Old 04-05-2015, 06:10 PM   #1
jesse_86frs
jesse_86frs's Avatar
Drives:
iJDMToy Valenti Brake Light.
Any video or better guides/instructions to have the V-Light go on?!
I have the running light on and reverse lights on.
Anything im missing or doing wrong ?
Bought this from the iJDMToy store in Los Angeles.
jesse_86frs is offline   Reply With Quote
Old 04-07-2015, 09:09 AM   #2
FRSPhil
Nobody Epic
FRSPhil's Avatar
Drives: 2014 WRX SWP
You have to wire tap a wire from valenti brake light to make the red V luminate. Here's the video I used to install mine. [ame]http://youtu.be/0jrFASjxwWQ[/ame]
FRSPhil is offline   Reply With Quote
The Following 3 Users Say Thank You to FRSPhil For This Useful Post:
Bimble Bamble (04-17-2015), Slammedsteve (08-12-2015), YamahaR86 (04-22-2016)
Old 05-09-2015, 10:53 AM   #3
JR Whiter
Drives: White 2013 BRZ
HELP PLS
So my reverse light works and the top triangle brake light works, but the long running light that is shaped like this -------v------- doesn't work, which connection am i messing up that would cause that not to work?
JR Whiter is offline   Reply With Quote
Old 05-10-2015, 04:36 PM   #4
jesse_86frs
Drives:
Which one you get the Valenti from Japan or Valenti style one from ijdmtoy
Old 05-10-2015, 09:12 PM   #5
JR Whiter
The IJDMTOY one, which connection is responible for the long middle light to be running with the running lights on the tails. Thank you for the help btw
Old 05-10-2015, 10:13 PM   #6
jesse_86frs
Drives:
Just tap the brown wire to the running top triangle light and should light it up. Cuz the blue wire is tapped to oem wires, just tap the brown to that one and leave it as it is don't connect it anywhere else but that blue one I think it's blue lol if you can't I'll send a pic of how my wires look
Old 05-10-2015, 10:13 PM   #7
jesse_86frs
Drives:
The Following User Says Thank You to jesse_86frs For This Useful Post:
Bimble Bamble (06-01-2015)
Old 05-11-2015, 11:55 AM   #8
JR Whiter
My top triangle doesn't run, it's only for braking, the middle light is the only one suppose to he running I believe
Old 06-01-2015, 09:27 PM   #9
Bimble Bamble
Drives: 10 Series
Nice pic. Nice to see the 5 Axis and buddy clubs on the silver. Are the BC tails smoked?
Last edited by Bimble Bamble; 06-01-2015 at 09:34 PM. Reason: Sorry, I meant TRD spoiler
Bimble Bamble is offline   Reply With Quote
Old 06-02-2015, 05:16 AM   #10
jesse_86frs
Drives:
Car is a WhiteOut. The picture is filtered here's the original. Name:  ImageUploadedByTapatalk1433236588.902219.jpg
Old 06-30-2015, 12:28 AM   #11
jesse_86frs
Drives:
Got the V light to be running light and brake light to function now. Name:  ImageUploadedByTapatalk1435638520.600905.jpg
Old 07-10-2015, 02:30 AM   #12
Joshwahhhs
Joshwahhhs's Avatar
Drives: 2013 Asphalt FRS M/T
Originally Posted by jesse_86frs View Post
Got the V light to be running light and brake light to function now. Attachment 113933
Hey, I have the same reverse light as you but my triangle stays on the whole time. How did you wire it so that the triangle goes on with the brake?
Currently the led bar and triangle are always on together.
Joshwahhhs is offline   Reply With Quote
Old 07-15-2015, 09:08 AM   #13
jesse_86frs
Drives:
V light should be hooked up to parking light and triangle to the brake light.
Old 07-25-2015, 03:33 AM   #14
mervingee
Drives: BRZ 2014 Limited Black
Stuck on wiring
I'm having the same trouble you had except on mine the V or anything won't light up I'm a little confused on which wires go where. I'm trying to run it with the tails and brakes applied. Can you help possibly? When I unlock and lock the car the V seems to light up along with the emergency hazards.
mervingee is offline   Reply With Quote
Valenti Bumper Light $179.99 Tail Light $299.99 Fog Light Kit $90.99 nigel-jdmparts Exterior Parts - Lighting 14 06-23-2015 06:32 AM
SOLD -Valenti Tails and Valenti 3rd light (Smoked) / Wheelhaus' headliner brake light AtlasMick Exterior Parts (Aero, Lighting, Etc.) 8 03-07-2015 06:51 PM
iJDMTOY flashing 4th break light ReaperX43 Cosmetic Modification (Interior/Exterior/Lighting) 0 09-19-2014 09:57 AM
Valenti Fourth Brake Light With Stock Tails mackdaddytran Cosmetic Modification (Interior/Exterior/Lighting) 0 06-20-2014 11:03 AM
Valenti 3rd brake light wiring SPCorBUST Southern California 4 09-24-2013 11:57 AM
