#435 |
Drives: 2015 BRZ
This is probably a stupid question, but here it goes anyway. I haven't tuned a car since my talon that used a palm pilot for logging.
![]() I'm still having trouble with my boost control. They sent me a new map and specifically mentioned this is an abnormal tune to see if they could get the boost down. Before it was spiking to 13psi or so before I let off. With this new tune I'm hitting 10psi on the "wastegate spring" tune which is 7psi. So it's still a little high. I know everything is 100% hooked up correctly. It's a well known company so I know they know what they are doing. My tune is for the jdl base kit. Do you think my gtx upgrade might make a difference? That's the only thing that I can think off that's not normal. I'm all out of ideas. |
#436 | |
5.8PSI wastegate spring, 6" hose to MANIFOLD will net ~ 6PSI 5.8PSI wastegate spring 18" hose to MANIFOLD will net ~ 6.5PSI 5.9PSI wastegate spring through 24" house to MANIFOLD and through a solenoid that reduces the flow even further (hose flexes, and bends reduce flow) ~7PSI. These are made up numbers but realistic expectations. Your hose diameter, flex abillity, length, and where the boost reference is coming from will make a difference. I used MANIFOLD as an example as the manifold is the end of where your boost is, and where you read your boost. If you hooked up the gate to the turbo then you will be making around the boost level if not lower due to the wastage regulating the pressure at the housing not at the manifold (further down the pipeline!) To verify this logic unplug the harness from your boost controller and see what pressure you get as "wastegate" only. This would mimmic the map being filled with 0's. If your solenoid is plumbed correctly then the wastegate will get constant pressure from the pressure source when disconnected.
When I grow up, I wanna be God. My flickr - Canibeat Local magazine scout Old Setup: Vortech Supercharged 360WHP/262WTQ @ 11.5psi My build thread - WTF happened to nelsmar's car thread |
#437 | |
Drives: 2013 SWP BRZ
#438 | |
#439 | |
I believe Zach mentioned that if the EBCS is disconnected it will just run off spring pressure, as I was worried about passing inspection a while back and we were discussing the Evap system monitor not being in a ready state. So I was debating on disconnecting that to run the stock solenoid again and I believe he mentioned it would run off spring pressure. For anyone who is curious I have the codes shut off for the purge valve solenoid and the Evap system will still show as a ready monitor and won't show unavailable. |
#440 | |
#441 | |
I can try unplugging it, and it should hit 5.8 since thats the spring I have in there for the wastegate. I know for a fact its not plumbed wrong. I mean its two lines...lol. Even with the 3rd line in there it doesn't take much to realize what goes to what. I am meticulous with that crap because I don't want to blow my car up
#442 | |
Drives: 2015 BRZ
During the initial teoubleshooting I was doing I took the two hoses off of the EBCS and connected them together. My wastage spring is 7. Something psi. With those hoses connected, bypassing the controler, I ended up with 7psi ok my gauge. But let off around 5k because I wasn't sure if I had other issues. |
#443 | |
#444 | |
#445 | |
Drives: 2015 BRZ
But your way...there is my extra 2-3 psi. I have the 7.25psi spring in the wastegate. Running unplugged I hit 7psi right way. Then 8 for a bit then 9psi once I get over 5500 rpm or so. I might just give up on the e-tune and have the same person that tuned my 500hp wrx wagon tune this one. |
#446 |
Drives: 2015 BRZ
Well...last ditch effort here.
Has anyone with a jdl kit used a delicious tune? Their off the shelf one isn't working working for me at all. Following advice here i bypassed the EBCS and hit 9psi. So they suggested just bypass the EBCS and run off of wastegate pressure. Well...that lead to a dtc for the purge valve. I don't want to hook it up factory because the purge valve will just be randomly opening to control boost. So today I just bypassed the EBCS by hooking the two hoses together. But I'll probably only get 7psi or so that way. I almost feel like at this point it was a waste of 1200 bucks. It's been a couple weeks and I still don't know what it's like to drive a turbo brz. ![]() Maybe something is wrong with my car. I don't know at this point. |
#447 | |
Drives: 2013 FRS
#448 |
Drives: 2015 BRZ
Huh. What the hell is the deal with my car I wonder. I don't care about the extra boost, but I also see knock correction the entire time too.
Oh well. Looks like a dyno tune is in my future then.
| HKS Supercharger owners thread | wbradley | Forced Induction | 1054 | 10-26-2024 01:18 PM |
| P&L Turbo kit Owners thread | Hawaiian | Forced Induction | 73 | 07-07-2018 02:31 AM |
| To Greddy Turbo Owners (or SBD/Zage Turbo).... Melted Radiator Fans? General Opinion? | xuimod | Forced Induction | 106 | 09-01-2016 07:33 PM |
| **Offical 213/323/626/818 owners thread** | mr. slim | Southern California | 71 | 10-07-2013 12:58 PM |
| P&L Turbo Owners Topic Thread | GTB/ZR-1 | Forced Induction | 4 | 09-01-2013 06:27 PM |
