should, the Ej205 is an archaic pig compared to modern engines
2013 FRS
Vortech V3 11psi Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300 2019 Series.Grey STI - Stage1+ SF |
| The Following User Says Thank You to DJCarbine For This Useful Post: | wparsons (07-16-2015) |
#31 |
Sarcastic SOB
For aftermarket:
Simplicity. Less potential for failure with less parts. Less potential heat issues. Centrifugal system, a good design has very low parisitic loss. " " , gentler onset of extra torque easier on driveline " " , doesnt drastically change the personality of the engine On the other hand, I prefer turbo if it is factory equipped as the details are most likely ironed out for dependability, eg: I have a 2015 WRX
#32 | |
Thupercharged
2013 FRS
#33 | |
It is not intended to be run on a track. It is not designed to handle the duty cycles it would see on a track and you are typically on gas too often on the track for it to recharge. I was on the waiting list and spoke to Rob and Fenton both about tracking it, as that was the primary use of the car by the time I had the opportunity to buy. After speaking with them, I passed and will go the JRSC route in time.
"It is better to keep your mouth closed and let people think you are a fool than to open it and remove all doubt." Mark Twain
| The Following User Says Thank You to Jonsey For This Useful Post: | CSG Mike (07-16-2015) |
#34 | |
A proper turbo setup works great at the track, just as a proper sc setup would. But it's always easy to pick out examples of each that don't. |
| The Following User Says Thank You to AVOturboworld For This Useful Post: | NLS8520 (07-17-2015) |
#35 |
I wish someone made a GT25x based kit (or similar sized EFR turbo). I don't want 350+whp, and don't want that much headroom just adding lag. No e85 up here, and no interest in a lower compression block. A solid 260-270whp would be perfect, and for off the shelf solutions the supercharger kits are the best option.
#36 |
NASA SpecE30 Racer
I'm running a GTX3076R on my S2000. Boost was as high as 10 psi during the weekend.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
| The Following User Says Thank You to King Tut For This Useful Post: | wparsons (07-16-2015) |
#37 | |
I Love custom Turbo kits
Drives: Limited BRZ
| The Following User Says Thank You to Sportsguy83 For This Useful Post: | wparsons (07-16-2015) |
#38 |
Drives: 2022 BRZ Limited
like others mentioned transient response (this may be very critical at the track and mimic lift-off oversteer) ..also there are so many different variations of each options (turbo vs SC), positive displacement, centrifugal type, journal bearing, ball bearing, single vs twin scroll ..list goes on.. each has their pros and cons so one size doesn't fit all
if you're ultimate goal is to make big hp then turbo it is, never really understood why people choose this platform to begin with, if that's what they're after though
#39 | |
Basically all custom minus maybe the manifold if the flange is compatible with the turbo I would end up picking. In all honesty, if the Greddy kit was available with a more modern (and smaller) turbo it would be pretty damn close.
#40 | |
NASA SpecE30 Racer
- King Tut
#41 | |
Drives: Crystal Black BRZ(Sophia)
| The Following 2 Users Say Thank You to Yoda For This Useful Post: | CSG Mike (07-16-2015), Sportsguy83 (07-16-2015) |
#42 |
Cost, plain and simple. It'll be way more expensive to get a custom kit fabbed up than to just buy the JRSC kit that gives me the same hp I want.
| The Following User Says Thank You to wparsons For This Useful Post: | D_Thissen (07-16-2015) |
| charged86 supercharged to build motor turbo | charged86 | Member's Car Journals | 9 | 07-24-2015 11:48 PM |
| turbo/supercharged FRS ride along? | dgerny | Northwest | 26 | 05-15-2015 11:43 PM |
| wtb Turbo or Supercharged auto FR-S/BRZ | TurboCarder | Want-To-Buy Requests | 1 | 01-27-2015 07:10 PM |
| wtb Turbo or Supercharged auto FR-S/BRZ | TurboCarder | Cars for Sale/Trade | 0 | 01-27-2015 09:31 AM |
| Turbo BRZ smashes a Supercharged v8 in a drag | CSI:86 | Forced Induction | 41 | 05-14-2013 09:12 PM |
