Old 07-07-2015, 01:54 AM   #155
8R6
8R6's Avatar
Drives: FRS
Originally Posted by Vracer111 View Post
No real issues you need to worry about, just put a 3.3 ohm resistor in the SRS seat connector and leave the seat belt connector unplugged - then install the bracketry and seat. Done!
If using sliding rails it helps if you tighten down one rail at a time - like tighten the front inside mounting point, then slide the seat back and forth, then tighten the rear inside mounting point. Slide the seat back and forth to settle the slides and repeat process for the outside rail. Slides will be smooth and easy operating yet rock solid when locked. Hardest part of the whole process is getting the seat in and out of the car without messing up the door sill rubber and plastic...
thanks for the tip!
8R6 is offline   Reply With Quote
Old 07-08-2015, 04:20 PM   #156
Krovi
Krovi's Avatar
Drives: '14 Midnight Purple FR-S
'14 MIDNIGHT PURPLE FR-S 『フェイリス』
Follow me on Instagram @overlim.it
Krovi is offline   Reply With Quote
The Following 2 Users Say Thank You to Krovi For This Useful Post:
8R6 (07-08-2015), swarb (07-16-2015)
Old 07-16-2015, 09:38 AM   #157
AJ124
Drives: 13' Toyota GT86
Originally Posted by JD86 View Post
Probably should have posted these in November when I installed them. Recaro Sportster CS's in black leather and alcantara with airbags. These are the OEM equipment from the Japanese STI TS model complete with genuine recaro rails. I just had them finished in black without the STI logo as I have a Toyota and not a BRZ.
Oh and Takata 4 point harness with TrackArt harness bar.
Looks great! you don't happen to have the part numbers for the seat rails? I might have a pair of CS I can use but need rails. Cheers.
AJ124 is offline   Reply With Quote
Old 07-16-2015, 04:36 PM   #158
swarb
Originally Posted by Krovi View Post
Looks good.
Please post the full setup. Seat, Rails, If the seat is centered, how low it sits compared to stock, the steering wheel, hub. And what you like/dislike about the setup. Also the shifter and the details, like if you hit the dash going into the 1st/3rd/5th and what gear it is in, in the pic.
Old 07-18-2015, 06:36 AM   #159
Krovi
Krovi's Avatar
Originally Posted by swarb View Post
Looks good.
Bride Zeta III, Buddy Club rails, seat's centered, sits pretty much on the ground, I'd say almost 2-3 inches lower than stock.
Steering wheel is a suede Sabelt SW-633 with a Splash (Works Bell) short hub, it's actually a little too close to the signal/wiper stalks right now so I have a spacer on order until I'm ready for a quick release.
Shifter is a TWM Competition shifter, no problems with hitting the dash, but I've slipped once and punched my radio before hahaha.
The Following User Says Thank You to Krovi For This Useful Post:
swarb (07-18-2015)
Old 07-18-2015, 03:40 PM   #160
ZOMFGAARON
A Demon
ZOMFGAARON's Avatar
Drives: Raven GT86
Looks like you need a resistor :p
Old 07-18-2015, 06:16 PM   #161
swarb
@Krovi are they really centered? Which L brackets are you using? From my experience with buddy club brackets and recaro spg and pole positions; they sit to the left of center. This has been the case on multiple cars I have sat in.
Old 07-20-2015, 09:26 PM   #162
Cross
It's the Mad Cow
Cross's Avatar
I thought I posted here but I guess I didn't.
Did these Evo 8/9 seats back in 2014. I want to say around March.
Either way they have the pressure sensor in the seat for awhile but not where it could work properly as I would have to take the seats apart and I do not want to cause issues. Now it's just under the seat.
Resistor for the Airbag Light, everything works great.
I have to say seeing someone else's work with the Recaro's out of the RX8 I might give that a shot next as a friend really would like these.
Guess we will see what happens.
First two pictures are from when we installed them, after that I have not really taken many pictures of the interior so I used the most recent with my wife in the drivers seat.
The Following User Says Thank You to Cross For This Useful Post:
RallySport (09-01-2018)
Old 11-06-2015, 04:45 PM   #163
Trap63
Trap63's Avatar
Drives: Brz WRB - Europe LHD
Hi JD86, do you have parts no. for oem recaro rails?
Trap63 is offline   Reply With Quote
Old 11-09-2015, 12:55 AM   #164
protpibe
protpibe's Avatar
Drives: 4-Runner Sport - 13' BRZ SportTech
Edirb 023 red stitch with bride rails and Takata drift 3 harnesses
Top Tier Imports - Check out my build journal HERE
protpibe is offline   Reply With Quote
The Following 2 Users Say Thank You to protpibe For This Useful Post:
8R6 (11-09-2015), SkAsphalt (08-03-2016)
Old 06-15-2016, 04:16 AM   #165
kingkenny
Drives: 2014 Toyota GT86
Bride Zeta 3 Type L FRP and Type FG rail
kingkenny is offline   Reply With Quote
Old 06-15-2016, 04:34 AM   #166
kingkenny
Right now , I have the stock seat belt buckle flip over and it clear everything .
I want the OEM belt to hold better and plan to redo it again soon . I am thinking let the seat belt go through both side tunnel , use the rear seat belt buckle (lot shorter) , and do a resistor on the buckle wire(someone mention just unplug it ?) to trick it .
So on street I fasten the seat belt from top , and I can plug the belt in through side tunnel on track for better holding .
If anyone know a better solution ? If not , I just try ...
Old 06-15-2016, 05:29 PM   #167
kingkenny
I got the seat belt buckle done , now the seat belt can go through both the side hole , find my confidence on hard braking again , no more slip out from the seat .
It take some time to figure it out what to do , I check both front rear seat buckle and both of them are tall and bent , not idea fit . So I have one of the rear cut and weld , make it straight and short .Don't need resistor for seat belt chime , take the wire/harness out of the buckle and unplug it from the connector under the seat .
Old 06-17-2016, 03:48 PM   #168
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
another pic of my pole positions
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
The Following User Says Thank You to spitfire481 For This Useful Post:
M1K3 (06-17-2016)
Using OEM Mic for Aftermarket Radio AND/OR Replacing OEM Mic with Aftermarket Mic ecko04 Electronics | Audio | NAV | Infotainment 10 05-05-2018 04:47 PM
SOLD: Used (But Like New Cond.) Stock FR-S Seats w/ rails (Both Seats) Vicious LED Interior Parts (Incl. Lighting) 16 07-21-2013 07:45 PM
WTT: My FRS seats for your BRZ Premium Seats Hanakuso Interior Parts (Incl. Lighting) 17 03-04-2013 02:37 PM
Aftermarket Seats sets off SRS light? Hanakuso Cosmetic Modification (Interior/Exterior/Lighting) 1 08-25-2012 06:09 PM
Please post FR-S w/ aftermarket leather seat pics ngabdala Scion FR-S / Toyota 86 GT86 General Forum 6 05-31-2012 10:51 AM
