| DIY (Do-It-Yourself) Guides For all DIYs. |
Drives:
iJDMToy Valenti Brake Light.
Any video or better guides/instructions to have the V-Light go on?!
I have the running light on and reverse lights on. Anything im missing or doing wrong ? Bought this from the iJDMToy store in Los Angeles. |
#2 |
Nobody Epic
Drives: 2014 WRX SWP
You have to wire tap a wire from valenti brake light to make the red V luminate. Here's the video I used to install mine. [ame]http://youtu.be/0jrFASjxwWQ[/ame]
| The Following 3 Users Say Thank You to FRSPhil For This Useful Post: |
#3 |
Drives: White 2013 BRZ
HELP PLS
So my reverse light works and the top triangle brake light works, but the long running light that is shaped like this -------v------- doesn't work, which connection am i messing up that would cause that not to work?
#4 |
Drives:
Which one you get the Valenti from Japan or Valenti style one from ijdmtoy
#5 |
The IJDMTOY one, which connection is responible for the long middle light to be running with the running lights on the tails. Thank you for the help btw
#6 |
Drives:
Just tap the brown wire to the running top triangle light and should light it up. Cuz the blue wire is tapped to oem wires, just tap the brown to that one and leave it as it is don't connect it anywhere else but that blue one I think it's blue lol if you can't I'll send a pic of how my wires look
#7 |
Drives:
| The Following User Says Thank You to jesse_86frs For This Useful Post: | Bimble Bamble (06-01-2015) |
#8 |
My top triangle doesn't run, it's only for braking, the middle light is the only one suppose to he running I believe
#9 |
Drives: 10 Series
Nice pic. Nice to see the 5 Axis and buddy clubs on the silver. Are the BC tails smoked?
Last edited by Bimble Bamble; 06-01-2015 at 09:34 PM. Reason: Sorry, I meant TRD spoiler |
#10 | |
Drives:
Car is a WhiteOut. The picture is filtered here's the original. Sent from my iPhone using Tapatalk |
#11 |
Drives:
Got the V light to be running light and brake light to function now.
#12 | |
Drives: 2013 Asphalt FRS M/T
Currently the led bar and triangle are always on together. |
#13 |
Drives:
V light should be hooked up to parking light and triangle to the brake light.
#14 |
Drives: BRZ 2014 Limited Black
Stuck on wiring
I'm having the same trouble you had except on mine the V or anything won't light up I'm a little confused on which wires go where. I'm trying to run it with the tails and brakes applied. Can you help possibly? When I unlock and lock the car the V seems to light up along with the emergency hazards.
| Valenti Bumper Light $179.99 Tail Light $299.99 Fog Light Kit $90.99 | nigel-jdmparts | Exterior Parts - Lighting | 14 | 06-23-2015 06:32 AM |
| SOLD -Valenti Tails and Valenti 3rd light (Smoked) / Wheelhaus' headliner brake light | AtlasMick | Exterior Parts (Aero, Lighting, Etc.) | 8 | 03-07-2015 06:51 PM |
| iJDMTOY flashing 4th break light | ReaperX43 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 09-19-2014 09:57 AM |
| Valenti Fourth Brake Light With Stock Tails | mackdaddytran | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 06-20-2014 11:03 AM |
| Valenti 3rd brake light wiring | SPCorBUST | Southern California | 4 | 09-24-2013 11:57 AM |
